Warn allen size - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2006, 12:15 PM   #1 (permalink)
cdhicks99's Avatar
Member # 77032
Warn allen size
Yes, I have searched high and low for this before asking.
What the hell size is that allen head?
I have Std. and Metric none of them fit well.
'94 NISSAN PATHFINDER cLE
3" susp. lift, Pro-Comp 3000's in the rear, lsd rear, IAB, 15x8 Rock Crawlers, 32x10.5 TSL's.
D44/F9 w/ 4-links F&R coming soon!
cdhicks99 is offline   Reply With Quote Quick reply to this message
Old 09-05-2006, 12:26 PM   #2 (permalink)
jesster's Avatar
Member # 49468
7/64
jesster is offline   Reply With Quote Quick reply to this message
Old 09-05-2006, 12:27 PM   #3 (permalink)
Member # 24859
Dude , I had the same problem. I went thru hell tyin to figure that out. I just kept tryin different sets. The cheapo flip out set finally had one in it that fit. Tis a bitch tho.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 09-05-2006, 12:34 PM   #4 (permalink)
BryanS's Avatar
Member # 21266
Yeah, no kidding! Goofy damn size. I ended up using one of those star style bits since it fit better than any of my allen wrenches.
BryanS is offline   Reply With Quote Quick reply to this message
Old 09-05-2006, 12:49 PM   #5 (permalink)
cdhicks99's Avatar
Member # 77032
Originally Posted by jesster
7/64
Thanks, I'm heading out to find one now!
Old 09-05-2006, 04:39 PM   #6 (permalink)
cdhicks99's Avatar
Member # 77032
FYI it's 9/64
Old 09-05-2006, 05:13 PM   #7 (permalink)
TDW
Member # 1352
Originally Posted by cdhicks99
FYI it's 9/64
Both are correct depending on the hub.
One ton hub (11690 and 38826) = 9/64
half ton (9790 and 20990) = 7/64
external = 5/32
TDW is offline   Reply With Quote Quick reply to this message
Old 09-06-2006, 07:43 AM   #8 (permalink)
jesster's Avatar
Member # 49468
FYI it's 9/64
I ASSumed you had a 1/2 ton front with 32 inch tires, I guess you should have given more info...
Thanks for clearing that up TDW.
Old 09-06-2006, 08:46 AM   #9 (permalink)
YeeP's Avatar
Member # 4568
Send a message via AIM to YeeP
external = 5/32
Do you work at a shop, work for warn, or have no life and memorize warn part numbers?
YeeP is offline   Reply With Quote Quick reply to this message
Old 09-06-2006, 09:20 AM   #10 (permalink)
cdhicks99's Avatar
Member # 77032
It's actually an axle I just bought for my SAS. According to what I've found so far is that it came out of a K10 Blazer mid 70's.....
Guess I got lucky??????
Old 09-06-2006, 09:25 AM   #11 (permalink)
jesster's Avatar
Member # 49468
Should be a 44 front out of a 70's K10, but with 9/64 head size, maybe a 60?
Factory or aftermarket lock outs?
Old 09-06-2006, 09:35 AM   #12 (permalink)
cdhicks99's Avatar
Member # 77032
Aftremarket.
I am positive it's not a 60.
It only has the 6 on 5.5 pattern, 3" tubes, and flat top knuckles.
Old 09-06-2006, 10:16 AM   #13 (permalink)
Member # 15404
I have old internal warn hubs with 3 different sizes of allens... there have been a bunch of changes thru the years. Most have been ?/64 so I would use your allens and find the closest one and then head to the stoor to match it up.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 09-06-2006, 10:17 AM   #14 (permalink)
jesster's Avatar
Member # 49468
Aftremarket.
D44 for sure then...
