5.0 H.O. engine swap??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2002, 05:44 PM   #1 (permalink)
Member # 9487
Question 5.0 H.O. engine swap???
I have a 89 Mercury Grand Marquis with a fuel injected 5.0 H.O. that was given to me, it is wrecked. The motor runs like a clock. I just purchased a 73 CJ-5 that will be stretched 13" and put on a 81 CJ-5 frame SOA that was also strecthed 13". The plan was to use my 3/4 ton Suburban drivetrain but the 350 is not fuel injected (and it works damn good for hunting). What do I need to make the 5.0 swap? What are my tranny and transfer case options? I will be running 60's front and rear. The front is a passenger side drop (GM). Some help would greatly be appreciated. I am getting my rear axle tomorrow and am getting to the point of installing the drivetrain on the frame!!!
MillerMan is offline   Reply With Quote Quick reply to this message
Old 03-29-2002, 06:31 PM   #2 (permalink)
Member # 1169
Send a message via Yahoo to Monkeyboy
Ford NP435 to dana 20 from bronco or Adapt a dana 300 to it.
Thats what I'm doin.
It was even more of a turn on when I found out she was doing me to buy baby formula
Monkeyboy is offline   Reply With Quote Quick reply to this message
Old 03-29-2002, 06:50 PM   #3 (permalink)
Member # 9487
I have access to 3 jeep Dana 20's, is this an option? Is the 20 strong enough? Probably gonna run 39.5's, what about the wiring?
Old 03-29-2002, 08:07 PM   #4 (permalink)
Mr.N's Avatar
Member # 1635
This is a MUST for anyone thinking of swapping in a Ford EFI 5.0L. Buy the Probst pamphlet "Multiport EFI Engine Management Harness" by calling Ford's Tech 'Hot Line' 810-468-1356 for only $5. Then buy or barrow the Probst book and read it, a lot! "Ford Fuel Injection & Electronic Engine Control : All Ford/Lincoln-Mercury Cars and Light Trucks 1988 to 1993" by Charles O. Probst. Only 28 dollars. http://www.amazon.com/exec/obidos/AS...229428-7720961
Or a great second option and worth it's wieght in gold is the large and well documented Helms wire manual. $18.50 http://www.helminc.com/helm/product2...PFM7WQBB7G44DD
And Mitchell wiring manual, from local library or Auto store. Plus the Haynes and Chilton books.
Also my draft of my wiring page might help, but it's geared towards Mustangs
http://77cj.littlekeylime.com/5_0l_wiring.html
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 03-29-2002, 08:41 PM   #5 (permalink)
Member # 9487
Thanks for the info, any second thought's on the transfer case? Will a 20 hold up to 39.5's?
Old 03-30-2002, 10:13 AM   #6 (permalink)
withamc's Avatar
Member # 1757
Excellent info! I have a '93 Mustang 5.0 and an '86 Mustang harness with all the smog goodies - I had done a Mass Air conversion on the '86 before I wrecked it. Getting ready to do the same thing. I'm bookmarking your page and I'll give you feedback as I proceed. I probably won't be starting until summer though.
Usually lost...
Eat your spaghetti :flipoff2:
withamc is offline   Reply With Quote Quick reply to this message
Old 03-30-2002, 10:24 AM   #7 (permalink)
Member # 8843
you can use a C6 to a 203/205 doubler. I have a 5.0HO to C4 to D20 in my EB with dual 60s and 38.5s. I would definitely consider the D20 to be my weak link. I'll probably just go atlas eventually.
-Steve
offroadr35 is offline   Reply With Quote Quick reply to this message
Old 03-30-2002, 11:36 AM   #8 (permalink)
Member # 1065
Very good info Mr N,(well except fopr the Chiltons and Haynes manuals which are as about as worthless as tits on bull).
Thanks for the Links, I had to perouse a half dozen libraries looking for the same literature.
Pirates of the Rubicon
Announcing is tough,..I need a beer
H8monday is offline   Reply With Quote Quick reply to this message
Old 03-30-2002, 12:00 PM   #9 (permalink)
Member # 1169
I can't see why a jeep 20 can't be used.
If you wnet with the ford one and a ford Np435 you would not need to purchase an adapter.
(not sure of the input differences between jeep and ford 20's)
Old 03-30-2002, 02:50 PM   #10 (permalink)
Mr.N's Avatar
Member # 1635
Yeah, I've 3 different Chiltonís for my 77 and not one helped me at all. I even found differences between Helms and Mitchell with teh Helms being the correct one. (It should as it's just a Ford re-print)
Thanks for the complement!
Old 03-30-2002, 03:32 PM   #11 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
use a 435 and either get the adapter from AA to run a jeep dana 20, or use a 203-205 doubler setup, which could be done with a ford 203 (bolts right up to the tailhousing of the 435) and a dodge or GM 205 to get the pass side drop required for the chevy axle...
John Foottit 70 Bronco Buggy
Contact me about Custom Cabinetry www.beniciacabinetry.com
CrazyHorse is offline   Reply With Quote Quick reply to this message
Old 03-30-2002, 06:25 PM   #12 (permalink)
Member # 3834
Send a message via AIM to Bgcj5
I am running a ford t-18 adapted to a dana 300. It should work out great as both the motor and tranny is ford so u can use all stock parts. Make sure u get the 164 tooth flywheel from and F150 or 250 u can't use any of the mustang clutch stuff.
Just
Empty
Every
Pocket
Bgcj5 is offline   Reply With Quote Quick reply to this message
