How strong are FJ40 axles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-26-2005, 08:19 PM   #1 (permalink)
Member # 22955
When combined with the stock drivetrain? How much can they handle when used in conjunction with a stock 2F? Are FJ60 axles a time consuming upgrade?
EDIT: Tires, Low Gears, Lockers, Axles, etc.
FordCarnage is offline   Reply With Quote Quick reply to this message
Old 03-26-2005, 08:47 PM   #2 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
If you ask in the cruiser forum that would help. Most of those guys dont venture out much.
76 and up cruiser axles ok if you add longfields and cromo inners much stronger. even with that said I would not run anything bigger than 37s. FJ60 axle swap is an easy way to gain 3 inches of width. You can grind the housing a bunch to get a pirch on the pass side or outboard the fronts. Do a search it has been covered a bunch.
KOH 2009 Team 435
KOH 2010, 2011,2012,2013,2014, 2015 Team 4431
EMC 4619 2014,2015,2016
TLCA# 5305
RustyNailJustin is offline   Reply With Quote Quick reply to this message
Old 03-26-2005, 08:49 PM   #3 (permalink)
LC Hamma's Avatar
Member # 137
IMO, they'll handle up to a 35" tire, depending on abuse. Stick an ARB up front & you're guaranteed to go Over 35", you'll need to Bobby Longify the front shafts & birfs. You can score a drum front axle usually cheap, trash from knuckles out, substitute some mini outers & call it good. There's a writeup in the tech section on Ih8mud.com
There are spring perch/ hanger issues involved here - FJ60 axles are 3" wider on one side. See link above. Birfields are your best friend
'72 FJ55 & '73 FJ40 stock...ish
'12 Alaskan Camper NCO
LC Hamma is offline   Reply With Quote Quick reply to this message
Old 03-26-2005, 09:24 PM   #4 (permalink)
88 mangler's Avatar
Member # 31780
my dad has 40 front with longs and cromo inners and stock rear. both are locked and he has a 350 and 38s and hasnt any problem beside a broke pinion. that was because it had no track bar at the time and corse spline pinion.
88YJ, d60 with some goodies&14bolt,atlas,111"wb,40"maxxis trepedors,some other stuff and 6 extra angry hampsters under the hood and a ATO built tf999!:D
tow rig: 07.5 6.7l dodge 2500
Dixon 4Wheelers
Build it, Break it,Fix it, Repeat!
88 mangler is offline   Reply With Quote Quick reply to this message
Old 03-27-2005, 05:04 PM   #5 (permalink)
Member # 22955
They don't like me in there. Thanks for the info. The one in question is a 78. I got a couple potential prospects for a new project. Whatever it is, it will get the 36x12.5 TSL that I have. If it breaks, it breaks I guess. Then I'll get the 60 axles. ARB is out of the question, I won't be able to scrape the cash together to run one. Will most likely get a lunchbox up front and Tig-locked in the rear.
Old 03-27-2005, 05:16 PM   #6 (permalink)
Member # 260
Send a message via Yahoo to woody
78 is an oddball....the knuckle on that was only produced from 76-78, so replacements can be a bitch.
I run 39.5 IROK's on my FJ40....rear was stock, now a Cruiser hybred centered with minitruck shafts, coarse pinion, cryo'd, and welded gears. Front is lunchboxed, PIG inners, chromo longs, and soon to be cryo'd knuckles and other tweaks. 350 TBI, 700R, 4:1 D300, etc...
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote Quick reply to this message
Old 03-27-2005, 05:28 PM   #7 (permalink)
Member # 22955
That's a good thing to keep in mind about the knuckles, I'm sure the thing will break. How was the rear with the 39.5 Iroks? I'm not going to go over 36" tires, but it's good to know. V8 swap may or may not be in its future. I don't know if I'll buy this one, its kinda beat to shit. I wish I could find a halfway decent one for a good price, I don't think its possible anymore.
Old 03-27-2005, 06:23 PM   #8 (permalink)
Member # 4557
Send a message via AIM to muddogbob
You're sure what will break? Woody isn't exactly easy on parts. Do a little reading and you will find that he actually wheels his junk.
'90 FJ62
LQ4, 4l80-E, 203/Split Case, 38" MTRs
muddogbob is offline   Reply With Quote Quick reply to this message
Old 03-27-2005, 06:28 PM   #9 (permalink)
Member # 22955
Give me time and I'll break any axle, never underestimate the power of an idiot's right foot. I believe him that he wheels but he also just built a hybrid rear end for what I see as obvious reasons.
Old 03-27-2005, 06:28 PM   #10 (permalink)
Moderator
Member # 8568
He breaks Toyota stuff too.
KOH 2009 Team 435
TLCA# 5305
Old 03-27-2005, 06:30 PM   #11 (permalink)
Moderator
Member # 8568
Give me time and I'll break any front end. I believe him that he wheels but he also just built a hybrid rear end for what I see as obvious reasons.
True.
I tried everything to make Toyota stuff work. I broke every time I went wheeling. Now with 1tons over a year and not a thing has broke!
KOH 2009 Team 435
TLCA# 5305
Old 03-27-2005, 06:59 PM   #12 (permalink)
Member # 22955
Honestly for the prices I see these things, I may as well go buy one of my true loves... an Early Bronco fawkers.
Old 03-27-2005, 07:00 PM   #13 (permalink)
Member # 4557
To get a centered rear axle I bet. Mini shafts have the exact same spline count/minor diameter as cruiser axles (no strength gain). Of course there are more aftermarket options than cruiser rear axle though.
'90 FJ62
Old 03-27-2005, 07:19 PM   #14 (permalink)
Member # 15163
Send a message via AIM to FJ40|RUNNER
How does the cruiser r&p compare to a minitrucks? On the trucks doesn't that seem to be the next weak link?
thanks
FJ40|RUNNER is offline   Reply With Quote Quick reply to this message
Old 05-18-2015, 12:45 PM   #15 (permalink)
Member # 102866
hey guys quick q...i have a 2 door sidekick i put 78 fj40 axles in it,its all stock motor and tranny stock case for now but a 6 to 1 coming soon.it has 35s and 4 linked front and rear..i am really hard on stuff,how long u think they will hold up with the 1.6 engine and it being kinda light?
bigfreak is offline   Reply With Quote Quick reply to this message
Old 05-18-2015, 01:37 PM   #16 (permalink)
Member # 428418
holy dead thread revival batman.. anyway, you probably won't have any issues.
I have a sami buggy on yota mini truck axles, 37s, turbo 1.6, auto and stock transfer gears. I ran stock axles for a season and broke one birf but that was 27 spline, yours will be 30. running RCVs on mine now and no issues. My brother runs longfields in his buggy with fj40 axles on 38.5 TSL's. only broke a course spline pinion so far, one of their weak points. He is also running a turbo 22re.
dropitlow88 is offline   Reply With Quote Quick reply to this message
