Wilwood / CNC clutch reliability - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-29-2006, 07:36 AM   #1 (permalink)
Lars915's Avatar
Member # 12876
I'm looking at converting my Ford 302/T-18 combo to a hydraulic clutch and have a couple questions.
How is the reliablity of Wilwood and CNC pull type slaves? Is one better than the other? Is the CNC push type slave good?
Both of these slaves use a 7/8" bore, Wilwood offers a 3/4" clutch master cylinder. Is this master large enough to disengage the clutch?
This rig sees some street time (to and from trails, up to 100 miles per trip), and tough trails. I need a reliable clutch setup, I'd like to hear people's experiences.
Lars915 is offline   Reply With Quote Quick reply to this message
Old 07-29-2006, 09:39 AM   #2 (permalink)
Member # 15404
I have been running a willwood pull type for 4 years now. The only problem I have found is that they didn't locktite the piston to the rod and it started to loosen up on me (did it on 2 friends race rigs too). After I pulled it appart and locktited it it worked great.
3/4" master cylinder is what they recomend...I have been using a 5/8" factory one and it is just bairly enough for my sm465...
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 07-29-2006, 09:54 AM   #3 (permalink)
Member # 10974
I ran wilwood with the pull type for 5-6 years, with no problems.
toploader4x4 is offline   Reply With Quote Quick reply to this message
Old 07-29-2006, 09:59 AM   #4 (permalink)
Brian1's Avatar
Member # 2205
I run a Wilwood 3/4 master and a CNC push slave and it works great. When I was first making my system I used a 3 finger pressure plate (I already had it with my engine) and it was a little tough to get the clutch to disenguage with the hydraulics. I traded up for the multi finger pressure plate and it was alot easier to press the pedal and disenguage the clutch.
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 07-31-2006, 12:39 PM   #5 (permalink)
Lars915's Avatar
Member # 12876
Good to hear people are getting several years out of them. Thanks for the replies!
Old 05-22-2008, 12:06 PM   #6 (permalink)
Member # 88867
I had two Wilwood slaves come unscrewed. I called them and they told me they were unaware of any problem with their slave. I tried Locktite after thoroughly cleaning the threads and it came apart again. I made the fix permanent with a roll-pin.
North Tahoe Trail Dusters
FOTR
Blue Ribbon
NRA Life Member
KK6EGU
Posimoto is offline   Reply With Quote Quick reply to this message
