Anyone heard of a Warn MX10000? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2002, 07:08 PM   #1 (permalink)
Member # 876
I found a used winch, a warn MX10000, and was wondering if anyone here knows the specs for one? Was it a worm drive winch or planetary gears? Were they any good or should I hold out for a HS9500i?
1971 FJ 40
85toyboy is offline   Reply With Quote Quick reply to this message
Old 02-05-2002, 07:10 PM   #2 (permalink)
Member # 7600
More commonly known as a m10000? Not a bad winch but very slow. Go with a 8274. The run fast and are very reliable.
jeeps with stuff
wild1 is offline   Reply With Quote Quick reply to this message
Old 02-05-2002, 07:38 PM   #3 (permalink)
Member # 6350
M10000
Model: Warn M10000
Gear reduction ratio: 164:1
Motor: 2.5 hp, series wound
Gear train: 3 stage planetary
Weight: 125 lb.
Line Pull Line Speed Current
(lb) (ft/min) (amps)
0 35 80
2000 14 163
4000 9 245
6000 6 322
8000 4 400
10000 3 475
For more winch infor try this Winch tech page
bronco78 is offline   Reply With Quote Quick reply to this message
Old 02-05-2002, 07:40 PM   #4 (permalink)
Member # 4001
It may be slow but it does work very well. I know someone who was stuck in their YJ (in the snow) and pulled themself and 2 other stuck vehicles out at the same time. It's a little too big for my taste though.
Scout Dude is offline   Reply With Quote Quick reply to this message
Old 02-05-2002, 07:48 PM   #5 (permalink)
Member # 876
So you think it would be to big for my toy pickup? I was thinking about building a receiver mount system to use on my toy and on my full size extra cab chevy. I'd need a big winch for the chevy, but don't want to weigh down my toy too much.
1971 FJ 40
Old 02-05-2002, 07:59 PM   #6 (permalink)
Member # 9006
i agree get and 8274 they are a little big but very strong and reliable ive got one on my 76 chevy it pulled me and a cheroke up a hill through mud and the jeep did not run
toyletrider is offline   Reply With Quote Quick reply to this message
Old 02-05-2002, 08:19 PM   #7 (permalink)
mj
Member # 1919
what was the model number for the good worm drive warn 10000.
could that be the mx?
mj is offline   Reply With Quote Quick reply to this message
Old 02-06-2002, 11:54 AM   #8 (permalink)
Member # 9726
Just what does the X in MX mean? I've got a MX8000, it says MX right on the plate, but everybody including Warn (on service calls and emails) calls it a M8000.
92xj is offline   Reply With Quote Quick reply to this message
Old 02-06-2002, 04:12 PM   #9 (permalink)
Serious One's Avatar
Member # 8768
Toy Boy,
TRUST ME, I have lugged ALL of those Warn winches around for the past 3 years. (all of the product catalog and web shots are mine)
I know them all too intimately, and I would suggest that for a multi-mount style winch, to NOT use the M10 or M12. Even the 8274 might be kind of a funky thing to have on a multimount unless the cradle is EXTREMELY bulky and reinforced.
If you're just putting it on a small-ish Toyota, you ought to look for an 8000 or 9000 model. The 9500 is a bit heavier, but you probably don't *really* need (or want) the speed and expense.
The M10 is a sweet winch, I have one on my 1990 Range Rover, I just wouldn't want to have it on a cradle heaving it all over the place.
A suggestion for the multi-mount when it's NOT being used. Make a dummy reciever hitch with a 6x6 plate (or so) bolted through the floor so the winch has a secure place to live. Either mount the winch horizontally or vertically depending on which will fit better.
Good luck!
M
Serious One is offline   Reply With Quote Quick reply to this message
