Bearing failure...input needed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-07-2006, 10:55 AM   #1 (permalink)
Rugger99's Avatar
Member # 22646
Well, I somehow managed to destroy a Timken 20 Series bearing. The bearing and race show no signs of discoloration due to heat buildup. When I pulled the shaft, there was this nice gray, metallic paste that was the remains of the grease and some cage pieces. The shaft(D60 35 spline) was dry. This bearing has less than 300 miles on it...there was also no sign of contaimenents in the oil when i pulled the diff cover.
The theory that I have is this ... due to my ARB leaking (copper line inside the diff had a hole worn in it due to being too close to the carrier) I was thinking that an air pocket may have formed,thus not allowing any oil to get to the bearing on the driver side,that in turn causing it to go crunch. Am I onto something here or crack? The axle is a Dana 60 with 35 spline shafts and I am the third owner of it. Was built by Currie. Any ideas or thoughts?
" Never underestimate the power of idiots in large groups"
Rugger99 is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 11:07 AM   #2 (permalink)
Gozuki's Avatar
Member # 3088
Yeah, "currie"...
Sometimes a two foot level is not handy, but usually there's some ground around.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 01:40 PM   #3 (permalink)
Rugger99's Avatar
Member # 22646
Btt...need some thoughts/input here
Old 02-07-2006, 02:02 PM   #4 (permalink)
Member # 13786
Not enough oil in the diff to run down the tubes
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 02:10 PM   #5 (permalink)
Rugger99's Avatar
Member # 22646
Diff was full.
Old 02-07-2006, 02:16 PM   #6 (permalink)
Member # 3002
no question on why the bearing failed, no lubrication..
why it did not get the lubrication is the question. are you useing the right cover? is this axle housing a dana? you said "d60 axle" the rear dana 60 housing fill hole is lower than a front HP 60 cover. is this a front or rear axle? you say "grease" so i'm thinking front axle. rear axle should have gear oil, or lube. not grease.
steelman
"There is no king, no prince, no president, no athlete,
nobody that has ever lived a better life than I have."
Evel Knievel
steelman is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 02:17 PM   #7 (permalink)
Member # 3002
steelman
Evel Knievel
Old 02-07-2006, 02:31 PM   #8 (permalink)
Member # 192
steelman
Well, its got a plate, so it's a rear shaft. Do you not grease your bearings a bit on the initial install? I do.
brector is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 02:40 PM   #9 (permalink)
Member # 3002
oops, just looked at the wasted bearing. and no i don't grease my rear axle bearings when first installed, i oil them like they say to do at timken.com
its a great web site. has pic's for trouble shooting, wear patterns, install dirrections, pre-loads, trq settings. etc...
Evel Knievel
Old 02-07-2006, 03:01 PM   #10 (permalink)
Member # 20092
Originally Posted by Rugger99
Diff was full.
When you say full, at what level was the oil? The level should be at the centerline of the axle shafts, and in effect the tubes will be half full of oil too.
Sure there is not a rag or something jammed up in there blocking oil from getting to the bearings?
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 04:40 PM   #11 (permalink)
Member # 46175
A few questions:
How many quarts does it take to fill? Depending on pinion angle, the fill hole may not be an accurate method.
What size tire and weight of vehicle? I run a set 20 bearing and 35 spline shaft in my 9" wearing 37's and on a 5,000 lb truck. I was afraid of this bearing as a weakness since my truck gets some raod miles.
What type of fluid? Synthetic is your friend.
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 02-07-2006, 07:55 PM   #12 (permalink)
Rugger99's Avatar
Member # 22646
Diff had the correct amount of fluid. There was nothing in the tube to block the flow of oil. After talking with Dan @ BlueTorch....the race may not have been correctly seated when I put it in...so it may be operator error....oops , hell,it could have been worse.
