Hydraulic Steering - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-03-2002, 08:58 AM   #1 (permalink)
Member # 11038
Send a message via ICQ to sweden
Hydraulic Steering
I'm looking for hydraulic steering information, i have been checking the net but cannot seem to find what i'm looking for, theres lots about the "rock ram" hydraulic help steering. But I want the fully hydraulic "orbitrol kind"? -Is there anyone who has a nice URL for me? What brands are there in this?
How big of a cylinder do i need for 44" boggers on 2.5T axles (Swedish axles btw, stock vacuum actuated lockers both front and rear) -lenghtwise/piston diameter and so on.
Any tips/urls appreciated!
/Magnus
sweden is offline   Reply With Quote Quick reply to this message
Old 04-03-2002, 09:06 AM   #2 (permalink)
Member # 9971
Scroll to the bottom of the page. Select the drop down to diplay the last 100 days.. let the page reload then <img src=" images/top_search.gif "> the appropriate buzz words
and welcome newbie
I swing this old hammer, for a dollar and a half a day….
AKA cornfedred
ol John Henry is offline   Reply With Quote Quick reply to this message
Old 04-03-2002, 09:06 AM   #3 (permalink)
Moderator
apeters89's Avatar
Member # 7647
try here
apeters89 is offline   Reply With Quote Quick reply to this message
Old 04-03-2002, 09:14 AM   #4 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
https://www.pirate4x4.com/forum/showt...threadid=44513
howe steering performance in lakeside CA
i have run several of his setups on diffrent rigs. top of the line stuff
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 04-03-2002, 09:17 AM   #5 (permalink)
The Piratenite
camo's Avatar
Member # 4
ops forgot the # 619-561-7764
Old 04-03-2002, 11:04 AM   #6 (permalink)
Member # 11038
Thanks
Thanks, have been reading up now -Theres loads and loads of stuff
As i get it custom seems to be the only true way to get my 100% hydraulic steering.
A pal who currently are putting a cj5 body on top of hes unimog bought a complete steering setup with wheel/steering/column/orbital valve/pump/ram from some tractor junkyard. I think it's from a harvester of some kind. Anyway it's all bosch stuff.
-Anyway he's come to the conclusion that hes not gonna use it and has it and wants 250$ for the lot.
Only problem as it seems is that the piston on the ram (hydraulic cylinder) seems a bit on the small side? Converted from mm its:
~0.7" thick (18mm)
~8.3" long (210mm) (piston travel)
As i stated earlier i'm going for 2.5T axles and 44" boggers, can this seemingly puny pushrod deal with that?
Old 04-03-2002, 11:07 AM   #7 (permalink)
The Piratenite
camo's Avatar
Member # 4
no. i am using a 2 .25" inch ram and you will want at least a 2" for full hydro
Old 04-03-2002, 11:26 AM   #8 (permalink)
Member # 5960
Send a message via Yahoo to LAME
He is probably talking the shaft size, not the piston dia.
I would imagine your 2.25 ram is around a inch or so...still might be a bit small with the .7. Tractors often use linkage, instead of direct pressure on the steering (for the ram)
crawl4cure.org
Rock Rash Racing #613, Trail Tampon Spotter
LAME is offline   Reply With Quote Quick reply to this message
Old 04-03-2002, 01:30 PM   #9 (permalink)
Member # 6494
My 2x8 ram has a shaft size of 1.125. 0.7 might be kinda small. Maybe take your buddy's junk and take the ram back to the j-yard and see if you can swap it for a slightly larger one. 8" stroke is pretty typical for most of the steering setups I've seen. I had to limit mine to 7" though.
Easy
[SIZE="4"][FONT="Trebuchet MS"][I][COLOR="Magenta"]#914 Pampered Chef Buggy[/COLOR][/I][/FONT][/SIZE]
[SIZE="2"][U][COLOR="Blue"]Companies we're proud to work with[/COLOR][/U][/SIZE]
[COLOR="Blue"]East Coast Gear Supply[/COLOR]
[COLOR="Red"]Reid Racing[/COLOR]
[COLOR="DarkOrange"]RCV Performance Axles[/COLOR]
[COLOR="Sienna"]Rose Grinding & MFG[/COLOR]
[COLOR="DarkOliveGreen"]Single Source Welding[/COLOR]
[B][COLOR="Wheat"]Northern member of MUD DEVILS[/COLOR][/B]
EasyXJ is offline   Reply With Quote Quick reply to this message
