Dana 135? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2006, 10:28 PM   #1 (permalink)
Member # 23853
Send a message via AIM to DarkEternal Send a message via Skype™ to DarkEternal
Dana 135?
Someone asked me about one and I realised all i know about them is they exsist in some F550+ and similar vehicles. Not interested in using one for anything but am curious about it
What size ring gear?
Pinion Splines?
Axle shafts?
Anyone have pictures?
DarkEternal is offline   Reply With Quote Quick reply to this message
Old 10-02-2006, 10:39 PM   #2 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
https://www.fleet.ford.com/truckBBAS...cifications%22
Scroll down to the semi-detailed rear axle specs..
10.50" ring gear full floating
1.5" max dia. axle shafts , 32 spline
13,500 lb load capacity
4.00" dia axle tubes , .390" wall
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 10-02-2006, 10:40 PM   #3 (permalink)
onetoncv's Avatar
Member # 2160
I think the ring gear is rivited to the carrier on that one -Its a friggin huge monster- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 10-02-2006, 11:07 PM   #4 (permalink)
Member # 23853
So the ring gear is actually smaller than a 80 as well as shafts - odd.
Old 10-02-2006, 11:19 PM   #5 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I thought so too... but that is straight from ford specs. It could be wrong though. ill try to find a second source
Old 10-03-2006, 08:59 AM   #6 (permalink)
Member # 4438
Detroit shows the shaft as 1.86", 36 spline. Which would make it the same spline contour as the 14 bolt, rather than the finer spline of a 1.5", 35 spline axle.
Those who dare, win.
afecko is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 09:10 AM   #7 (permalink)
Valley Auto's Avatar
Member # 78079
I think if you look at the wheel bearing size there a lot bigger than most 1 ton stuff
Master of the wire Wheel!
Valley Auto is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 09:28 AM   #8 (permalink)
Member # 3906
Send a message via AIM to Jeepmangled87
any pics of one??
Jeepmangled87 is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 11:33 AM   #9 (permalink)
Member # 4243
Mid '03 it switched from the 135S to a S110. I'm having trouble finding facts on the ring 135S, but it may be as large as 14.24".
The S110 specs are here:
http://www.roadranger.com/Roadranger...xles/index.htm
another discussin thread:
http://www.thedieselstop.com/archive...o=&fpart=1.htm
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 02:34 PM   #10 (permalink)
Member # 3152
Send a message via AIM to Trango Send a message via Yahoo to Trango
Peek any F450 or F550, look for the sheetmetal housing, and boom, there's your axle. Swing by your ford dealer, and look at the biiig F series cab and chassis trucks.
Found some on google.
http://community.webshots.com/album/173234179mdhPJE
Compulsive vehicle builder
Trango is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 04:07 PM   #11 (permalink)
bigtoyfreak's Avatar
Member # 9550
F550 = Dana 135
F450 = Dana 80
bigtoyfreak is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 05:12 PM   #12 (permalink)
Member # 4243
Old 10-03-2006, 06:55 PM   #13 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
That sounds more like it. Looks like the ford specs i pulled up were mis-listed
Old 10-03-2006, 07:02 PM   #14 (permalink)
Kaiser5's Avatar
Member # 26472
My '99 Winnebago, which is built on the Ford chassis, has the 135 out back. Its big. Mine came with factory 5:38s, finned aluminum diff cover, disk brakes and some bigass wheel bearings.
[COLOR="Silver"]'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating.
'82 -'8 As stock as it gets...[/COLOR]
Kaiser5 is offline   Reply With Quote Quick reply to this message
Old 10-03-2006, 07:16 PM   #15 (permalink)
Member # 4243
Thats a Dana 80 then The others look like an overgrown 9" from the back (i.e. no diff cover).
Old 10-03-2006, 07:23 PM   #16 (permalink)
Member # 73059
http://www.dana.com/commercial_vehic...F_G-series.pdf
Rockhales is offline   Reply With Quote Quick reply to this message
