why not the swivel frame? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-22-2002, 04:53 PM   #1 (permalink)
Member # 1899
Location: Tacoma, Wa Where you can drink the water, but don't breath the air
Arrow why not the swivel frame?
It's a 50's Dodge Power Wagon with a Willock swivel frame, made in Canada.
stolen from JU
What?
HighHooder is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:09 PM   #2 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
thought about it... but i couldnt work out how to deal with the rear driveshaft. i finally figured that the swivel would have to be as close as possible to the TC output to eliminate weird angles. i still may attempt to build one someday, but not this year!
road1will is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:11 PM   #3 (permalink)
GloNDark's Avatar
Member # 2482
Where would the drivetrain go? Does the rear drive shaft go thru the "Swivel"?
BUILD THAT FUCKING WALL!!!
GloNDark is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:34 PM   #4 (permalink)
Member # 7646
no why whould it
if you out put is directly center so your drive shaft is directly under the swivel ther should be no problem
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:37 PM   #5 (permalink)
DUG
DUG's Avatar
Member # 858
Send a message via AIM to DUG
The drive shaft runs just like normal. with the Piviot near the transfercase output it would piviot so close to it that it would not really be an issue.
The axle is pivoting around the center much like when the axle articulates the rest of the time.
Of course like anything else it does have it's limits.....
Be yourself, by yourself.
DUG is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:37 PM   #6 (permalink)
GloNDark's Avatar
Member # 2482
Originally posted by Chief Yelling Alot
no why whould it
Sorry, I was thinking shorter wheel base such as mine is now. 100 inch wheel base and taking probably 8 to 10 inches of that with the swivel portion, no way it would work with my current set up.
But longer wheel base like the pics above....hhmmmm
What what it drives like on the highway? Would it lock in place? hhhmmmm
Old 03-22-2002, 05:43 PM   #7 (permalink)
Member # 5832
hey, cool find Hooder!
there's a guy building up a rig somewhere in the Suzuki section here(i think..... ) that has mounted his front shackle mounts on a swivel frame run horizontally across under the front bumper more or less- looked much like this (in it's own way) very neat looking though.
UZI 9mm is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:50 PM   #8 (permalink)
Member # 256
well if you were building it your self
I see no reason why you could not run a
shaft thrue the swivel point.
Land Crusher is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 05:52 PM   #9 (permalink)
Member # 4073
There's a rig here similar to that. The torque would sometimes lift a front wheel on that thing.
Dustin S.
I had a brain-eating disease that died of starvation.
Dustball is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 06:07 PM   #10 (permalink)
Member # 4406
I remember seeing a kit like that a few years back in one of the mags (Peterson's?). The big problem I see is that there is really no suspension. If I were to do something like that, I think I'd want a big torsion spring between the two sides. A lock for the highway (if applicable) would be a good idear, too.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 06:31 PM   #11 (permalink)
TR
TR's Avatar
Member # 2877
That is the thing you say in pertersones. Dustball do you have any more pics of that thing?
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 08:15 PM   #12 (permalink)
Member # 2029
a lockout would be a good idea for street driving.
Soni Honneger(sp?) maker of the scorpion rigs, has a twisting subframe, i like his because of the way the suspension is tied together acting like a torsional equlizer of sorts.
seems like a two peice frame like the one pictured would be very unpredictable, wich could explain the pre-production disapearance.
75 BDJ55
get inline, you'll be fine.
RHINO is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 09:02 PM   #13 (permalink)
Member # 3511
That's the green monster sitting at the farm in chaska isn't it? I drive past that thing everyday, never got close enough to see that it had a swiveling frame.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 03-22-2002, 09:38 PM   #14 (permalink)
TNToy's Avatar
Member # 5776
*snap!* ... "Oh shit... what the hell do we do now???"
Old 03-22-2002, 09:59 PM   #15 (permalink)
Member # 10729
Just like Gamma Goats
Gamma Goats were discontinued from the army because they liked to tip over a lot!! They act like a whip. If you could add some type of torsion to it like the Scorpion it might work but otherwise you would need a round cage so you could flip back on you tires!! LOL. I think the green truck is a bogger from missouri. Named sumpin Dragon or sumpin
72zebra is offline   Reply With Quote Quick reply to this message
Old 03-23-2002, 01:44 AM   #16 (permalink)
Member # 4073
I don't know where the owner lives but I did take the pic while at Mud and More in Buffalo. Here's another pic of it-
Dustin S.
Old 03-26-2002, 10:40 AM   #17 (permalink)
m715's Avatar
Member # 2235
Nice pictures, that's pretty cool
You could run the brake lines, gas lines & wiring all bundled just below the pivot point
Driveshaft can run just about normal
Where do you run the exhaust?
I guess you could go with stacks behind the cab
Anybody have some more pictures? I seem to remember seeing some oil rigs that had a similar pivot point...
1977 CJ7 Chevy 327 and some other stuff...
1968 M715...Under Construction
m715 is offline   Reply With Quote Quick reply to this message
Old 03-27-2002, 05:25 PM   #18 (permalink)
Member # 5510
from the Jeep forum...
Cutter is offline   Reply With Quote Quick reply to this message
Old 03-27-2002, 05:26 PM   #19 (permalink)
Member # 5510
1
Old 03-27-2002, 05:28 PM   #20 (permalink)
Member # 5510
u
Old 03-28-2002, 06:52 AM   #21 (permalink)
Member # 9425
Send a message via Yahoo to bigshawnf
I don't have picture posting ability so here's a link. It's worth going to cool stuff to read about it.
http://www.truckworld.com/Monster-Tr...antanimal.html
Pretty amazing "monstertruck". All hydraulic 460 Ford motor (bored to 495) no tranny, no transfercase, no driveshaft, no ujoint, no suspension, no steering linkage, no front or rear drive shaft. Can turn 360 degrees in its own wheelbase (it's 20 ft long). Can do wheel stands all day long and turn 360 when it is.
Oh and swivel frame.
bigshawnf is offline   Reply With Quote Quick reply to this message
