Mounting Tires - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-18-2006, 09:45 AM   #1 (permalink)
bigblackblur's Avatar
Member # 44321
Send a message via AIM to bigblackblur
Mounting Tires
Alright well this is kind of a newb question, but I have this feeling that most newbs don't mount their own tires.
What is the best/easiest way to mount tires. I don't want to take them to pep boys. How do you guys mount up your tires?
Sorry for the dumb question, a few quick answers and you can let this thread drop.
Thanks alot,
Kevin
bigblackblur is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 10:03 AM   #2 (permalink)
ROCKILLER's Avatar
Member # 3273
dish soap, tire irons (or crow bars) and cussing. Go buy a 6 pack first so you have something to look forward to.
[QUOTE=Alfred W.;10665950]When a man has the scent of pussy in his nose...... The best advice in the world bounces off the block formerly know as his head. :grinpimp:[/QUOTE]
ROCKILLER is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 10:27 AM   #3 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
From my experience, it has been MUCH easier to take them down the street to the service station and pay them a couple bucks than to wrestle with them myself. Now backcountry tire changes are obviously a different ballgame. Rockiller has it right if that is the case...
’94 GMC 6.5TD K1500 Yukon SLE / ’93 Chevy 6.5TD K2500
’85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 10:30 AM   #4 (permalink)
andyr354's Avatar
Member # 28130
My procedure that worked well on my 44" TSLs
mix some dish about 50/50 with water and soap up the beads
Got out my set of HF prybars and mounted them up, working around the beads with two bars. The 44s were large enough I just knelt on the sidewalls to put pressure on them.
The ones that werent deformed I was able to use a ratchet strap around the tread to get them to take air. Soon as it starts to inflate release the strap.
The ones that had sat and gotten deformed...... ether+match.
89XJ, 4.0L, AW4, D30, D44, 33s, homefab dakota and RE lift.
93 Dodge W250 Clubcab LE, Cummins, getrag 5spd, 3.54s, straightpipe.
andyr354 is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 10:44 AM   #5 (permalink)
b454rat's Avatar
Member # 16536
Took me a whole 5 minutes total to mount 2 40" boggers on 15x12s. LIke the others were saying, dish soap or laundry soap, that stuff is slickery. Two prybars, spray the bead, push on to the rim, work the bead over, and air up. I never take tires to get mounted, or even dismount, got a bead breaker. Why pay them for something you can do for nothing?
Web wheeler
b454rat is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 10:47 AM   #6 (permalink)
LeviGarrett76's Avatar
Member # 13654
same as above, except i only use soap if i have to, i try to avaoid moisture in the tires since i run bb's
two tire tools and ether are all you need
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency.
LeviGarrett76 is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 12:35 PM   #7 (permalink)
Member # 47974
If you need to break the beads, use your Hi-lift. I.e. jack up the front of your rig on the bead, works like a charm.
19 JL, ex’s: 16 JK, 98 TJ, 98 ZJ, 90 XJ
1996cc is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 01:50 PM   #8 (permalink)
13972551's Avatar
Member # 71473
GUY's, GUY's, GUY's, thats never going to work. Its a 12 pack of beer.
13972551 is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 02:04 PM   #9 (permalink)
andyr354's Avatar
Member # 28130
I can barely walk after drinking around 4 lately. I am a cheap drunk
Old 05-18-2006, 02:10 PM   #10 (permalink)
andyr354's Avatar
Member # 28130
