Currie HP 9" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-16-2005, 07:57 PM   #1 (permalink)
srscout's Avatar
Member # 47067
Currie HP 9"
Hi Guys
I have been looking at the Currie High Pinion center section for my crawler and have a few questions if anyone has used it.
What housing mods are necessary to use the 35 spline shafts?
Second is gears. Are the R&P gears something Currie has custom made or are they a factory item?
Any other info would be greatly appreciated as well as comments from anyone who has used one.
Thanks
srscout is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 08:00 PM   #2 (permalink)
srscout's Avatar
Member # 47067
BTW I guess I should have noted that this is for a rear end not a front.
Old 12-16-2005, 08:06 PM   #3 (permalink)
Member # 17313
the 3rd member is a currie unit, but the gears are just factory ford HP 8.8" gears.
Your much better off just getting a true high 9
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 08:08 PM   #4 (permalink)
shopteach's Avatar
Member # 54135
they make a case just for the 35 spline shafts, gears are ford 8.8 reverse gears from an expedition (or something). I have built 2 different 35 spline hi 9 rears and they work great (up to 37" tire)
shopteach is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 08:18 PM   #5 (permalink)
srscout's Avatar
Member # 47067
What is a true high 9? I thought the Currie was the only game in town for a HP 9"
Old 12-16-2005, 08:41 PM   #6 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
How about searching for "true hi 9".
Bunk is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 08:42 PM   #7 (permalink)
Member # 10736
www.truehi9.com i wouldn't waste money on the currie hp. the true hi 9 is what i would get.
masonmachines is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 09:20 PM   #8 (permalink)
Member # 33830
Technicly, True Hi-9 IS the only game in town since Currie's so called hi pinion "9 inch" center section uses 8.8" gears as mentioned previously.
mad_boi is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 09:39 PM   #9 (permalink)
jgarden1's Avatar
Member # 584
There is nothing wrong with Currie "hi 9" if you use it as intended, which I believe according to them is up to 35" tire. If you really want to pound your rig and you are running high HP and large tires, then you will want the true high 9 or RC 60.
jgarden1 is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 10:07 PM   #10 (permalink)
BIGWOODY's Avatar
Member # 25935
Just got one, two thrust blocks, solid spacer and forged yoke..
Jimmys 4x4 buggy
BIGWOODY is offline   Reply With Quote Quick reply to this message
Old 12-17-2005, 08:28 AM   #11 (permalink)
srscout's Avatar
Member # 47067
I had never heard of the "true hi 9". I didn't know if that was the name of something or a referance to a type of centersection.
