Can you run Humvee tires on Humvee wheels without runflats/beadlock? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-18-2006, 01:24 PM   #1 (permalink)
vintagespeed's Avatar
Member # 25551
Send a message via AIM to vintagespeed Send a message via Yahoo to vintagespeed
I have a set of 36" Goodyear GSA's (biased) to run on my Humvee wheels, but I have no runflats of any kind to hold them against the bead.
I mounted a couple of them up on the wheels and cant get the bead to seat, I'm assuming this is because I'm either a retard or the stiff sidewall is preventing me from getting enough air pressure to seat them. Do I need to take these to a tire shop to get them seated? Will they seat at all without the internal beadlock?
These tires are just for testing so that I can determine if a 36" tall tire will work for my setup or if I need to go 37-38. And they were cheap rollers. I plan to run PVC inserts once I get the right size IROK.
Thanks for any help!
-jb 'been here awhile.
vintagespeed is offline   Reply With Quote Quick reply to this message
Old 04-18-2006, 01:34 PM   #2 (permalink)
Member # 3864
Send a message via AIM to WOLF359
yes they will mount without the beadlock/runflat insert.
WOLF359 is offline   Reply With Quote Quick reply to this message
Old 04-18-2006, 01:45 PM   #3 (permalink)
Member # 11077
Send a message via AIM to Gouky Send a message via Yahoo to Gouky
try a racheting strap acound the circumference of the tire and tigheten it as much as you can. it should make the beads spread a bit and help you seat it
Gouky is offline   Reply With Quote Quick reply to this message
Old 04-19-2006, 05:47 AM   #4 (permalink)
Member # 3511
Also make sure to lube up the bead with some dish soap. The bias hummer tires are really stiff, and really don't seat easily even with the insert in there.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
