Butt weld vs press fit then weld...which one??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2002, 11:56 AM   #1 (permalink)
Member # 3549
well a buddy and i are each making full floater 9"s in the spring and we need some advice. we are gettting the flanges made locally to accept a chev d44 spindle and need to figure out the best way to weld the flanges to the tubes. for simplicity we would like to press them on but for total alignment they should be butt welded with a jig right? if we had the flange made with a sleeve that presses over the axle tube like 4"s would that be enough to make sure the flange is perfectly aligned with the carrier bearings? ideas please...
19935.043520330044143812.509000
AndrewH is offline   Reply With Quote Quick reply to this message
Old 02-11-2002, 09:21 PM   #2 (permalink)
Member # 4224
You won't need a jig, buy a good angle finder.
I use a machinist combination head with a level vial for everything. Just keep everything at the same angle in relation to the machined surfaces on the pig. Align the spindles, rotate the housing 90 deg. and align it again, tack weld it and double ck. everything.
A small slip fit would make it easier than a butt joint.
dirtrod is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 05:09 PM   #3 (permalink)
Member # 7174
Anybody else? We could sure use some advice on this...
Chris
cwate is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 10:24 PM   #4 (permalink)
Member # 3549
well with the huge response i will rephrase the question. if i gave you a r/c 60 housing (to cut down/lengthen) to put in the back of your jeep would you press the flanges on or use a jig with aluminum pucks for total alignment????
*this is if you could get any flange made you needed.*
Old 02-12-2002, 10:28 PM   #5 (permalink)
Member # 4001
I'd pay to have someone with the jigs do it right (Sorry DR). This is because I don't trailer my rig so it's important that it is exact. Them bearings are expensive.
Scout Dude is offline   Reply With Quote Quick reply to this message
Old 02-13-2002, 12:12 AM   #6 (permalink)
Member # 144
Id use (and will be using) a jig. You'd be suprised, they're not all that expensive.
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote Quick reply to this message
