D60 rear strength - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2005, 11:09 AM   #1 (permalink)
Member # 49226
Send a message via AIM to southernkrawler
D60 rear strength
The 60 in the rear of my Heep right now has 4:56 gears, Detroit, disks, the whole 9 yards, and Im swapin out the front HP 44 for a HP 60 and i want to run 39 iroks then mabe in the future 42 iroks, would the rear hold up to those sizes, I have a 14 bolt, but I was just trying to figure out the best route, and Im swapin in a FI 318 V8/ Auto/D300
southernkrawler is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 11:17 AM   #2 (permalink)
fcfred's Avatar
Member # 3263
is it high pinion?
it should be fine, but anything can be broken
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 11:22 AM   #3 (permalink)
Member # 49226
Its low pinion
Old 10-28-2005, 11:29 AM   #4 (permalink)
JackA's Avatar
Member # 2129
What axle shafts are in the? If it's the 30 splines, it's time to upgrade.
2013, 2012, 2011 ASCC Ultra4 Class Champion, 21st place KOH 11, 20th place KOH 10, 16th place KOH 09, 9th place KOH 08
Huge thanks to Ballistic Fab, ADS shocks, Pro Diesel, Bulldog winch, Desert Rat Off Road Centers, BFG Tires and all my friends and family
JackA is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 11:43 AM   #5 (permalink)
GiS
GiS's Avatar
Member # 31285
30 spline wont cut it....Broach and run 35 if ya want it to live.
-Joe
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 12:29 PM   #6 (permalink)
Member # 49226
Would it be cheaper and easier to just build the 14 bolt, I was going to spool it instead of a locker this time and would 4:56 be good fo 39.5s to 42s
Old 10-28-2005, 12:30 PM   #7 (permalink)
Member # 49226
And yes it is 30 splines
Old 10-28-2005, 01:48 PM   #8 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Dana 60 rear, 35 spline mosers, 4.56 gears, and detroit locker. I've been running that setup for six years, several of those years under a 5000lb or more Wagoneer with a 300hp 360 and 38.5 Baja Claws. On steel wheels they weighed 140lbs each. Now I'm running 42 Iroks on a buggy with success. It'd probably be cheaper to build the 14 bolt but chevy stuff can lick my nuts so I went with the Dana 60.
https://
https://www.facebook.com/diddysbigblockraceshop/
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 02:17 PM   #9 (permalink)
GiS
GiS's Avatar
Member # 31285
Southern, its a tough call...If you switched to 14B you would have to do gears, locker and disks all over again, if you switched your 60 to 35 spline, you could retain the disks, but your still messing with locker and gears...
If you were picking up a diff and JUST starting the build...14B all the way.
-Joe
Driver: Joey Weber
Old 10-28-2005, 07:01 PM   #10 (permalink)
Corn_Smuggler's Avatar
Member # 28766
Southern... at LKQ here in Orlando, they have some 14 bolts that they want $80 complete; or if you catch the place over in Daytona on the right day, they are $20. I went 14 bolt and my buddy and I shaved a little off the bottom with a porta-band. Lockers for the 14B are even cheap if you went that route... I had a quote from DC4wd for 5:13's, Master Install Kit, and Detroit for $600 to the door; weld it up and you come out even cheaper...
I had a choice starting from scratch (D60's still in the garage) and I went 14B because of strength -vs- cost.
.02
-Dan ('63 Willys CJ5)
Corn_Smuggler is offline   Reply With Quote Quick reply to this message
