Advantages/Disadvantages of longer shackles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2005, 11:09 AM   #1 (permalink)
Member # 40636
Ok I have a SFA S10 blazer and Im using chevy rear shackles up front upside down. So I was thinking of buying 3 inch longer "lowering" shackles which would actually lift a slight bit because mine are upside down and because I hear longer shackles articulate better. You guys think its a good idea???
SmashedS10 is offline   Reply With Quote Quick reply to this message
Old 01-04-2005, 11:17 AM   #2 (permalink)
Member # 6957
the only problem i see with longer shackles is if there "thin" and not gusseted they will bend sideways. for example take a 3" piece of steel and put one end in a vice and see how far you can bend it. now try this with a piece 6" long.
ironpig70 is offline   Reply With Quote Quick reply to this message
Old 01-04-2005, 12:03 PM   #3 (permalink)
Member # 15404
It will change your steering geometry (caster) a bit if you just add the longer shackles and do nothing else.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 01-04-2005, 12:05 PM   #4 (permalink)
Member # 32613
Some of the guys I run with use those in the rear after a shackle filp. I can't count how many times they have crushed, collapsed, torn, or just plain broke. I killed my stock ones also and mad a set using 1.5x1/4" flat stock and rienfroced the center so it looks like an ' A ' haven't had a problem yet. The jeep cherokees have a lift shackle that is 2x3/8" flat stock and should bolt right in.
[COLOR="DarkOrange"][B]KOH: Won in the desert - Lost in the rocks[/B][/COLOR]
az-k5 is offline   Reply With Quote Quick reply to this message
Old 01-04-2005, 12:45 PM   #5 (permalink)
Member # 16384
Send a message via AIM to paulevans76
as long as they are built correctly and kept at a reasonable angle, they should be fine.
91 Isuzu Trooper Y-link/coil SAS
35" Grabber X3's, tera low, d44's: RCV's, OX, detroit, 5.38's
paulevans76 is offline   Reply With Quote Quick reply to this message
Old 01-04-2005, 12:52 PM   #6 (permalink)
Member # 62
3" longer will really throw your caster out of wack, but yes a longer shackle will usually give you more flex. The exception is if you have flat or nearly flat springs you probably won't notice anything
NE-RokToy is offline   Reply With Quote Quick reply to this message
