9 inch bearing renew - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-16-2004, 10:30 PM   #1 (permalink)
Member # 1441
I had a weeping seal on my ford 9" axle.
This is not the first time I have replaced a seal. however, my shop press is still loaded out so I did it shade tree fashion.
Installing the seal. bearing race and retention collar the best I coul
I used a MAP gas torch to heat the collar before I used a scrap piece of tubing to drive the hole lot against the flange. I heated the collar untill spit bounced off of it.
By heating the collar, was it's strength compromised. if it was will it fail?
alimony: verb: The Efn ya get 4 da Efn ya got
kodak is offline   Reply With Quote Quick reply to this message
Old 09-17-2004, 08:32 AM   #2 (permalink)
Member # 1441
anyone?
Old 09-17-2004, 09:42 AM   #3 (permalink)
Member # 21914
There should be no problem. Heating bearing retaining collars is common.
There was one brand (I won't mention, since they fixed the problem) that used a different material that when heated, expanded and stayed. It was too tight to press cold, but when heated, it dropped on - then fell right off when cool.
I'm confident you are fine.
CARBON Off Road
Racing Ron is offline   Reply With Quote Quick reply to this message
Old 09-17-2004, 12:13 PM   #4 (permalink)
45acp's Avatar
Member # 13671
Been running mine w/ the redneck install for about 5 years now.... still going strong.
45acp is offline   Reply With Quote Quick reply to this message
Old 09-17-2004, 10:45 PM   #5 (permalink)
Member # 1441
Way too go! I didn't think I fawked it up. It was a Timken set.
The cool part was I did the same with the race in the axle tube, Heated and used the claw end of my framing hammer. Came out with little effort. Installing the new race was even easier 'cause it was cold and the axle was heated. sliped in like an elephant twat.
Thanks
Old 09-18-2004, 02:34 PM   #6 (permalink)
Member # 187
Thanks
and just how would you no that was the fit of a elephant twat anyway?
[FONT="Arial Black"][SIZE="5"][/SIZE][/FONT]
:flipoff2:
GearMan is offline   Reply With Quote Quick reply to this message
