dana 44 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2007, 10:09 PM   #1 (permalink)
Member # 86513
dana 44
i was just trying to find out if the locker out of a ford dana 44 would fit in a chevrolet dana 44? ihave some people saying yes and some saying no can anyone tell me, i got more maybe than anything thanks for any help
georgeofjungle is offline   Reply With Quote Quick reply to this message
Old 02-05-2007, 10:15 PM   #2 (permalink)
Member # 13786
As long as the gear ratio for the carrier is correct
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 02-05-2007, 10:15 PM   #3 (permalink)
Member # 31972
Well, Tuesday it is....
The answer is 'maybe'. What gears are in the ford vs. what gears are in your axle? The D44 locker has a large and small carrier which splits between 3.73 and 3.92 gears. After that you have to worry about the spline count on the chevy vs. ford shafts. Odds are that the spline count is different, but you might get lucky.
willyCJ is offline   Reply With Quote Quick reply to this message
Old 02-05-2007, 10:42 PM   #4 (permalink)
Member # 86513
dana44
okay i should have said this earlier they are both 3/4 tons with 4:10 gears
Old 02-05-2007, 10:59 PM   #5 (permalink)
Member # 70321
'Sounds like you're in luck.
You'd be best served by buying a Pirate Red Star. This will enable the search function for you and enable you to do some research. It's the best $20 you'll ever spend.
Happy Tuesday.
Dunn-Edwards Paint
"The #1 Choice of Painting Professionals"
soilantgreen is offline   Reply With Quote Quick reply to this message
Old 02-05-2007, 11:17 PM   #6 (permalink)
jrod66's Avatar
Member # 42436
Happy Tuesday.
x2, you will find more information here than in all of the back issues of all the rags combined, and that 20.00 bucks spent here is a whole lot cheaper than the rag subscriptions, so donate the 20 and search, as far as your question goes since they both have 4.10's check the spline count, if they are the same, you should be in luck.
BLOODY STUMP WHEELERS
jrod66 is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 01:00 AM   #7 (permalink)
Member # 37770
Send a message via AIM to 93chico4by
i am confused, i know early d44s had 19 splines, but aren't most d44s 30 spline?
Bronco Foot - '84 BroncoII 5.0/C4/Atlas D35 TTB/8.8
93chico4by is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 03:46 AM   #8 (permalink)
bronco69drp's Avatar
Member # 36795
yes it will fit. any D44 carrier will work in any D44.
yes there is a different carrier for ratios 3.92-5.89, but they all use the same carrier bearings & all have 30 splines. this applies to both front & rear axles.
check out this link for more info: http://77cj.littlekeylime.com/web_rs44.html
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s
bronco69drp is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 06:56 AM   #9 (permalink)
Myanarchy's Avatar
Member # 14059
He didn't indicate if it was a hi-pinion axle or not, if thats the case then he is shit out of luck
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 09:20 PM   #10 (permalink)
Mr.N's Avatar
Member # 1635
How so?
The carrier works in HP or LP, it's the split that matters. That and if you've really old axles or a locker, coarse splines dont' work in fine splines.
But, but the split...Ok, ok... but the ICA is not seen that often... but just to cover myself.
Model 44 3.73 and Down 3.92 and Up
Model 44 ICA 1984 & earlier 3.73 and Down 3.92 and Up
Model 44 ICA 1985 & later 2.87 and Down 3.07 and Up
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
