Need a dimension, LPD60F - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2002, 12:40 AM   #1 (permalink)
Member # 2521
Can somebody take a tape measure to a disassembled 60 front, low pinion? I need to know distance from: flat cast surface parallel with pinion, just inboard of right side (left when viewed from front) carrier bearing boss; to: the innermost edge of the inner pinion bearing bore.
So basically if you stuck a tape in the housing and jammed one end right next to the carrier bearing area of the housing, over to the the edge of the pinion bearing bore. Or, to the pinion centerline if that's easier.
Thanks, I'm trying to figure something out on this POS 61 front that the BOM number isn't helping with.
Slagburn is offline   Reply With Quote Quick reply to this message
Old 02-18-2002, 11:51 AM   #2 (permalink)
redruM's Avatar
Member # 7855
if you are trying to find out what size ring gear spacer to get call Drivetrain Direct and give them the BOM they can hook u up (they did me...(on the rear Ford 61 i have)
98TJ 4.0L, Auto, 4.0 231, 60F Detroit, 61R Spool, 4 links F&R,5.38's, Hydro, Beadlocks, TSL&Boggers
redruM is offline   Reply With Quote Quick reply to this message
