CB kills engine????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2006, 09:59 PM   #1 (permalink)
SpineTx's Avatar
Member # 1499
Every time I key up the mic on my CB (Classic nightwatch) my engine dies. I am running a holly projection with analog computer. I have heard that the CB can cancel the computer. My question is: is there anything that can stop this from happening besides replacing either of them. ie is there some kind of filter that will eliminate this?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 10:12 PM   #2 (permalink)
Member # 13786
Call Holley, GM ---years ago had the same problem, took about 10+ watts to do the caddys in
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 10:13 PM   #3 (permalink)
CJDave's Avatar
Member # 12232
I have found that when trying to get the holley pro junktion to work correctly the most sucessfull method is to take the computer out and carefully hang it from a tree, bush, fence, pole, junk car, bla bla bla..... .
And fire what ever high power weapon you can find at it
And if you have no high power weapon.............
A BFH works good too
WE SPLINE AXLE SHAFTS!
Great wheeling in the North east!
CJDave is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 11:13 PM   #4 (permalink)
Member # 1887
I don't know jack about the Holley stuff, but what happens if you wire the radio directly to the battery (both + and -)? If it still happens, what if you use a separate battery? Is your antenna properly gounded?
I'm guessing - just guessing - that you've got a wiring problem somewhere. Also, you might post your question in the "Electrical systems" forum at http://www.cbradioforum.com/.
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
ScaldedDog is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 11:18 PM   #5 (permalink)
TNRanger's Avatar
Member # 22676
Send a message via ICQ to TNRanger Send a message via AIM to TNRanger
had the very same thing happen in a cro-moly chassis carbon fiber bodied pro stock car last year with a racing radio(using a 9v not wired in) and an MSD digital 7 programmable. Turned out the chassis itself was magnatized. The radio interference totally fawked up the ignition. Ran a demag(degaussing) tool over the bars and it fixed the problem. may be totally unrelated, but worth a toss.
95 YJ 4 links f/r, D60/14b 5.8/c6/203/205 115.5"wb
90 Ranger 5.0/435/205, D44/D60
04 F-250 PSD
TNRanger is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 11:51 PM   #6 (permalink)
2manyprojects's Avatar
Member # 39901
often times it's rf radiated from the ant that gets into the "box".
Ground the case on the holley box and try some different mounting locations for the box and ant.
"]my 90 project [/URL]
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Because there is no 2nd chances on Pirate!
2manyprojects is online now   Reply With Quote Quick reply to this message
Old 08-03-2006, 10:27 AM   #7 (permalink)
SpineTx's Avatar
Member # 1499
Antenna is properly grounded, wired directly to seperate battery. When using a less powerful CB it doesn't happen, or at least it doesn't kill the engine, just causes a sputte.
Where can I get a degaussing tool and do you run over the entire frame body and cage?
As far as relocating or remounting the "box" do you mean the computer?
Old 08-03-2006, 10:37 AM   #8 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
It sounds to me like the Holly box is not properly shielded against RF. Make an enclosure for it out of sheet metal and see what happens.
Originally Posted by Mustard Dog
Me and my co driver were running across the Lakebed on our way to pre run when we saw :gary: walking his dog.
We didn't stop to say hi cause he's a fucking douchebag.
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 11:00 AM   #9 (permalink)
thump93yj's Avatar
Member # 14874
Look into Toroid Choke Cores... radioshack
-clint
Secret black text says... Buy my Stuff!
For Sale:
thump93yj is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 11:18 AM   #10 (permalink)
SpineTx's Avatar
Member # 1499
Excuse my ignorance, but what is that and what does it do?
Old 08-03-2006, 11:44 AM   #11 (permalink)
rotozuk's Avatar
Member # 8965
Might try slapping some tin foil around the Holly and some of its wires. See if that helps any. Quick and easy method to see if basic RF sheilding will help.
