3 Link - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-01-2006, 03:43 PM   #1 (permalink)
Member # 27266
3 Link
OK lets beat a dead horse,
I have read and searched, but I am going to ask a question that might seem stupid. What is the right measurements for a front 3 link? I am aware that the link length will change, and the method of mounting will be different for each vehicle, but how about Anti-squat, roll center, and roll axis? I am working on an FJ55 project (http://homepage.mac.com/ryanandjessaka/PhotoAlbum1.html) and some problems with the steering means I am going to have to do a 3 link. I have read the posts and used the 3 link calculator, but am still unsure. I also noticed that the calculator is for rear axles. Will that have any impact on the results?
What I have now:
Wheelbase 107"
Anti-squat 67.34
Roll axis 6.05
Roll center 24.17
8.5" separation at the frame
8.5" separation at the axle
The lower links would be 33" and the upper link would be 35"
Go ahead and tell me to search, but give me some good advise as well.
Thanks,
Ryan
scottryana is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 03:55 PM   #2 (permalink)
Member # 52710
Is that roll center 13" off the ground? Thats pretty low, will result in alot of body sway.
Slowly building:
jpmassey is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 04:04 PM   #3 (permalink)
Member # 27266
jpmassey,
Sorry, I had the wrong info entered for my Panhard bar it should actually be 24.17" with a roll axis angle of 6.05. Any suggestions on what numbers I should be looking for? I have a clean slate to work with, but having never done a 3 link I have no idea, what is ideal and what will kill me.
Thanks,
Ryan.
Old 08-01-2006, 07:03 PM   #4 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Here's what I'm building right now.
The calculator can be used for front or rear, it's just gonna be anti-dive instead of anti-squat.
Converge the links towards the frame (less seperation there) and I think you'll be happier with it. A good starting point for the frame is to have 75% of the seperation you have at the axle. Mine is 8" and 6" I believe.
Other than that the values don't look too bad. 3-links done this way can have some bitchin clearance issues though. Here's how my crossmember is going together (along with the 4-link rear:
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is online now   Reply With Quote Quick reply to this message
Old 08-01-2006, 08:07 PM   #5 (permalink)
Member # 27266
How imporant is it to follow the 70% rule? I have been told a couple of times, that I need to make my top link 70% the length of my lower links. I can only think that this would help point the pinion at the TC as the axle drops. Wouldn't this change the caster quite a bit? Maybe the 70% rule is more for rear axles? What do the experts think?
Ryan.
Old 08-01-2006, 08:46 PM   #6 (permalink)
Member # 21938
I have come up with a 4link for the rear of my YJ how do I put the picture in a post for a critique?
Marc
northjerseyjeepclub
Save tellico #112
[I]origionall posted by entropy I'm so jealous, my penis just left me with a note telling me I'm a loser and he is going to find a cooler guy to hang with...[/I]
[I]Originally Posted by TrojanMan
It's on another non-4x4 related site too... jeepsunlimited.com[/I]
rokspydr is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 10:58 PM   #7 (permalink)
stomper4x4's Avatar
Member # 22805
for the front 70%AD is way to much, you want to shoot for no more then 50%AD...IMO 6* roll axis is alittle to steep, even for a steering axle....You also want your upper link to be the same length as or shorter then your lowers......
[B][COLOR=Green][QUOTE]
So you want all for yourself alone
And you don't think about the other man
Let me tell you my friend if you gonna live this life
It's not good for you to build strife
Robert Neshta Marley ; Cravin choke puppy[/QUOTE][/COLOR][/B]
stomper4x4 is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 11:20 PM   #8 (permalink)
TRD
TRD's Avatar
Member # 8286
I agree with stomper about the AD being too high
I think the roll axis is in the acceptable range
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 08-01-2006, 11:45 PM   #9 (permalink)
vetteboy79's Avatar
Member # 31621
Ryan.
Actually, having the upper link shorter has the opposite effect of what you're describing.
In a nutshell, without inspiring a lot of debate and worthless posts, having the upper link shorter helps keep the anti-dive/squat characteristics favorable throughout the whole range of your suspension.
Keeping them equal length will maintain your same caster angle.
Having the upper length longer will give you a better pinion angle, at the expense of having a good caster angle throughout travel and also at the expense of having any movement from that point of reference.
I know the advantages of making it shorter; however in mine I made the upper link longer because I was going to have issues with the pinion angle. Your situation might be different.
