Cutting Frame for shorter wheelbase - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-15-2005, 10:07 AM   #1 (permalink)
Grayguy's Avatar
Member # 38695
Send a message via AIM to Grayguy
I already posted this in the newbie forum, but apperently no one there knows, so: Is it a bad idea to cut inbetween 1-2 feet out of a 85' dodge long bed frame to shorten up the wheelbase? The frame would be boxed and all welded up with a arc welder using 7018 rods. Also, if the frame is boxed, what is teh best way to run all of the lines?
Grayguy is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 11:01 AM   #2 (permalink)
Member # 26262
That's a reasonable thing to do. The limit to the quality of the result is your skill. I'd take out more than that though. like get the wheel base down to 115". Cut the front and back down to get rid of overhang.
It is illegal most places to alter the frame in a critical spot, and have it licenced as the same vehicle. I doubt anyone will notice, care, or know it's illegal, though.
Running the lines can be as easy or hard as you want to make it. If you want to make it nice, come up with a good way to get them inside the frame. You have to make them not rub on stuff though, because after a while the frame will cut through break tubes. To do it fast, just use your imagination. Bailing wire, zip ties, those stock plastic clips, what ever.
That truck is way to big to wheel. Cut it down to be a really heavy Jeep.
Dalec is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 11:03 AM   #3 (permalink)
Member # 6967
As long as you know what your doing then No its not a problem. Leave the lines where they are at on the frame or run them on the outside of the boxed part. Its realy up to you and how you want it. IMO on the inside where they will be safe.
scott-885 is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 11:19 AM   #4 (permalink)
mj
Member # 1919
stock wheelbase is about 130"
my shortbox chev has a c30 frame under it
go for it if you are certain you want a short wheel base
I am looking to increase my wheelbase by pushing front axle forward and rear axle back
long is better
mj is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 11:25 AM   #5 (permalink)
Member # 26262
Small overhang is better, short wheelbase is better. Overhang is more important. I didn't realize they are already 130". in that case, hack out 2 feet to be cool. really get rid of the overhang though.
Old 01-15-2005, 12:17 PM   #6 (permalink)
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
make the cut like this / / (about 45* angles or so)
dont do vertical cuts. Figure out if you can sleeve the inside of the frame with some rectangle tube, this would be the strongest. If not just plate the outsides and top and bottom after welding the frame back together
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 01:31 PM   #7 (permalink)
mj
Member # 1919
mine was done vertically and plates bolted inside the rails
no issues to report since 1995
Old 01-15-2005, 02:14 PM   #8 (permalink)
Member # 2499
is it possible to blow all the spring mounts off the frame and slide everything forward?
72 k5
OneTonK5 is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 03:09 PM   #9 (permalink)
Member # 62
I know fords have a low rear axle hump and sometime in the distant future I will just be moving the spring mounts forward and doing a shackle flip, with a 4" lift I should have about the same axle to frame distance as stock height/stock location
NE-RokToy is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 03:45 PM   #10 (permalink)
mj
Member # 1919
yes but it looks very ugly
you can make it look factory cutting the straight section in the middle
Old 01-15-2005, 04:14 PM   #11 (permalink)
Member # 24837
i'd fishmouth it or use diamond shaped plates to brace where you cut the frame after welding it back together
kyle_22r is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 05:11 PM   #12 (permalink)
rockcrawlinredneck's Avatar
Member # 16662
Definatly do this. If you just butt weld the two ends together I dont think it would be that strong. The best way to go about doing it is like mentioned above, cut the ends like this // then after you weld them together plate it like this <> and you should be good to go. If you weld vertical or horizontial lines on the frame it will tend to be weak and stress crack at the welds.
Kevin
YJ Unlimited on tons/ARB's/Atlas/radflo's/42's/TR Beadlocks!
rockcrawlinredneck is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 08:02 PM   #13 (permalink)
Member # 20804
We have been talking about this over at ck5... there are two good threads
the bible on frame shortening ... and frame shortening...
both in the garage
all the answers are too long to put here so i suggest a visit might be worthwhile
cam
Frustrated hose beat in a black and white
camsk5 is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 08:16 PM   #14 (permalink)
Member # 800
when I did my wheelbase shortning I remounted all the spring perches forwards, this will only work if you are lifting at the same time though because of the axle / frame interference issue. then I just bucked off the excess frame and remounted the last crossmember at the new back of the frame. worked fine and dosn't leave any questions as to weld strength cause there are none.
my dodge sucked, I went superduty
mytzlflick is offline   Reply With Quote Quick reply to this message
Old 01-15-2005, 09:46 PM   #15 (permalink)
Grayguy's Avatar
Member # 38695
Thanks fo rthe replies, I read a bunch of stuff over at ck5 and I know what is going on now. Thanks
Old 01-16-2005, 03:47 PM   #16 (permalink)
Member # 7486
I did this with my 78 F250 frame, thinking it would be the easiest way to go.
I took the wheel base from 133" down to about 111". The front suspension is stock, but in the rear I used 63" Chebby leaves. I did a shackle reversal using the stock Chevy front spring hangers with a longer set of shackles.
The problem I had was that the frame angles in just in front of where the original front spring hangers were at. So, I had to build new front hangers to take in for the difference.
I didn't worry about the hump in the frame...for me, the springs go negative arch before they hit, so it isn't an issue.
Groundhawg is offline   Reply With Quote Quick reply to this message
Old 01-16-2005, 04:07 PM   #17 (permalink)
Member # 31425
Send a message via AIM to Ramboss429 Send a message via MSN to Ramboss429
I did this on a '75 f250 by moving the spring mounts forward to give it a wheelbase of 115". I also installed a 4" lift at the time so as not to interfere with the frame.
Ramboss429 is offline   Reply With Quote Quick reply to this message
