welding to rims technique? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2006, 12:05 PM   #1 (permalink)
another Lance's Avatar
Member # 26077
Send a message via AIM to another Lance
is there a special way to weld a ring to a rim lip to avoid warping or are they thick enough to just weld away?
Originally Posted by John F. Kennedy
Today, we need a nation of Minutemen, citizens who are not only prepared to take arms, but citizens who regard the preservation of freedom as the basic purpose of their daily life and who are willing to consciously work and sacrifice for that freedom.
another Lance is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 12:26 PM   #2 (permalink)
Member # 6803
Weld away!
Mig-Arc-Tig-Oxy Acet....What ever you have will work.
Geargoyle is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 01:03 PM   #3 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
center it realy nice, tack it so it dont move. weld the bitch.
I do a few inches and then switch sides just in case
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 01:06 PM   #4 (permalink)
Budd's Avatar
Member # 28368
That is what I did on the last set - tacked in four places - then in between each tack laid down 2-3 inches and then rotated until done.
I did it in my carport with a wooden chair and stacked a couple rims to get a comfortable height - next time I will put a welding blanket over my pants.
'68 Jeepster, GN powered
Budd is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 01:18 PM   #5 (permalink)
Member # 12414
Your not welding until you are on fire.
Team Devil Frogg
Kettering, Ohio
GPERX4 is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 01:24 PM   #6 (permalink)
crawldaddy's Avatar
Member # 50098
[CENTER][FONT="System"][SIZE="5"][COLOR="Orange"]Copperhead Fab[/COLOR][/SIZE][/FONT][/CENTER] [CENTER][SIZE="3"][FONT="Arial Black"][COLOR="Red"]MY BUGGY BUILDS[/COLOR][/FONT][/SIZE][/CENTER] [CENTER]
[/CENTER]
[CENTER]
[/CENTER]
crawldaddy is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 01:37 PM   #7 (permalink)
usmcdoc14's Avatar
Member # 13344
I took an extra spindle and hub and placed them on the ground and set the rim on it and had a perfect little turntable Sitting on a milk crate next to it was the perfect height to set my pant cuffs on fire
Old 01-12-2006, 10:50 AM   #8 (permalink)
Member # 26077
should I weld the backside of the ring too?
Old 01-12-2006, 10:55 AM   #9 (permalink)
Budd's Avatar
Member # 28368
I guess that depends on the kit you have. Mine set inside the lip of the rim - thus preventing welding the back in any practicle way.
Old 01-12-2006, 11:08 AM   #10 (permalink)
Member # 26894
The most important thing I have found about welding these is the prep work. You have to make everthing nice and clean. Leaving paint on the rim in the area your attemping to weld to is a prime recipe for pin hole air leaks in your welds.
I have never had any of mine leak, but that is because I have a sandblaster in the shop and I usually blast the rims off before I weld to them.
I had a buddy who just kinda half ass grinded the area so he could get a ground when he welded up his rims. He was chasing leaks for 2 months.
Smash-K20 is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 11:13 AM   #11 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
Solution...
Summit
4 rims
15 x 8
8 on 6.5 bc
raw unpainted
167.10 shipped to my door
As of Tuesday January 10, 2006
EDIT:
Thanks for asking the question...I will be welding mine up in the next week or two. I have searched, searched, and searched some more...and it appears from that that you really can't fuck it up. Straight welding or stitch method ends up the same...That as mentioned the prep work is what yields the best set up.
Hence just starting with brand new, TRUE and clean non-painted rims...
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 11:15 AM   #12 (permalink)
Myanarchy's Avatar
Member # 14059
JB weld. Be a trend setter
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 11:45 AM   #13 (permalink)
Member # 26894
Originally Posted by Harvester of Sorrow
Solution...
Summit
4 rims
15 x 8
8 on 6.5 bc
raw unpainted
EDIT:
Even though they are new it would'nt hurt to take a wire wheel on a grinder and remove the mill scale from around the bead area where you are welding. The cleaner the better is my motto.
Old 01-12-2006, 11:47 AM   #14 (permalink)
Member # 28652
When I welded the inner rings on my wheels ( the rings sat on the wheel lip ) I ground a small chamfer on the wheel lip and on the ring giving a nice little V groove to lay the bead in. Then I tacked in four spots 90* apart and welded in two inch incraments 180* apart from each other on the O.D. only, It worked well enough not to leak.
Spaceman Spiff is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 02:16 PM   #15 (permalink)
AthlonAJ's Avatar
Member # 10462
Shop I used to work at had a cool homebuilt setup for welding rims and anything round. Used a variable speed router controller on an electric motor, two pulley setup to reduce the speed down. The 2nd pulley had a shaft on it which you could place various fixtures depending on what you were welding. For instance he had a fixture for nearly every bolt pattern of rim, ones with hold down clamps for other pieces... Anyways, slap the rim on, tighten it down and put the MIG gun in the holder. This holder basically is a rest for the MIG nozzle to hold it at a set angle and distance in relation to the weld area. It takes a little bit to get everything setup as far as the speed of rotation, heat and wire speed. But DAM once you do you can blast through them in no time. But the nice thing is the weld consistency is incredible.
AthlonAJ is offline   Reply With Quote Quick reply to this message
Old 01-12-2006, 02:36 PM   #16 (permalink)
Member # 26077
that would be nice but mine won't be welded a full 360, there are notches every few inches in the ring
