AN-06 adapter for Explorer remote res. steering pump? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-21-2004, 04:38 PM   #1 (permalink)
Member # 3959
I'm going crazy here - I know it’s been posted before, but I can't find it in a search.
I'm using a '00 Ford Explorer power steering pump with a remote reservoir and am trying to make my lines using AN-06 fittings. I have all the fittings I need except the one that goes into the pressure outlet of the pump. It’s a metric fitting that has an o-ring down in the pump and I think a crush washer at the pump body. It’s been posted before where to buy one (it’s not a standard fitting - ie the earls/aeroquip/etc 16mm o-ring fitting is not it), but I’m having zero luck finding it.
Anyone know where to get it?
-Ben
'74 Bronco - some assembly required... one of these years I'll drive it again.....
injectedEB is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 06:00 PM   #2 (permalink)
Member # 5110
http://www.holley.com/HiOctn/ProdLin...PA/991941.html
Twards the bottom are the o-ring fittings...no idea which one but there are only 3 choices.
Then get them from summit or something.
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 06:04 PM   #3 (permalink)
Member # 4554
Send a message via AIM to bluesman2a
Call Tom at PSC, he sells what you need, and they are steel, not aluminum.
http://www.pscpowersteer.com
For what it's worth, I did the same thing on mine, all my steering hoses are standard AN fittings and the adapters are on the pump and box.
<blank>
bluesman2a is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 09:17 PM   #4 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Try here This is what you are looking for
ROCK HUGGER is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 09:50 PM   #5 (permalink)
yager's Avatar
Member # 10695
Send a message via AIM to yager
since you said crush washers i figured id post this up. Its off a montero pump i was running on my zuke. Basically i took a -6 fitting to NPT 1/2"? i think i drilled out the threads and then brazed it to the factory junk. It worked good.
Mike Yager -
- 3800 v6 Supercharger, Toy axles etc..
Stroke - Coumadin (warfarin) - INR - Heart Valve - Ask me (true story)
yager is offline   Reply With Quote Quick reply to this message
Old 09-21-2004, 10:51 PM   #6 (permalink)
Member # 5926
Lee power steering gave me one.
Brian Wickert
Hanford, CA
KingOf_Pain is offline   Reply With Quote Quick reply to this message
Old 09-22-2004, 07:14 AM   #7 (permalink)
Member # 3959
Dooh - you were the one that originally told me, oops. So you got the phone # or website?
edit : Is this it? http://www.leepowersteering.com/
edit2 : I tried every fitting the local speedshop (master warehouse distributor for earls and aeroquip) had without any luck, then called Lee as suggested above and had the correct part in a few days. For anyone else trying the route, save your time and give Lee a call.
-Ben
