2X8X1.125 Ram, what Orbital for 2.5 turns? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-19-2005, 06:24 PM   #1 (permalink)
Member # 63225
I need an orbital that will do about 2.5 turns on the slow side with a 2 inch bore, 8 inch stroke, with an 1.25 diameter rod/shaft. Anyone got orbital part numbers or how many c.i. flow such an orbital is?
TeenyCAR is offline   Reply With Quote Quick reply to this message
Old 12-19-2005, 06:51 PM   #2 (permalink)
Member # 1636
whats the flow and gpm on your pump?
chris demartini is offline   Reply With Quote Quick reply to this message
Old 12-19-2005, 07:10 PM   #3 (permalink)
Member # 1636
I calculated using my GM pump (1400 psi around 3.5 gpm). With a 7.5 cu/in per revolution valve you will be 3.3 turns right and 2.0 left.
Someone correct me if I'm wrong
Old 12-19-2005, 07:12 PM   #4 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
As long as it can keep up, what does it have to do with the orbital? I have a 6.0 CI displacement orbital and it's about what you're talking about. 2 Revs one way and 2.5 the other.
desertCJ is online now   Reply With Quote Quick reply to this message
Old 12-19-2005, 07:18 PM   #5 (permalink)
Member # 1636
I guess I need to play with the calculator more
Old 12-19-2005, 07:20 PM   #6 (permalink)
desertCJ's Avatar
Member # 9026
For what it's worth, I would go with a 7.6 CI valve if I could with that cylinder.
Old 12-19-2005, 07:25 PM   #7 (permalink)
Member # 63225
The pump is 1600 psi and 4.5 gpm, from PSC.
