D70 locker ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2002, 07:18 PM   #1 (permalink)
Member # 4389
D70 locker ?
OK I've searched but couldn't find an answer. Does the Dana 70 take a drop in Locker (like a 14 bolt FF)? Or does it come with a new carrier? Anybody got the width of a GM duallie D70 handy?
dawhipp is offline   Reply With Quote Quick reply to this message
Old 02-19-2002, 07:39 PM   #2 (permalink)
Member # 2521
I've got the part number right here, it's E 7018
Slagburn is offline   Reply With Quote Quick reply to this message
Old 02-19-2002, 08:44 PM   #3 (permalink)
Member # 1718
Send a message via ICQ to Bigtoy22
new carrier!
Jason VanderVeen
Bigtoy22 is offline   Reply With Quote Quick reply to this message
Old 02-19-2002, 09:41 PM   #4 (permalink)
Member # 1476
it depends if it is a front or rear and if it has 23 or 35 splines!
livermore2 is offline   Reply With Quote Quick reply to this message
Old 02-20-2002, 08:11 PM   #5 (permalink)
Member # 4389
It's a rear D70 (duallie pick-up). Pretty sure a 35 spline but I'll look again tomorrow.
thanks, mossberg
Old 02-20-2002, 10:51 PM   #6 (permalink)
Member # 1476
if its a rear then yes it is 35 spline. i have one in my driveway... my dodge dulley D70 rear is 69" drum to drum. anyway all rears are 35 spline and they all will use a new carrier, but you can weld up the spiders with a tig and good rod instead.
Old 02-20-2002, 11:55 PM   #7 (permalink)
Member # 2521
Tore apart my landlord's D70 rear from 94 Dodge 2500 and it was 30 or 31 spline???
Yeah, I ran the BOM and it was a 70, what is up with this Dodge BS?
Old 02-21-2002, 12:53 AM   #8 (permalink)
Member # 1476
i didnt know Dana made a 30 spline 70 rear. well now i have to do a little research and find out more info...
Old 02-21-2002, 08:59 AM   #9 (permalink)
Member # 4737
I just bought a d70 w/ 35 spline axels and I remember being told that the 30 spline 70 are junk. But thats all I know
4x4realm is offline   Reply With Quote Quick reply to this message
Old 02-21-2002, 09:32 AM   #10 (permalink)
Member # 5021
I have a rear 70 out of a 75 E350 van. 35 spline. You can get a full detroit (new case) ARB, open diff with a lock rite, or weld it.
I will be welding mine until the gear swap and at that point if the $$$ is there I will go ARB but will probably end up with a lock rite. The lock rite in a 60 or 70 is HUGE. Should be plenty strong for my 4.0/Auto setup
Don't be "THAT GUY" on the trail.
The Rockslut is offline   Reply With Quote Quick reply to this message
Old 02-21-2002, 10:51 AM   #11 (permalink)
Member # 4737
lock rites scare me I've had a few friends with them and they seam to only last about 2 years then and with my luck the ring and pion would go with the lock rite
Old 02-21-2002, 11:51 AM   #12 (permalink)
Member # 5021
I have had lock rights in my toyota front and rear and put many miles on them, street and rocks. Then I had one in the front of my 44 in my YJ. Beat that thing along with 4 other friends with lock right front 44's. Nobody broke.
I say if you have a V8 a rear lockrite is probably not the best idea. But for $$$ reasons I will probably end up with a lockrite
Old 02-21-2002, 12:38 PM   #13 (permalink)
Member # 4737
The price on the lockrights are great and the fact that it can be installed in my own drive way would be great but i have a v8 and a heavy foot.
Old 03-02-2002, 09:35 AM   #14 (permalink)
Member # 4737
I welded mine up this week
Old 03-02-2002, 09:36 AM   #15 (permalink)
Member # 4737
another pic
Old 03-02-2002, 02:34 PM   #16 (permalink)
Member # 2756
How different is the M715 D70 from a regular dodge or whatever D70? I know it has a lower spline count. 23? But the carrier looks different from the one in the pic above. Its bolted together, i think 4 pinions? What kind of stuff is available for these axles? I have several i want to use for various stuff.
Will
NCtoy is offline   Reply With Quote Quick reply to this message
Old 03-02-2002, 02:38 PM   #17 (permalink)
flimmy's Avatar
Member # 3101
another pic
WOW thats a hell of alot of weld. I don't have nearly that much and have never broken one. I just welded the spider gears to the carrier. Looks like you welded everything solid.
flimmy is offline   Reply With Quote Quick reply to this message
Old 03-02-2002, 03:06 PM   #18 (permalink)
Member # 5510
DAMN thats ugly!!
Cutter is offline   Reply With Quote Quick reply to this message
Old 03-02-2002, 03:08 PM   #19 (permalink)
Rock Taxi's Avatar
Member # 5108
Send a message via AIM to Rock Taxi
Your not supposed to use JB Weld! DOH!!!
Ed
A Black Sheep
81 FJ40, LS2, 4L65E, Atlas 4.3, 4 link, Sunray Sun60 front and 9" rear, 42" IROK's and TWICE THE RICE!!
Rock Taxi is offline   Reply With Quote Quick reply to this message
Old 03-02-2002, 03:39 PM   #20 (permalink)
Member # 4737
My Friend has the bolted carrier with 4 pinons he was told that is the hevy duty carrier and mine in the pics is a standard carrier. My dana 70 came out from under a 1973 winabago brave (aprrox 24 foot model) and it's 35 spline 4.88. I'm junking the small dodge yoke and using a bigger chevy yoke.
Old 03-02-2002, 04:03 PM   #21 (permalink)
Member # 1802
Send a message via AIM to emsoffroad
The D70 came a few diffrent ways, most common is the 35 spline with 2 piece carrier. You can also get one with a one piece carrier, like welded above. The M715 like 23 spline. Real old ones will have something like 19 or 16 spline, found a few saw that they were course spline and cut the centers out for the gears. And I'm sure there are a few others out there.
emsoffroad is offline   Reply With Quote Quick reply to this message
Old 03-02-2002, 06:46 PM   #22 (permalink)
mj
Member # 1919
90s dodge 70s are 32 spline
mj is offline   Reply With Quote Quick reply to this message
