3rd member and locker ID: WTF is this thing? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-17-2006, 07:29 AM   #1 (permalink)
Member # 8203
I was told this came from an 82 toyota, but does not look like any toyota diff.
there's some sort of traction adder in it, I don't know if it's factory or aftermarket, but the fact that the housing for it is sand cast instead of machined makes me think it's a factory item, but what do I know?
careful: big pics
http://www.dana60.com/sundowner/diff2.JPG
http://www.dana60.com/sundowner/DIFF1.JPG
here are the specifics:
it's bigger than a toy pig, a lot bigger
the ring gear has a total outer diameter of 8.5"
both bearing caps are embossed with D3048
there are 10 holes in the flange for the pig to mount to the housing.
there are no screw adjusters for the carrier bearings, I can see that the carrier bearings are shimmed from the inside like a dana axle.
there are no other markings on the case indicating who made it (argh.)
super cool turbo 4runner
Sundowner is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 07:47 AM   #2 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
eaton?
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 08:04 AM   #3 (permalink)
Member # 8203
Originally Posted by sceep
eaton?
maybe.
I forgot to mention that the ring gear bolts are graded at 10.9(metric)
might be eaton if they made drop-outs after most ofthe OEM's went metric.
could it be something like a Nissan or a Rover?
gear ratio is 4.56:1
Old 01-17-2006, 08:43 AM   #4 (permalink)
Member # 192
Can you get a better pic of it? I can't tell if it is an eaton by the pic
brector is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 08:49 AM   #5 (permalink)
Member # 31711
That is not an eaton. It looks like one of the axles in one of the dually toyota U-Haul trucks.
Rob
robsjeepyj is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 09:15 AM   #6 (permalink)
Member # 8203
Rob
this says the toyota dually's were 8" ring gear likes the std. 4x4 drop out.
http://www.sr5.net/dually.htm
Old 01-17-2006, 09:17 AM   #7 (permalink)
Member # 65517
Rob
also what i was thinking.
OneTonRav4 is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 09:20 AM   #8 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
not to hijack.. but.. i wanna see pics of this "onetonrav4"
gotta build thread somewhere?
Old 01-17-2006, 09:22 AM   #9 (permalink)
Member # 192
I missed something, it is not an Eaton. I have not seen an eaton with a pinion flange
Old 01-17-2006, 09:53 AM   #10 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
Isuzu 12 bolt ?
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 10:37 AM   #11 (permalink)
Member # 38563
It has to be out of a nissan or LR, definately not yota, the flange is very different from a yota flange, the inner diameter is too large where the driveshaft bolts to, plus the webbing is different from both a 4cyl and turbo/v6 diff housing
a dually yota 1ton rear has the same pig as a turbo/6ycl one
84' M1031 CUCV 35's
84' Suburban 2wd to 4wd on tons, 8.1 4L80e NP205, 35's
Pietro is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 11:09 AM   #12 (permalink)
Member # 8203
I've been looking for pics of different 3rds,
but the rover 3rds have an external pinion bearing support like a 14b or a ford, so they're not options, and the nissan 3rds have screw-in carrier bearing adjusters with lock pins like a toyota, so they're out.
I'm trying ot find pics of an isuzu 3rd.
Old 01-17-2006, 12:22 PM   #13 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Rover third is smaller than a toy third..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 01:05 PM   #14 (permalink)
Member # 11072
I say nissan patrol.
redrangie is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 01:08 PM   #15 (permalink)
Member # 347
Originally Posted by usmcdoc14
Isuzu 12 bolt ?
Doc nailed it -- that's an Isuzu 12-bolt casting, you can tell by the way the carrier main bolt pockets are merged into the top wrap-around rib. Looks to be an early-ish one, as well, since there is no sensor bunged into the top. 4.56 is a common stock gear ratio. It is bigger in every dimension than a Toyota 8-inch or Dana 44, FWIW.
Here's an article with some pix:
http://www.4x4wire.com/isuzu/project...dtrooper/ARB/?
That looks like the factory clutch-drive limited slip. That might have some value to the right fella.... the diff itself isn't very marketable to someone without an Isuzu axle to stuff it into.
Randii
[B]
[/B]... you pick up after your dog, so clean up after YOU, too.[I][SIZE="1"]
- [B]VIRTUAL RALLY[/B] for the HAMMER TRAILS in JOHNSON VALLEY
- [B]VIRTUAL RALLY[/B] for TELLICO
and
- [B]KOH Pledge Drive:[/B] for
[/SIZE][/I]
randii is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 01:16 PM   #16 (permalink)
usmcdoc14's Avatar
Member # 13344
Randii
I just did not feel like crawling under the Amigo to verify my guess
http://www.4x4wire.com/isuzu/project...B/Ex000047.jpg
and
you can see the "unibrow" rib
Old 01-17-2006, 01:55 PM   #17 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Talking
me too!
Bryan 'Opie' Bennett
Wanna be rock crawler guy #91 in a Blue XJFireWallBuggy.
XJ_ranger is offline   Reply With Quote Quick reply to this message
Old 01-25-2006, 01:24 PM   #18 (permalink)
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
it's an isuzu Corp. 12 bolt rear 3rd with a limited slip unit......Non ABS, 4.56 ratio. came out of a '93 ish trooper
here's one that is sitting on the bench in my shop:
Matt, Owner: Independent4x
804-550-0480: 9am-6pm EST
UFWDA Life Member -
[FONT=Verdana]
[B][I][COLOR=DarkOliveGreen][SIZE="2"] Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM [/SIZE][/COLOR] [/I] [/B] [/FONT]
Independent4x is offline   Reply With Quote Quick reply to this message
Old 01-25-2006, 01:27 PM   #19 (permalink)
Member # 8755
oh, and if you don't want/need it.....PM me i can use it. thanks
UFWDA Life Member -
[FONT=Verdana]
Old 01-25-2006, 01:57 PM   #20 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
Ain't that the same crap they use in those E-Z GO Golf cart thingys
That's what we always tell my buddy with the Isuzu farm/deer hunter rig (Nick named the "Meat Wagon")
Photo is a old one when it used to be mine. Crappy photo cause I just took a photo with my dig of a 35mm print. aaaaahhhh deer hunting
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
