Member # 3781
1410 Yoke for Square Driveshaft Part Number
Searched and came up empty handed.
Anyone built a square driveshafts using 1410 yokes? Looking for a part number for one that would be good for this application. Thanks
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Member # 15400
No help but I am going to build the same thing
![]() I'll let you know if i find out a number or something that works.
92 YJ, 383TPI,700r4,60's Last edited by rls270; 12-15-2005 at 06:38 AM. |
Sponsored Links |
Member # 2160
The 2 1/2 .156 wall tube yoke is a 3-26-437 - hope this helps- there's also a 3-28-327 but its kinda expensive- 2.500 .095- Jess
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Also see us on facebook @ High Angle Driveline 530-877-2875 |
#5 (permalink) | |
Member # 3781
Can you pm me a price for two of those yokes?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by pmaddy; 12-15-2005 at 09:51 AM. |
Member # 2160
well my pm is turned of -the 3-26-437 is 39.00 - each- Jess
Member # 1700
my rear drive shaft is the stock shaft that runs between the two rear axles of the 2.5 ton. trhey use flanges so i just took the flanges off of them (i run standard 1410 yokes on my t-case and rear end) and used them. it was not as easy if i would have had say a slip yoke off of a drive shaft but after some welding and plating they worked fine. i beat on them hard and they held up. i broke 4 th400 cases while running a square front shaft and i have since switched to a round shaft from high angle. i read that higher HP rigs ( i run v8 and 42's) can cause problems when running a square shaft and several people have had breakage issues with tranny cases. anyway i switched in hopes that the breakage issues will stop. i have not run the new shaft long enough to say for sure my issues is fixed though.
High5 IT'S 1TON O' FUN! |
Thread Tools | |
Display Modes | |
