Flux core wire size. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2002, 09:17 PM   #1 (permalink)
EricZ's Avatar
Member # 1364
Just picked up a Hobart Handler 135.
Came with 1lb of 0.030 flux core wire.
Gonna buy a 10lb spool.
Can i run 0.035 wire.
I know we are only talking about a difference of .005.
I think as long as i have the right size tip it'll be fine.
See any probs with it???
EricZ
2005 KTM 300 MXC
EricZ is offline   Reply With Quote Quick reply to this message
Old 03-30-2002, 09:42 PM   #2 (permalink)
bgreen's Avatar
Member # 9801
.035
The wire size you are interested in is .035" not 0.35"
.35 is almost 3/8" Dia
the diff between .035 and .030 is not much but it makes a diff. You can use it with you Hobart. I just did the same thing today. I bought a 2# flux core spool and a few .035 tips.
[CENTER]Project Freak - Resurrection[/CENTER]
bgreen is offline   Reply With Quote Quick reply to this message
Old 03-31-2002, 12:39 AM   #3 (permalink)
Member # 8161
Make sure your feed rolls have grooves for the .035 wire and your liner can handle the larger size. It should be ok though.
anthony_harris is offline   Reply With Quote Quick reply to this message
Old 03-31-2002, 01:13 AM   #4 (permalink)
Member # 1408
Send a message via AIM to RockRanger
As anthony said make sure the liner is the right size. I am not sure on the hobart but on my lincoln i had a skinner liner and ran .035 wire in it for a while then it jammed up and had to get a new liner ($12.00 or so) I would just call the local welding shop and see what they have to say about it.
Matt
RockRanger is offline   Reply With Quote Quick reply to this message
Old 03-31-2002, 07:16 AM   #5 (permalink)
Member # 3879
If you aren't using gas it's not MIG welding. Praxair seems to be the cheapest around here for gas. If you get gas you'll never use that flux crap again, unless maybe it's windy out.
-BTG Rockcrawlers-
Toyota 3VZE turbo
Benchworks steering systems in Az RIPPED ME OFF
Clifton is offline   Reply With Quote Quick reply to this message
Old 03-31-2002, 11:54 PM   #6 (permalink)
The Fleckster's Avatar
Member # 3178
Hey now I use Flux core wire ....Corse it's in combination with the gas. Its called Dual Shield. Talk about bad ass smooth welds. I will almost never run hard wire on my thick steel jobs again. The dual shield only comes in .045 at the smallest that I have found, but man does it fill an 1/8" gap and penatrate like there is no tommorow.
Yes the .035 will be fine in the Hobo welder. Just get the right tips and as mentioned above go hard wire you will like it in all places except windy areas.
Fleckster
John
Back Country Binders 4x4 ( bcb4x4.com )
The Fleckster is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 07:30 AM   #7 (permalink)
EricZ's Avatar
Member # 1364
I've welded with gas many times. In fact most of the welding i have done has been with gas. (Borrowing friends welders)
This is my first time with flux core.
When i get a little more $$$ i'll get a tank, but right now this is working fine for me.
Clifton - you going to the Jamboree?
EricZ
2005 KTM 300 MXC
Old 04-01-2002, 08:16 AM   #8 (permalink)
Member # 6043
You have to make sure that your liner will handle the .035 wire. My welder originally came with .030 liner. I purchased the .035 liner so that it would allow me to run the .035 flux core.
53 Willys truck restored mostly original
RocnWilly is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 09:24 AM   #9 (permalink)
Discount!
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
I have the peice of shit Hobart 135, and I use .035 in mine, but every so often it gets all jammed up at the begining of the liner right past the feed rollers, makes me real mad! They say it can run .035, but it does'nt run as smooth as .030.
Jeff
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
04 UJZ100
1990 FJ62
dog walker is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 11:48 AM   #10 (permalink)
Member # 7248
The .005 difference is significant. Because the cross section depends on the square of the radius, the .035 puts down 36% more metal for the same wire feed speed.
Flux core wire definatly has it's place.
I have better luck welding out of position with the flux core wire.
Don't forget to swap the polarity when you get your gas bottle hooked up.
Kevbo is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 03:16 PM   #11 (permalink)
Member # 5402
GET THE 0.035 LINER!!
hey Eric-
that's the key- spend the buck's for the right size liner and tips. it will assure ya that things will work properly.
Also, ya need to get a good quality nozzle dip or spray, especialy with the flux core. They splatter alot more than a gas setup.
If you do go for the gas shield, you'll probably want to use 0.023 solid wire w/ the little machine- that'll give ya a better burn.
I'm gonna buy some flux core for my Lincoln 170- I'm tried of fighting the wind up here. It's an easy swap over.
_____________
Q.
Are you using CO2 for your on board air? If so, you already have a tank, and probably a regulator for a gas set up------ check it out!
later
2009 Dodge Power Wagon with stuff on it...
crawler#976 is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 03:54 PM   #12 (permalink)
Member # 3879
Yup heading out the 11th, are you going?
-BTG Rockcrawlers-
Toyota 3VZE turbo
Old 04-01-2002, 07:06 PM   #13 (permalink)
Member # 256
I found home depo to be a cheep place to
buy the wire...
Land Crusher is offline   Reply With Quote Quick reply to this message
Old 04-01-2002, 08:20 PM   #14 (permalink)
Hayraker's Avatar
Member # 5946
I tried the .035 in my HH 135, it ran it OK, but I went back to the .030 because it carries it alot easier, and I think it makes better welds with this little machine.
I.R.B.S.T.M.
Hayraker is offline   Reply With Quote Quick reply to this message
