Front Dana 70 Open Knuckle, Pictures?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-26-2005, 04:04 PM   #1 (permalink)
Member # 41097
Hey everyone, i'm in need for some pictures of an opne knuckle dana 70 front axle, i have search the board for a couple days with no results, and i am wondering if anyone can help me out here, as i have a chance to aquire one for a decent price from out of some forklift or something (i got lucky to as its within a usseable lenght, a little wider than the truck, but its for the mud so it don't matter to much) like that, if possible a good front picture and a good of of the rear that shows everything would be appreciated.
Thanks.
mustange70 is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 04:07 PM   #2 (permalink)
b454rat's Avatar
Member # 16536
Dana 70 fronts look just like Dana 60 fronts, just the pumpkin is a little bigger.
Web wheeler
b454rat is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 04:13 PM   #3 (permalink)
sick_sahara_yj's Avatar
Member # 38380
Send a message via Yahoo to sick_sahara_yj
all the dana 70 fronts i have ever seen were closed knuckles. the only open knuckle ones i have seen had 60 inners machined and put on them. i think the only advantage is the bigger ring gear, and i think it has less ground clearance. iirc they take the same axles as the dana 60. i had 2 of them, and did not want to go through the trouble of replacing the c's so i traded them for a 60
If your not breaking stuff, then you arent trying hard enough.....smash the skinny pedal
sick_sahara_yj is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 04:21 PM   #4 (permalink)
GOAT1's Avatar
Member # 5969
You need one of these, Dana 80?
GOAT1 is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 04:27 PM   #5 (permalink)
Member # 12429
Steve @ Diff. Eng. makes D70 Fronts...They are NEW too i believe.
Dana 70 Fronts
Todd W is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 04:40 PM   #6 (permalink)
b454rat's Avatar
Member # 16536
They made Dana 70 open knuckle, but I don't think that any trucks came factory with them. I think that aftermarket companies doing 4x4 conversions on vans and motorhomes used them. Quigley for one.
Web wheeler
Old 01-26-2005, 06:03 PM   #7 (permalink)
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
for those of you not in the know as to what these axles come in
http://www.chevrolet.com/mediumduty/kodiak/c4500/
Im special, just like everyone else.
jstarnes is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 06:09 PM   #8 (permalink)
jstarnes's Avatar
Member # 12575
Dana 70 Fronts
Steve has 70 open knuckel king pin axles BUT wait not the same as a 60 king pin stuff its a king pin/knuckel combo big enough to use rockwell size u joints, they also use standard chevy type wheel hubs, spindles, and brakes
Old 01-26-2005, 06:44 PM   #9 (permalink)
steve gerstner's Avatar
Member # 12741
Send a message via Yahoo to steve gerstner
I have had these dana 70's laying around for 6 years, these were for front wheel drive motorhomes. This is a very LARGE tube fork and the steering knuckle is a stretched style dana 60, using chevy dana 60 parts top and bottom and all other parts. In the pic this is a 2 1/2 ton rockell axle and it clears very easy. I plan on reproducing these two items. steve differential eng. inc.
steve gerstner is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 06:51 PM   #10 (permalink)
Member # 12741
Why go through all the trouble to have dana 70's built for 1 1/2 and 2 ton trucks and use a 1480 U joints????????????
Old 01-26-2005, 07:56 PM   #11 (permalink)
Member # 41097
Well through my research there were dodge W600's and IHC 1600 that used the open knuckle dana 70. The difference's between the 70's and 60's were that the 70's used the bigger centersection (gears and such), the bigger/strong 3.5" tubes, as well as bigger inner c's, the only thing that were the same between the 70 and 60 were the rotor's, inner axles (stubs were 35spline on open knuckle 70's), calipers and spindles, and 35spl hubs intercahnge between the 2 as well as the stubs. I think that i will have to give a call to that wreckers i called today and see what that 12000lb front drive axle was (might just be an 80, that would be cool), but if this deal doesn't work out anyone know (or have) wher i can get some a good deal on a front 70 i can use in my competition bogger?
Oh and even though those pictures aren't of a 70, they help and give me a better idea.
Old 01-26-2005, 08:10 PM   #12 (permalink)
Member # 12741
The dodge W600 is closed knuckle with tracta joints 1967 to 1975, U joint 1974 to 1978. The IH 1300 and 1600 are U joint, closed knuckle. There is no dana 80 front made by dana for hwy. use. steve
Old 01-26-2005, 08:25 PM   #13 (permalink)
Member # 41097
and yet another thing learned, those used the 35spline outers as well, i thought the closed knuckle axles all used the 19 or 21 (can't for sure remember, i would have to look at the couple charts i have) spline outers, while on the subject, can the hubs (drive flanges, as that is what i want to use) from a closed knuckle axle be used on an open kunckle axle?
Old 01-26-2005, 08:55 PM   #14 (permalink)
Blazerman1's Avatar
Member # 3574
I have some pictures of my open knuckle dana 70 front but I can't post them, if someone wants to host them I could e-mail them to someone.
My dana 70 front is from a big front steer front wheel drive fork lift and it is the same width as a GM dana 60.
Blazerman1 is offline   Reply With Quote Quick reply to this message
Old 01-26-2005, 08:58 PM   #15 (permalink)
Member # 41097
I have a gallery i can put them up in and post it up, i sent yyou a pm with my e-mail.
Old 01-26-2005, 09:11 PM   #16 (permalink)
Blazerman1's Avatar
Member # 3574
Pictures sent
Old 01-26-2005, 09:38 PM   #17 (permalink)
Member # 41097
Here are the pictures blazerman sent me:
Old 01-26-2005, 10:04 PM   #18 (permalink)
Member # 29210
Send a message via AIM to Davethorik
I don't know about the Dodge part of that, but IH was using the D70 with closed knuckles and the large 6 lug pattern on their 1600 Loadstars and S-series trucks into the 80's, I don't think they used an open knuckle version.
EDIT: there was just a thread about this in the Chevy forum...well sorta. Some late model 3500HD trucks (that had 10 lug wheels and the extended grille) were converted by aftermarket companies to 4x4, and they used a 10 lug open knuckle D70 up front, and a D80 in the rear.
:laughing:
Davethorik is offline   Reply With Quote Quick reply to this message
Old 01-27-2005, 10:18 AM   #19 (permalink)
Member # 41097
Yeah i know about the converted chevs too, i found the website of the company that does the conversion a couple night ago, they are usually sent to firehouse's in rural/rough areas where something like this is needed.
Old 01-27-2005, 07:08 PM   #20 (permalink)
Member # 12741
The IH 1300 and 1600 from 1968 to 1978, closed knuckle came with 35 spline inner and outer, this stub was 11 1/32 long 35 spline - solid dive cap, no locking hub. steve
Old 01-27-2005, 07:40 PM   #21 (permalink)
Member # 41097
Thank you very much, it helps out a lot.
Old 01-27-2005, 11:28 PM   #22 (permalink)
Member # 33536
Steve, isnt a 1480 rated for at least 1.5 tons, i thought a 1410 was 1.25 or 1.5, so 1480 has to be at least that?? am i missing something here??
thanks
85blue4runner is offline   Reply With Quote Quick reply to this message
Old 01-27-2005, 11:38 PM   #23 (permalink)
Member # 25643
You are confusing ratings for use in the driveshaft with axle-shaft ratings. Yea, 1410 is kickbutt going into the R&P but put 5.13 torque multiplication into it and
Magnum_Willys is offline   Reply With Quote Quick reply to this message
