Acceptable ratio difference - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-12-2006, 07:27 PM   #1 (permalink)
cdhicks99's Avatar
Member # 77032
Money concerns have got my plans changed temporarily, so I am going to have to reuse my rear axle which has 4.63 ratio. My problem is that I have a D44 for the front and gears jump from 4.56 to 4.88. Are either of these acceptable?
'94 NISSAN PATHFINDER cLE
3" susp. lift, Pro-Comp 3000's in the rear, lsd rear, IAB, 15x8 Rock Crawlers, 32x10.5 TSL's.
D44/F9 w/ 4-links F&R coming soon!
cdhicks99 is offline   Reply With Quote Quick reply to this message
Old 10-12-2006, 07:32 PM   #2 (permalink)
Typical White Guy
Member # 9769
I have always 'heard' that 2% difference is the limit. So based on that, the 4.56 gears at ~1.6% difference would be within the acceptable range. 4.88's are too far off. A lot of that probably has to do with the type of terrain you wheel and how much 'slip' it allows to avoid binding.
________
Fix ps3
Indyguy is offline   Reply With Quote Quick reply to this message
Old 10-12-2006, 08:55 PM   #3 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
with 4.56's in the front your front axle will be dragging your rear axle. with the 4.88's your rear will be pushing your front. but alot of people run 5.38's in a d44 front and 5.29's in a toy rear.
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote Quick reply to this message
Old 10-13-2006, 12:56 PM   #4 (permalink)
nissancrawler's Avatar
Member # 76684
many manufacturers (I know our nissans don't) run a slightly higher gear ratio in the front to make them faster, and turn better. I.E 4.09 front with 4.11 rear. If it was me, I personally wouldn't do any of that. If you're going 35's or more, you're going to have no power at all. I would recommend gearing the back right, and driving it 2wd until you have funds for the front gears. I'm going to be doing that on my build, to get it on the road.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 10-13-2006, 03:22 PM   #5 (permalink)
Member # 187
4.63 and 4.56 work fine
[FONT="Arial Black"][SIZE="5"][/SIZE][/FONT]
:flipoff2:
GearMan is offline   Reply With Quote Quick reply to this message
Old 10-13-2006, 06:11 PM   #6 (permalink)
krawlfreak's Avatar
Member # 56418
it's not ideal but it should work fine
jeremy
________________________________
K.O.H. competitor #797
OG 13
thanks to :
Trick Toys Fabrication
Lindsey Trucking
P.W.T racing
krawlfreak is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 06:28 PM   #7 (permalink)
bremen242's Avatar
Member # 28687
I ran 3.27s in front of my beater and 3.50s in the rear.... worked good in mud; however, t-case made some weird sounding noises on hard-pack... wouldn't run it under a lot of HP..
bremen242 is online now   Reply With Quote Quick reply to this message
