links and airbags are done!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2006, 08:59 AM   #1 (permalink)
motorcitydak's Avatar
Member # 54956
Send a message via AIM to motorcitydak
I finally had a free weekend and used it to tear down my dakota. I put a new dana 44 from a 78 f-250 w bronco 5 lug brakes and outers. The big difference this time is I used 11 inch travel semi truck reversing sleeve air bags. It is really soft and I need to get my mx6-r shocks on there soon. It is a double Y link radius arm type setup and I can disconnect my upper arms to allow flex. but here are a few pics I took this mournin to show off.
96 dakota 44/9 4.56s loc rite front, detroit rear, 3 linked w 14 inch FOA coilovers and Alcan leafs on the rear, Dana 300, 35in MTZs. O ya, and that things got a HEMI!!!
motorcitydak is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 09:11 AM   #2 (permalink)
Member # 13886
This should get interesting..
71 Bronco frame off in progress.
efi302, 3 link front, 4-link rear
Buba is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 09:23 AM   #3 (permalink)
bigassedredjeep's Avatar
Member # 38701
Send a message via AIM to bigassedredjeep Send a message via Yahoo to bigassedredjeep
those may be the worst pics eva..
bigassedredjeep is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 09:25 AM   #4 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
What exactly is going on here?
Apparently caster and pinion angle are adjustable by simply drilling a new hole...
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is online now   Reply With Quote Quick reply to this message
Old 08-02-2006, 09:31 AM   #5 (permalink)
Member # 54956
sorry, ill get some more tonite cuz i f-ed up my ball joints and need to replace 2 of em.
Old 08-02-2006, 09:38 AM   #6 (permalink)
Member # 54956
No, I set the pinion angle and castor before drilling the holes. I set the castor to 4 degrees when its at ride height(bags at about 9 inches). Then I drilled 2 1/2 inch holes thru the upper arms and put bolts thru the pass side and will have pins on the drivers.
Old 08-02-2006, 09:52 AM   #7 (permalink)
Member # 38701
so because you fucked your your ball joints, you couldn't operate the camera properly??
Old 08-02-2006, 09:57 AM   #8 (permalink)
Member # 54956
basically yes. You see, a while ago, God said I can pick bw fab or photography. I picked fab.
Old 08-02-2006, 10:06 AM   #9 (permalink)
Member # 54956
I do have pics of my buildup every step of the way, but they are so dark, it wasnt worth puttin on here. Thats why I will take some more tonite so you guys can see what happens at the axle.
And as for the ball joints, some of the threads got flattened out so I couldnt get the nuts back on so I need to replace em.
Old 08-02-2006, 12:02 PM   #10 (permalink)
jesster's Avatar
Member # 49468
I don't think god likes you...
jesster is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 12:48 PM   #11 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
He better start praying his ass off then, if he is going to disconnect the upper radius arm on that suspention...
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 12:52 PM   #12 (permalink)
Member # 77093
You should've picked photography!
Why are you using square tubing? With a custom suspension radius arms would not be my first choice...should've ran a three link w/ panhard.
Bu11et is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 12:56 PM   #13 (permalink)
mrtwstr's Avatar
Member # 12370
LOL, I aint say'n shit!
I'M the real Dan Black!!!!
mrtwstr is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 01:00 PM   #14 (permalink)
Member # 54956
ya, i was waitin for those replies, took you guys a little while.
Please keep in mind that there are upper arms on both sides, but I will only disconnect one at any time.
I went for square becasue the flat sides will keep it from bending. it is more rigid that round tubing the same sizes.
Old 08-02-2006, 01:04 PM   #15 (permalink)
Member # 3815
Meaning you will disconnect one of the upper arms on one side only, correct? And, you're running a panhard bar, correct?
EDIT: n/m, answered above.
Cajun is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 01:06 PM   #16 (permalink)
Member # 54956
and you can see the panhard bar in the top pic. its bw the tie rod and drag link attached to the top of the axle.
Old 08-02-2006, 01:11 PM   #17 (permalink)
Member # 54956
Ive seen a few rigs with the Y link on one side and just a single link on the other. I build the double Y link so I can lock up both uppers and it will act as a sway bar with the only "give" coming from the bushings at the axle.
Old 08-02-2006, 01:12 PM   #18 (permalink)
Member # 26216
Send a message via Yahoo to Gummi Bear
When he disconnects the passenger side only (RIGHT?!?!) it'll act like a wristed radius arm on a Ford.
LOL
If there isn't a panhard, then he'll be discussing his place here with God sooner than later.
I consider myself a student of the game, it's just too bad I'm in special ed...
Gummi Bear is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 01:17 PM   #19 (permalink)
Member # 3815
LOL
I thought that was essentially what he was talking about, but I hate to assume things, especially here lately.
Old 08-02-2006, 01:19 PM   #20 (permalink)
Member # 54956
Yes, gummi bear is rite
Old 08-02-2006, 05:21 PM   #21 (permalink)
geeze's Avatar
Member # 34420
What airbags are you using?
geeze is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 06:30 AM   #22 (permalink)
Member # 54956
http://truckspring.com/Search.aspx?Keyword=5423
Old 08-03-2006, 07:34 AM   #23 (permalink)
mj
Member # 1919
looks good.
do you have it set for 9" compression travel and 3" extension?
what are you using for rod ends?
mj is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 08:36 AM   #24 (permalink)
Member # 5982
Looks like the same bags I'm using in the rear on my rig. What are you using to limit the bags?
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 08:44 AM   #25 (permalink)
Member # 54956
At 9 inches, I have almost 7 more inches of extension and it will compress about 4. It has 11 inches of travel from 4.9 to 15.8 inches.
I have large summit machine flex joints welded to 1.25 all thread. that is 2x2 .250 wall square tube. I have poly bushings at the axle and am using BTF traction link brackets to hold on. I have 3/4x3/4 rod ends w 5/8 hi-misalignment spacers on the drag link and will be changing to 5/8x3/4 rod ends on the track bar.
