adding water to tires - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2007, 05:59 PM   #1 (permalink)
Member # 66588
was wondering about how people went about putting water in tires for weight.do you fill thru the valve stem,or drill a new hole and use some sort of nut and bolt with sealing washers?
88 toyota 4runner 39 irocs and some other stuff
gttowhlr is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 06:07 PM   #2 (permalink)
Member # 50123
SEARCH RETARD .....This has been covered many....many.....many....many times.......... Oh and if you are gonna ask how to search pay the $20 bucks , or use google.
ProJunkRacing is offline   Reply With Quote Quick reply to this message
Old 02-06-2007, 07:30 PM   #3 (permalink)
Member # 66588
why waste your freaking time to post that.your the retard.
Old 02-06-2007, 07:32 PM   #4 (permalink)
Member # 50123
No your the retard this is GEN 4x4 . Get a star and search .. Oh I forgot it's Tuesday.....
Old 02-06-2007, 07:44 PM   #5 (permalink)
Member # 66588
tryed searching on google didnt come up with what i needed genius.
Old 02-07-2007, 12:41 AM   #6 (permalink)
Member # 22492
Water doesn't work... it freezes, and it corrodes the shit outta everything...
Industrial, and farm applications have liquid calcium pumped into tires... they typically pump it right in through the valve stem. They have a special pump for doing this usually... go to a tire shop... ask them about the details and how much.
YJ all chopped up... and a pile of parts...
mUD uCKeR is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 01:16 AM   #7 (permalink)
crawlin'YJ's Avatar
Member # 7958
Water can work, If you're in a cold climate add a little anti-freeze.
ProJunkRacing is just mad cause he is for strokeddodge and no one listens to him.....
crawlin'YJ is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 01:58 AM   #8 (permalink)
Member # 17103
water? wtf? Green jello, i wouldnt run anything less than green jello in my tires... they deserve better than that.
"Redneck, white socks and blue ribbon beer"
Copenhagen is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 03:06 AM   #9 (permalink)
Pook's Avatar
Member # 3370
I went with the red jello, added some marshmellows now I got a trail snack when I blow a bead been all good so far.
:grinpimp:
Pook is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 06:12 AM   #10 (permalink)
Member # 50123
Shit nigga I got sick of posting in there so I just gave up . He's just a friend that's all . Wish I woulda Never posted anything in there. lol Oh well .
Old 02-07-2007, 09:50 AM   #11 (permalink)
Bushwhacker's Avatar
Member # 9138
Send a message via ICQ to Bushwhacker
Any tricks to getting the antifreeze in? My tires are solid ice now. I have the farm adapter for the hose, but need a way to pump the antifreeze in now. Maybe some kind of bug sprayer attachment or car wash cup that would thread onto the valve and the hose??
WEROCK Judge
RROCK Legends Competitor
97 TJ buggy,4.0,727,Atlas,D60,14B
Bushwhacker is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 10:11 AM   #12 (permalink)
Member # 50123
That Sucks man ....
Old 02-07-2007, 10:33 AM   #13 (permalink)
Member # 15404
It carodes far worse than water. You have to run tubes to run calcium. They make products like rimguard that work without a tube and are biodegradable.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 11:33 AM   #14 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
Bushwacker...search for posts made by me on this subject. I went through that easy/FAST/cheap way to do it on a number of threads.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 12:34 PM   #15 (permalink)
GaryTJ's Avatar
Member # 36995
lay the tire on the ground. break the outer bead. pour it in and air it up....
Life is not about a pretty body, it is about sliding in at the end, all used up and worn out, going "Man, what a ride!"
GaryTJ
GaryTJ is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 01:52 PM   #16 (permalink)
Member # 9138
Thats too much work.
Dustin found your parts list to make the adapter, but nothing about getting antifreeze in there yet.
Old 02-07-2007, 05:29 PM   #17 (permalink)
Gunmetalcruz's Avatar
Member # 6569
I can't take the credit for the antifreeze idea but here what we did. I hooked the hose to the adapter on the rim ran the hose up hill, slide a funnel into the hose and added about a gallon and a half of antifreeze before the hose was full. Pulled the funnel, hooked up the water and flushed it thru. Simple and free. With 35 gallons with 1.5 galloons of antifreeze down to 0 degrees so far this winter and no ice blocks yet.
Team FOH# 321
Gunmetalcruz is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 05:37 PM   #18 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
We had a tire on the farm-front of an old farmall-cracked to hell and would not come off the bead. It finally blew apart one day on the road....filed with concrete
actionpaintball is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 07:12 PM   #19 (permalink)
Member # 83614
would anyone like to see the valve stem cap-dipstick i made for checking the water level in my tires?
when in doubt, floor it!
brownsmetal is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 08:35 PM   #20 (permalink)
Member # 9138
Good idea, I wonder if a short cutoff piece of hose and funnel would work, or if the water pressure is needed to get the antifreeze to go through the adapter.
Old 02-07-2007, 09:25 PM   #21 (permalink)
Member # 6569
seemed enough to fill the hose and have the water level lower then were it will end up when finished. Flushed it thru and rotated the stem to the gurgle point that I was shooting for as the "full point"
Team FOH# 321
Old 02-07-2007, 09:29 PM   #22 (permalink)
Member # 68765
Send a message via AIM to King7765
Plumbing shops sell a hand held transfer pump for pumping antifreeze into boilers.
-You pour the anti-freeze into a 5 gallon bucket.
-Hook one end of a double female ended hose to the pump and the other end to the adapter on the rim.
-Pump away...
I've used it a couple of times and can take a picture of it if you want to see what it looks like...
My dad and I use it to pump biodegradable antifreeze into snow-melt radiant heat systems in concret sidewalks and patios for rich people... The snow-melt loop is separate from the boiler loop via a heatsink (actually I can't remember what it is called, its not a heatsink....damn brain farts)
TTYL
-Adam-
94 Ranger on 42's
My thread
King7765 is offline   Reply With Quote Quick reply to this message