I still like the idea above of strapping the holly up and shooting at it.
rotozuk is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 12:15 PM   #12 (permalink)
Member # 4406
Are you running the early or late analog computer? The early ones have a finned case, and were more succeptable to the CB problem. The later ones had a smooth case. Try moving your computer further away from the CB. I remember this being a fairly common problem when the Projection setups first hit the market.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 03:05 PM   #13 (permalink)
Roksamy's Avatar
Member # 752
Is the equivilent of the tin foil hat often suggested ofver in chit chat
I'm on a boat
Roksamy is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 03:28 PM   #14 (permalink)
SpineTx's Avatar
Member # 1499
Pete
Yes it is the older analog computer, I will try to move the computer and try shielding it.
Is it possible that the computer is also inhibiting the performance of the CB?
Old 08-04-2006, 07:44 AM   #15 (permalink)
Member # 4406
Not sure on the computer messing up the CB, I kind of doubt it, but I'm really not sure.
Pete
Old 08-04-2006, 09:33 AM   #16 (permalink)
SpineTx's Avatar
Member # 1499
Still trying to figure out what this is, anybody?
Old 08-04-2006, 10:15 AM   #17 (permalink)
ROCKTACO's Avatar
Member # 6296
It is an iron ferrite material that is formed like doughnut made to clamp around in this case your holly harness right before it goes into the ECM. The idea is that you are getting RF induced into the wiring of the ECM that is fawkin it up. The FF is most likly screwing with the crank sensor.
I would double check that the antenna system is not grounded, and make sure it is properly tuned.
CALIFORNIA CREEPERS
ROCKTACO is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 11:02 AM   #18 (permalink)
thump93yj's Avatar
Member # 14874
sorry... late reply... yep, see above... radio shack has a few variations of these... similar to what you see on a lot of usb pc cables etc. to combat rf interference.
I used one on my Quadzilla fuel box for my previous tow-rig... anyone with a high output cb keying next to me would cause the truck to stall. Depending upon grounding and such mentioned above... RF cant interfere with numerous vehicle gizzmos, computers etc.
Here's the RadioShack doodad I used
-clint
For Sale:
Old 08-04-2006, 12:39 PM   #19 (permalink)
61scout80's Avatar
Member # 16722
how close is your antenna and coax to the computer? i would try moving the 2 as far from each other as possible would result in less rf into the computer. if that fails then look into building an rf shield for the computer.
powerful cb's could really interfere with electronics. My old base unit would overtake any electronic device in the house. i put an extra 10'-0" section of pipe under the antenna to raise it up and after that the only thing i had trouble w/ was my fm radio that sat on the same desk as my cb. moving the antenna and coax might help you.
Sky is filled with starry scenes of heroes and their greatest deeds
61scout80 is offline   Reply With Quote Quick reply to this message
Old 08-06-2006, 12:52 PM   #20 (permalink)
Member # 77285
I had an 88 S-10 that the cell phone would make spit and sputter. Riding down the road, make a call, truck starts sputtering.
perterra is offline   Reply With Quote Quick reply to this message
Old 08-25-2006, 03:43 AM   #21 (permalink)
OX
Member # 3113
DITTO!!!!!!
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
79 Bronc XLT, 400/C6/404 Mogs/42 roks
OX is offline   Reply With Quote Quick reply to this message
Old 08-25-2006, 05:51 AM   #22 (permalink)
Member # 41969
You need to run shielded wires and you will no longer have this problem. Has been a problem for a long time for people with the old holley system
08 LTZ Duramax
Top Shop Champion Spring 2006-Team Toumbs Repair
Top Shop Champion Fall 2006---Team Toumbs Repair
Originally Posted by Dan Dibble
"In my opinion this is a motor sport so I like to have one. Any more questions "
Dan
botiejeep is offline   Reply With Quote Quick reply to this message
Old 08-25-2006, 11:46 AM   #23 (permalink)
mc5cent's Avatar
Member # 52536
How about you find somebody who can hook you up with stock 351 fuel injection and just put that in it? Then take the Holley crap and sell it to some other sucker. I may know a guy who can hook you up. Patience Randy, patience.
mc5cent is offline   Reply With Quote Quick reply to this message
