Anyone Tubed a tire ran on a beadlock ?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2006, 03:15 PM   #1 (permalink)
Pdaddy's Avatar
Member # 8133
Tips ? Im assuming that running higher than regular tire pressure would be required as well (not pinch the tube??)
Im financially being forced into this situation
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 03:36 PM   #2 (permalink)
welndmn's Avatar
Member # 398
Huh?
Are you asking is anyone ever ran a tube inside a beadlock wheel?
Yes I have, a few times
Mark
Old 09-26-2006, 04:19 PM   #3 (permalink)
scatterbrain's Avatar
Member # 19933
you can tube a hmmwv rim without a beadlock insert in it
Frank
'85 Yota Truggy-350 TBI,Turbo 400, Stak 5.44:1, D60s
scatterbrain is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 06:02 PM   #4 (permalink)
Pdaddy's Avatar
Member # 8133
Originally Posted by welndmn
Huh?
Yea man thats what I was asking... How long have you ran em like that ?
Old 09-26-2006, 06:20 PM   #5 (permalink)
Blase's Avatar
Member # 63692
I have a Buddy that runs 35MTR's on Bart doulbe bead lock wheels and a tube in one side. He ripped the tire at the bead the lenght of a fist ! He airs down like normal with no problems that i no of. I Think he has made three or four trips like that.
Blase is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 08:28 PM   #6 (permalink)
Pdaddy's Avatar
Member # 8133
Thank you , no one else reply please
Old 09-26-2006, 10:07 PM   #7 (permalink)
Danger Ranger's Avatar
Member # 1234
no... I want to tell you how special I am too
I've run two beadlocked 42 tsl's with tubes for a couple years now
It's the perfect time of year, Somewhere far away from here.
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 09-27-2006, 08:36 AM   #8 (permalink)
welndmn's Avatar
Member # 398
DR even bought my tubes, I think in 2 of the tires
Yes, I have put in the hummer rims to, With PCV locks, and drilled a hole for valve stem.
I have not personally put them in a mag lock, or Deans new cage locks though.
Mark
Old 09-27-2006, 08:58 AM   #9 (permalink)
shelljeep's Avatar
Member # 7352
I'm the buddy Blase referred to earlier.
They are actually 37" MTRs. I was wedging into an undercut and the sidewall ripped away from the bead. The bead stayed under the lock ring. It's a huge gash. And noone likes a huge gash.
I don't plan to replace the tire. I'll just replace the tube when I need to. Which isn't often. I've only had the tube pop one time, that was when it come in direct contact with some rock. I never pay it any attention, haven't changed my lines at all.
Brian (High5) brought up a good point when the tube popped. He pointed out how much less abuse the inside of a tire sees, compared to the rock rash that the outside of the tire gets. Check out your tires, it's true.
So... I swapped the tire on the rim so that the the gash was on the inside, and called it good.
I'll never carry a spare tire again. Tubes rule. Welndmn will hook you up with the right stuff.
Always workin' on it or at it.
shelljeep is offline   Reply With Quote Quick reply to this message
Old 09-27-2006, 09:16 AM   #10 (permalink)
Pdaddy's Avatar
Member # 8133
Gots tubes, putting them in tonight.
Thanks guys. I was just curious if it was a waste of time or not. Im kinda amazed the tubes arent getting pinched or whatnot from the damaged tire. I put some cheap patches on the inside of mine so the tire wouldnt spread and pinch the tube just in case. Im lookin forward to some Tube wheeling this weekend
Old 09-27-2006, 09:17 AM   #11 (permalink)
Member # 1234
yup both tubes are from well done man
Old 09-27-2006, 09:56 AM   #12 (permalink)
welndmn's Avatar
Member # 398
They get pinched or over streched if you have the wrong size, or a crappy tube.
The normal tubes you buy at walmart suck.
Mark
Old 09-27-2006, 10:01 AM   #13 (permalink)
Member # 1234
yeah I turned mine around... the first one I didn't for about a year and the tire just wears away around the slash... duh.
here's what it looked like a bit after I first booted & stitched it... this was a *3 finger* size slash btw
here's what it looked a year or two later :banghead:
so yep, run the slash on the inside :banghead:
Old 09-27-2006, 10:03 AM   #14 (permalink)
Member # 1234
put a real boot on the inside of the tire with the tube... you will blow the tube out if you don't. I've blown two tubes... one was due to my tire spinning in a loose beadlock and the other was because my boot gave out and allowed the tube to get pinched...
Old 09-27-2006, 10:38 AM   #15 (permalink)
Pdaddy's Avatar
Member # 8133
OK so were would I get a boot for a 38 before Friday ??
Old 09-27-2006, 03:37 PM   #16 (permalink)
Member # 1234
well done man sells them... http://www.welldonefab.com/products.htm
I just went into a local tire shop that did big tires etc and starting asking questions... they sold me everything I needed.
Old 09-27-2006, 05:07 PM   #17 (permalink)
Member # 76834
any farm implement repair shops will have everything you need including the tubes ive got a gashed 40 bogger that i boot patched stiched and tubed on 15 inchwide beadlocked wheels and i run 2-5 psi 4 years running only problem ive had is running down pavment at 50 with that type of presure for extended period will get the tire hot and melt the glue and eventually pinch the tube but aired up no problems on road even
BIGBADJMY is offline   Reply With Quote Quick reply to this message
