Educate me on front 60's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-28-2005, 03:55 PM   #1 (permalink)
FearMe's Avatar
Member # 1565
I need some interchange and general info on the various front 60's.
I want to find out which models and years of front 60 yolks and knuckles are interchangeable. GM to Ford to Dodge etc. What king pin style parts will interchange, ball joint styles and spindle interchange etc.
Thanks.
I've outlived my dick.
FearMe is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 04:05 PM   #2 (permalink)
Bushwhacker's Avatar
Member # 9138
Send a message via ICQ to Bushwhacker
Might try the Dana 60 bible in the Tech section.
WEROCK Judge
RROCK Legends Competitor
97 TJ buggy,4.0,727,Atlas,D60,14B
Bushwhacker is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 04:12 PM   #3 (permalink)
Member # 25697
FearMe
Probably your Dad
Member #1565
I hope your joking!
72 FJ40
VinSil is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 04:13 PM   #4 (permalink)
FearMe's Avatar
Member # 1565
Might take that For Sale ad and put it in the for sale section.
Old 07-28-2005, 04:16 PM   #5 (permalink)
FearMe's Avatar
Member # 1565
Originally Posted by VinSil
FearMe
Probably your Dad
Member #1565
I hope your joking!
Nope. Just because most people on the board know everything doesn't mean we all do.
Old 07-28-2005, 04:40 PM   #6 (permalink)
Member # 25697
Not to be a smart ass (and yes, I did think it was a joke )
but 5 years and you haven't seen this part of Pirate4x4.com?
https://www.pirate4x4.com/tech/
Enjoy!
72 FJ40
Old 07-28-2005, 05:19 PM   #7 (permalink)
FearMe's Avatar
Member # 1565
I did enjoy it. Thanks for pointing it out the search I did, didn't.
Great info on the king pin knuckles. How about the ball joint style? That search didn't turn up anything either.
Old 07-28-2005, 06:05 PM   #8 (permalink)
mj
Member # 1919
try asking a question that is a bit less vague.
mj is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 08:54 PM   #9 (permalink)
Member # 42509
Screw the balljoints, they're crap, you want kingpins, end of story.
broncobuster37 is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 10:52 PM   #10 (permalink)
BossBuilt's Avatar
Member # 1760
If you all don't have answers to the question why do you clutter the thread with your B.S.??
BossBuilt is offline   Reply With Quote Quick reply to this message
Old 07-28-2005, 11:20 PM   #11 (permalink)
onetoncv's Avatar
Member # 2160
just remeber to set castor correct on the king pin and you will be happy- oh yeh stay away from the dodge 60 its a wierdo- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 01:43 AM   #12 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
Whats weird about Dodge D60s
I have several of them sitting at the shop. They have the external lockouts , heavier, stronger inner castings, and GM style knuckles.
The right side perch is cast inot the housing, with two studs for securing the spring plate.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 05:29 AM   #13 (permalink)
Member # 36383
because of this:
Front Dana 60. This monster is some 66 pages long, and contains just about everything there is to know about Dana 60 Front Axles. Sections include description, identification, dimensions, specifications, pictures, Bill of Materials listings, parts interchange, assembly specifications, yokes, gears, lockers, axle shafts, bearings and seals, lockout hubs, u-joints, as well as technical facts, how-to articles, and a HUGE FAQ. Updated frequently.
Link
JoshH is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 08:38 AM   #14 (permalink)
FearMe's Avatar
Member # 1565
Partially correct buckwheat, but I was still asking about the ball joint style and other than the usual "Hell no don't use those" I got NO info on them even in Bella Vistas great write-up. Have you got some useful information or just another mouthfull of bullshit?
Old 07-29-2005, 10:13 AM   #15 (permalink)
welndmn's Avatar
Member # 398
I know there were at least 2 versions of Ford Ball joint kunckles, I have seen one with cast in brake caliper mount, another with out.
Mark
Old 07-29-2005, 10:39 AM   #16 (permalink)
Member # 7703
WTF....So you are saying that the Unit Bearing stuff that.....well.....most moon buggy competitors are running is crap? They are ball joint style. We run them on our car and have had zero problems. So just clarify before you say what sucks and what doesn't.
#59 Toyo Tires/Outer Limit Motorsports
ohmscj is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 11:41 AM   #17 (permalink)
FearMe's Avatar
Member # 1565
Thanks Mark. Did one of the ball joint style come with the standard spindle and bearing set-up, not the unitized one? What years? And will the king pin knuckles of either fit a unitized yolk? They should be the same but I don't know for sure. I've got unitized knuckles but I'd like a more conventional set-up cause it's cheaper. I can always carry a spare unitized set but bearings seem easier.
Old 07-29-2005, 11:43 AM   #18 (permalink)
FearMe's Avatar
Member # 1565
Where is the best, and as usual, the least expensive place to have the unitized bearing machined to accept 35 spline stubs and 5X5.5 bolt pattern? Someone mentioned Currie but are there options?
Old 07-29-2005, 12:40 PM   #19 (permalink)
Member # 17777
front 60 5 on 5.5
Why would there be hardly any call for this setup? I know it can be done, but why is it done? Any rig that feels the need to be running a front dana 60 should be at least running a rear 60, or bigger, and if that's the case it's a ton of work and money just to not have to change wheels. The only way I could see that it would be useful to convert a front 60 to 5 on 5.5 is if you already have a rear semi floating 60 at 5 on 5.5, or some tricked out 9" in the back. I mean really, if you're looking at a front 60, you should be looking at a rear 70 or 14 bolt, so why not just run all 8 lug anyway?
jwjeep1 is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 01:23 PM   #20 (permalink)
FearMe's Avatar
Member # 1565
Because I have a really cool set of chrome with spinner centers 5X5.5 wheels that I want to keep using.
Old 07-29-2005, 02:31 PM   #21 (permalink)
Member # 17777
OK, to each his own... I don't want any wheel on my rig that I have to be worried I'm gonna mess up. I guess it looks good in the mall parking lot though huh.
Old 07-29-2005, 03:39 PM   #22 (permalink)
FearMe's Avatar
Member # 1565
Thanks for that. Not all 4 wheelers are hard core big dogs some of us just like the look and a clean rig.
Old 07-29-2005, 05:20 PM   #23 (permalink)
Keith's Avatar
Member # 52
my 97 f350 has ball joint but no unit bearing
Keith is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 05:58 PM   #24 (permalink)
Banned
Member # 24704
Those are called mall crawlers and they don't often ask about Dana 60s.
At least all you're wasting is a crappy balljoint one that nobody wants anyway.
Tim84K10 is offline   Reply With Quote Quick reply to this message
Old 07-29-2005, 06:05 PM   #25 (permalink)
Member # 41147
unit bearings were 99-up on fords.balljoints showed up in 92.
st ranger is offline   Reply With Quote Quick reply to this message
