Pirate4x4.Com : 4x4 and Off-Road Forum (/forum/)
-   General 4x4 Discussion (https://www.pirate4x4.com/forum/16-general-4x4-discussion/)
-   -   another hydroboost ? (https://www.pirate4x4.com/forum/general-4x4-discussion/54140-another-hydroboost.html)
The Jerk 05-13-2002 12:54 AM
ok so the line that comes off the large resivor(front brakes) is 3/16ths and the line for the rear is 5/16ths ( i belive) now given this set up came out of a cadilac would it matter if i ran 3/16ths line for everything? i say this because A: i have 25 feet of 3/16ths line, and B: the lines that run off the t on the rear housing of my 70 or 3/16ths. other specs = 60 front disks, 70 rear drums. thanks for any advise. jiMMy
brainless 05-13-2002 07:30 AM
the reason they did that is because it uses drums for the rear and drums require more volume to operate hence the larger line for the rear . if you run 3/16 to the rear drum they will work but might be a lilttle mushy , if you ever plan on going to disc in the rear use the 3/16
The Jerk 05-14-2002 12:19 AM
gracias allen, i was just making sure before i went and did this, and yes one day it will be disk rear. off to napa to gather all my fittings! jiMMy
