20" rims??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-29-2007, 07:08 PM   #1 (permalink)
Member # 57010
20" rims???
I was wondering what you guys ran for 20" wheels (preferably beadlocks) on your trail rigs. I am trying to find something light but strong. Any one run stazworks double beadlocks? how much do they weigh? I am running a dana 60 and 14 bolt so i need the eight bolt pattern and i wanna run some 49 IROKS.
redneckryder84 is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 08:50 PM   #2 (permalink)
Fl-Krawler's Avatar
Member # 47337
i have 49" iroks on 20x14 trail ready beadlocks.... i have them in a rockwell lug pattern though.. i've only got a few light duty runs on them but i am happy with them so far.. i think they weight around 75-80lbs each
Fl-Krawler is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 08:54 PM   #3 (permalink)
jrod66's Avatar
Member # 42436
same here, 20x14 usa6x6 wheels double beadlocked with 49" Irok's, beat on em pretty good, they are heavy but no problems with bending or leaking, except where the rims bolt together, but for the price (200.00 bucks each) they are great, wheel and tire combo weigh in at just under 250 lbs each
BLOODY STUMP WHEELERS
jrod66 is offline   Reply With Quote Quick reply to this message
Old 01-30-2007, 06:08 PM   #4 (permalink)
Member # 57010
how wide a wheel do you think i would need for the new 54" boggers???
Old 01-30-2007, 06:29 PM   #5 (permalink)
Fl-Krawler's Avatar
Member # 47337
i think that comes down to personal preference, and the type of wheeling you do.. i like the extra width that my 14's give my rig, and while my rig does sit stupid low for what size tires it has its still tall..and the wider stance gives it stability..there are some that will say that this is just too wide and that a 10" wheel is perfect.. i have 4 wheel steer and with a healthy small block , rockwells and 49's i can pretty much make the buggy fit into any hole i try to put it in
Old 01-30-2007, 06:47 PM   #6 (permalink)
MUCHADO's Avatar
Member # 21752
Send a message via AIM to MUCHADO
http://muchadoproductions.com/forums...ead.php?t=1184
Pdaddy from here is sellin a set of 20's and 41" michelin military tires...
MUCHADO is offline   Reply With Quote Quick reply to this message
Old 01-31-2007, 07:20 AM   #7 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
factory mogs, weld on lock kit from Great lakes off road, inchworm screws on the backside. (note the rubber washers on the screws have been removed because they leak.)
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 02-04-2007, 06:21 PM   #8 (permalink)
Member # 57010
how do you figure out the backspacing you need to keep the inside of the tires from hitting the frame when flexing and also how do you figure it out to keep the tires out of the radius arms?
Old 02-04-2007, 09:11 PM   #9 (permalink)
Member # 31972
I would recommend going out and spending some time looking at your rig to figure this one out. I've seen 35s rub the frame (narrow track CJ) just by turning the steering wheel. However, 49s might hit your frame rails with 'reasonable' backspacing on a D60 when you simply turn.
So, the real question is, how flexy is your rig? With 49s, I bet if your rig flexs well, you'll rub somewhere. Just remember your sawzall is your friend. Try moving your rig around with whatever you have currently, and then use a tap measure to extend your tire size and see what hits. After that, take a guess on your current backspacing, and then order your wheels.
Staz's stuff is considered top notch. Also, remeber you can vary the backspacing with wheel spacers if you really mess it up.
willyCJ is offline   Reply With Quote Quick reply to this message
