power steering fluid temp? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-07-2006, 07:49 PM   #1 (permalink)
X-Rated's Avatar
Member # 72707
Does anyone have any idea what temperature full hydro steering systems run at? I know the hotter the fluid the easier it cavitates, so cooler is better, but I have also heard too cold is bad as well...
What temperatures are you guys seeing, and what temps do you shoot for?
X-Rated is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 10:04 PM   #2 (permalink)
Danger Ranger's Avatar
Member # 1234
ha I just asked the same question without seeing your post... I installed a oil temp gauge and put the sender right into my ext reservoir. I saw temps no higher than mid 150ish this past weekend... that was a couple hour trail ride and it was 90ish outside.
It's the perfect time of year, Somewhere far away from here.
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 09-07-2006, 11:30 PM   #3 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
DR, are you running a cooler?
I'm getting ready to plumb up my hydro system and debating if I really need a cooler or not.
I would think whether the systems have coolers or not would have a big effect on what the temps are.
Hoarder of Land Cruisers, wheeler of none.
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 02:17 AM   #4 (permalink)
k5chevyblazer's Avatar
Member # 16358
Send a message via ICQ to k5chevyblazer Send a message via AIM to k5chevyblazer Send a message via Yahoo to k5chevyblazer
I was thinking of adding an A/C condensor to my hydro steering setup. not only to cool it, but to also add more capacity. my truck drives fine when I first start it up and the fluid is cold. so I dont see how being "too cold" would make a difference.
Ryan Morgan
k5chevyblazer is offline   Reply With Quote Quick reply to this message
Old 09-12-2006, 10:53 AM   #5 (permalink)
RufftyTuffty's Avatar
Member # 17867
HOWE reckon their systems run between 150-240
RufftyTuffty is offline   Reply With Quote Quick reply to this message
Old 09-12-2006, 06:27 PM   #6 (permalink)
X-Rated's Avatar
Member # 72707
the cooler the better or is there a warmed up temp that works better?
Old 09-12-2006, 09:08 PM   #7 (permalink)
mrtwstr's Avatar
Member # 12370
IIRC 80ish is minimum recomended, but I'm not real sure. I looked into this a little when hydro assist first hit the desert car scene and I was switching all our cars over. But that was a looooong time ago.
Minimum temp is no problem, it will get warmed up enough quick.
Keeping it cool is the hard part.
FWIW... I think 280 is really getting warm, 300+ is time to let-er cool off.
I'M the real Dan Black!!!!
mrtwstr is offline   Reply With Quote Quick reply to this message
Old 09-12-2006, 09:32 PM   #8 (permalink)
Member # 1234
no cooler installed right now... I had one but I put a hole in it. I expected to see soaring temps now that I got that gauge installed... but it NEVER went over 165* I run GM power steering fluid.
Old 09-12-2006, 09:50 PM   #9 (permalink)
Member # 56097
whats the actual boiling point of PS fluid?
edit: apparently its pretty hot or doesnt matter, i just googled it and found two msds one for valvoline and one for phillips 66 that said na for boiling point.
bigrippen is offline   Reply With Quote Quick reply to this message
