Tall unsupported shock towers/hoops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-18-2006, 06:43 PM   #1 (permalink)
Member # 6848
Hi guys. I'm trying to design some shock towers or hoops for a rear coilover application. Because of some design limitations I can't support the top of the hoop at all. So I need to figure out how I can hang these off of my frame, go out and up and be able to have something strong enough to handle me completely beating the shit out if it (high speed jumps, etc.).
So I was hoping somebody would be able to post up some examples of what they have done and how well it's held up. If you can also tell me what kind of driving you do, that will help me gauge your your response.
Thanks all!!!!
Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 08:19 PM   #2 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Posting a pic of your "limitations" might help others give you some ideas. Your question is rather vague.
Hoarder of Land Cruisers, wheeler of none.
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 08:50 PM   #3 (permalink)
crashinaz's Avatar
Member # 4669
Place the tabs on the underside of the hoop and mount your coilovers as close to the same linear plane as the hoop legs as possible... Essentially try to place the force being applied as close to the center of the hoop as possible. The further you move out from this center, the more you multiply the leverage being place on the top of the hoop... ie: Try to get away with the absolute least "up and out"... After that, go to town on your gussets. Other suggestions... BUMP STOPS. Shock bottoming puts some serious abuse on hoops and tabs.
crashinaz is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 09:12 PM   #4 (permalink)
Member # 6848
Thanks guys. I don't have any pics but basically I need to come up off of the frame a good 15 to 18" and not support the top of the hoop at all.
Shock alignment is a good point and I will pay special attention to that.
I'll be running bumpstops for sure to make sure that I don't kill the shocks.
Thanks for the replies.
Jack
71 1-ton EB
BITD 7200
Old 09-19-2006, 03:01 AM   #5 (permalink)
nissancrawler's Avatar
Member # 76684
I would be running limiting straps, too.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 08:21 AM   #6 (permalink)
Member # 26216
Send a message via Yahoo to Gummi Bear
Can you put some support bracing off of the tubing you used to support the front clip when you removed the core support?
That's what I'm planning to do with mine. I dumb lucked into a nice set of Fox shocks, and my F250 mounts aren't gonna work, so I'll be building a hoop and bracing it to the tubing. I'm also going to add a spreader or two across the motor to keep from squishing it in case of a rollover.
I consider myself a student of the game, it's just too bad I'm in special ed...
Gummi Bear is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 12:16 PM   #7 (permalink)
dane's Avatar
Member # 21948
Jack,
Can you go from the coilover hoop out to the cage instead of across to the other mount?? Dont know if this will have a cage in the back or if you are shooting the hoops up through the bed.
Dane
I WILL TRY BEING NICER IF YOU TRY BEING SMARTER.
dane is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 01:51 PM   #8 (permalink)
Member # 8228
Send a message via AIM to broncorob
Even if you can't support them at the top of the hoop, try to build a 3rd dimension into it even if it is on the lower sections of the hoop "legs"
Rob Ellis
broncorob is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 03:59 PM   #9 (permalink)
Member # 6848
This isn't for my Bronco. I setup my cage to have tie-ins for the hoops for support.
Also, an engine crossmember and such is exactly what I can't do. That's my design limitation.
At this point I'm planning on using some 3/8" plate that is turned perpendicular to the frame for strength. It will have attachment to muliple dimensions of the frame (top and sides) for extra strength.
I was hoping somebody had some pics of what they had done in the past but I think in the new world of tube buggies this isn't such a concern anymore (who the hell would want to run a full bodied rig with a back seat anymore?
Anyway, thanks guys for the help.
71 1-ton EB
BITD 7200
