Anyone ever f**k up tapping thier box???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2005, 08:33 AM   #1 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
this is just great. had a buddy bring me his "tapped" box last night wondering how we could fix it. this is a factory jeep box, drilled/tapped per the billa tech article.
drill locations are perfect.
heres the problem. top/side hole is oval, "threads" only worked on 2 sides of the hole.
both holes the threads are fucked. tap must have been reaaaaaaaaaallll buggered up.
so i need to drill this out larger and re-tap. what im thinkin is drilling it out to fit an 1/2-something helicoil. then coiling it. then going to a male/male adapter from 1/2-something to 1/4 npt. then haveing hoses made to fit the 1/4npt.
anyone see a problem with this??
anyone had to fix a similar problem?? how'd ya do it?
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 08:39 AM   #2 (permalink)
Member # 131502
I screwed up my first one. I ended up getting another box and using a press and a vise to get the hole strait.
Maybe you could go to the next size up. I've had mixed luck on getting the coils to seal under pressure.
Frozen ZJ is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 08:40 AM   #3 (permalink)
Member # 22955
Drill it out bigger and use a thread insert maybe. With teflon seal it should hold alright.
FordCarnage is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 08:43 AM   #4 (permalink)
Member # 4783
NPT threads are tapered and they seal on the threads, so coils don't work well. Make sure that the tap was run deep enough into the hole to completely cut the threads. If it has been tapped properly and the threads are still bad, just move up to the next bigger size NPT fitting.
Pin Head is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 09:06 AM   #5 (permalink)
HeyBeerMan's Avatar
Member # 4830
Why not go 1/2" or 3/8" npt to -6AN or what ever size AN you need?
beerman
HeyBeerMan is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 09:14 AM   #6 (permalink)
Member # 20092
beerman
+1. that could work nicely and salvage the box.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 09:23 AM   #7 (permalink)
YJ4RoX's Avatar
Member # 1930
I agree redrill/tap for 3/8NPT then adapt the the AN fitting you need.
3/8 NPT-37/64" drill size.
YJ4RoX is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 09:48 AM   #8 (permalink)
GloNDark's Avatar
Member # 2482
I say plus size the whole/tap. I tried the helicoil option and it never sealed properly. Held just fine but would always leave a little puddle under the truck after sitting for a day or 2
BUILD THAT FUCKING WALL!!!
GloNDark is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 11:38 AM   #9 (permalink)
SpineTx's Avatar
Member # 1499
tapping box
My wife says I'm always f-ing up tapping the box, But I'll be damned if I let someone else re-drill and tap it for me.
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 12:09 PM   #10 (permalink)
JeepinDoug's Avatar
Member # 13028
X10 on the over tap and AN reduction.
I may lack much in way of integrety but I make up for it with pure denial.
JeepinDoug is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 12:15 PM   #11 (permalink)
Member # 30038
just get a couple female pipe fittings, and weld them to the box over the holes.
I never liked the dril tap method, there is not much material there to thread.
wheelsup is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 03:49 PM   #12 (permalink)
Member # 8815
Yup,fit the fitting in there the best ay can and weld that sucker on there.Works great and saves the box............
2009 Single seater rear engine buggy on rockwells.Well thats when I should finish........
mudddog91 is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 10:29 PM   #13 (permalink)
Magoo's Avatar
Member # 10128
The tap didn't make the hole oval, the person drilling did.
+1 for going up in size for the NPT.
Work harder, millions on walfare depend on you.
Magoo is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 12:03 AM   #14 (permalink)
Member # 14437
3/8th NPT should do the trick. You can get 3/8-1/4 NPT adapters easily and use an off the shelf 1/4 hose and you're set.
freds40 is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 12:53 AM   #15 (permalink)
Dan Dibble's Avatar
Member # 12695
I have seen them welded on.
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops!
Dan Dibble is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 06:38 AM   #16 (permalink)
cheaprides's Avatar
Member # 40933
Send a message via AIM to cheaprides Send a message via Yahoo to cheaprides
do you have enough room to plug it and move over a little?
slow the drill down and get a sharper bit too
but i also like the weld on idea for more material
cheaprides is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 06:46 AM   #17 (permalink)
Member # 16045
Welded fittings
Dan
That's how PSC does theirs. They also sell the steel fittings on their site. I've got a stock TJ box if your buddy wants to start over. KC has my number if you want it.
Dave T.
Land use, not land abuse!
dotrappe is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 09:51 AM   #18 (permalink)
Banned
Member # 24704
Not sure about you guys, but I use 3/8" hoses. My box is tapped 1/4" NPT, though.
First, I'd try grinding the first few threads off the bottom of the tap and making a, "Bottoming" tap of sorts and tapping again. I've had mixed luck with this where there is no other option, just don't grind too many threads off or you'll end up with a hole so big you can't get a fitting to seal on the threads.
If that fails I'd go to 3/8" NPT, drilled/tapped correctly this time.
Tim84K10 is offline   Reply With Quote Quick reply to this message
Old 05-14-2005, 12:31 PM   #19 (permalink)
Member # 12499
Use a sharp bit and a drill press, go next size larger and away you go.
PTSchram is offline   Reply With Quote Quick reply to this message
