Rockcrawling course - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-04-2006, 09:45 AM   #1 (permalink)
Gonzalo Bravo's Avatar
Member # 26772
Rockcrawling course
Some one knows the thickness on the upper layer of this courses? What in underneath the surface?
Suzuki Samurai, 2JZ GTE 3.0TT, A340, NP231 Doubler, TLC Tcase, 12" ORIs, Toys 8" ,4.30s, Toys OEM Lockers, Iroks 36".
Gonzalo Bravo is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 09:47 AM   #2 (permalink)
jbcruiser's Avatar
Member # 9868
The underneath was styrofoam blocks.
I don't know the thickness, but it wasn't thick enough. We chewed through it pretty quick.
jbcruiser is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 11:59 AM   #3 (permalink)
Member # 48233
Looks like an old Putt Putt Golf course
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 01:04 PM   #4 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
To add to this...what I had heard was it wasn't regular styrofoam...at least it was RUMORED to be a harder, less brittle, type of styrofoam. It may not have even been listed as the word styrofoam, but instead a slightly different form of foam that is SIMILAR to styrofoam but with a different name.
Then again, that was RUMOR...it may have been plain-old styrofoam.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 01:47 PM   #5 (permalink)
Member # 4313
I assume the material was intentionally spread thinner as it was only dseigned to be used once and then had to be taken apart and thrown out.
There was also no rebar used in the construction of those obstacles.
I heard rumors that the surface itself was Jello Brand ® pudding, heat treated to a crackly crunch under the Vegas desert sun, but you know what they say about rumors . . .
Alan Soutter
Proudly representing our 2006 sponsors:
AlanSou is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 03:03 PM   #6 (permalink)
fcfred's Avatar
Member # 3263
get 1 million gallons of expanding foam mixed with wood shavings, then coat the whole thing with concrete.
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 04:15 PM   #7 (permalink)
Member # 50632
It was closed cell polystyrene or closed cell polyurethane but if you are on a budget straw bayles and gunnite work well. we have actually hand packed small stuff before. just get 10 of your crawling buddys and have the truck dump all 10 yards of pump mix,as high up as he can then spread it with flat shovels and hand trowels. it ends up looking like 10 rednecks did it but you can sure crawl the crap out of it and it holds up pretty well.
here is the last thing we hand packed.
Wayne
AllTech Motorsports
Fuel systems, shock work, and more
(951) 970-3399
Fox Shocks
ZukIzzy is offline   Reply With Quote Quick reply to this message
Old 08-06-2006, 11:25 AM   #8 (permalink)
Member # 26772
great. But someone knows about the thickness needed?
Old 08-07-2006, 10:56 AM   #9 (permalink)
Member # 50632
3" will hold up if there is chicken wire in there but if you want it to be permanent you need rebar with in the middle of that 3 to 4". if it is for something temporary then use some fiber ad mix and make it around 2 to 3" with it being heavier on the edges and the high trafic areas.
Wayne
AllTech Motorsports
(951) 970-3399
Fox Shocks
