Axle Identification - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-07-2007, 02:54 PM   #1 (permalink)
Member # 86620
Send a message via AIM to chevymudtruck
Axle Identification
anyone help me out in figure out what I have here . . . 10 lug and the planetaries are 17 1/2 inches across
numbers that I have found on it . . on the back of all 4 wheel fanges is LCC1 and 106740 and a B with a circle around it . . . on the axle tube of the non steer axle there is 10_229 where the space is the number is smashed maybe 6 or 8 or something . . and then on the bolt on steering arm (bolts on the top with 4 bolts and tierod goes to) has 106289
anyhelp is appreciated
chevymudtruck is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 02:58 PM   #2 (permalink)
72cj's Avatar
Member # 23802
an unbreakable axle...
sh!t what did thoes come out of?
72' cj5 full width 1 tons linked front and rear
98' LT1 SM465 NP205 ARB on 44's
04'Cummins on 20's and 37's TST lots of black smoke
Less Flower Power
More Fire Power
72cj is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 03:02 PM   #3 (permalink)
Member # 3152
Send a message via AIM to Trango Send a message via Yahoo to Trango
Clark tractor? Those are planetary housings from an implement with dry brakes. Could be a tractor, a crane, something. Definitely off highway, and probably heavier than shit.
Compulsive vehicle builder
Trango is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 03:07 PM   #4 (permalink)
Member # 86620
well on my f350 tow truck with extendable boom, and it extended and picking one up at a time front wheels almost come off the ground . . so yeah I'd say they are heavy .. . also they are 8 and half feet wide from end of planitary to the other . .
and I don't know what they came out of that's why I'm trying to identify em . . needa find wheels for em and if I need any parts . .
Old 02-07-2007, 03:31 PM   #5 (permalink)
Member # 3152
So where did you get these?
You should be able to find wheels that fit this at an implement shop, but I'd say that you'll probably be going custom, and I mean VERY custom, in that you'll likely want to make your own centers and weld them into wheel shells.... which is really very straightforward, FYI.
Um, so am I under the correct impression that you are going to use these for something?
Old 02-07-2007, 04:04 PM   #6 (permalink)
Member # 86620
yeah I found a wheel that'll fit over the planitary . . but lug pattern is aobut half inch to small . . so probably will have to get centers made. . 25 inch wheels . . and yeah I plan on using em on my chevy truck
here is the one wheel that I have that don't exactly fit . . in comparisson to the 38.5x16x16.5 TSL . . .
Old 02-07-2007, 06:36 PM   #7 (permalink)
Go_Vols's Avatar
Member # 12691
so, you lifted one with a davit crane on the back of your F350 and you said it lifted the front tires off the ground... and you're going to use these on an offroad vehicle? I'm not sure I get it... going for bulletproof is one thing, but going for USS Ronald Reagan's ship anchor is quite another...
"Lil'T" - 99TJ RC60/14B/Klune 4:1/Atlas 6:1/H1/44"TSLs/PSC Full-Hydro...
Rollover Ratio = 1.0:3
Go_Vols is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 06:45 PM   #8 (permalink)
Member # 84738
They might be heavy, but you know you won't break them. Know what they have for gears?
'98 Durango: 60/44, not done pos
'91 Suburban: DD, 350/4L80
durcrim is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 06:55 PM   #9 (permalink)
Member # 31352
those look very similar to what the monster trucks are running. Those may be a wee bit heavier tho.
TheRamChargerMan is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 07:11 PM   #10 (permalink)
Member # 18233
what in the hell size tires are you planning to run? 66 in. terra's ? i think that would be minimum for that axle. otherwise get some 2.5 rock's with 2 in. shafts or u 1300's and call it good. good luck
84 GMC k5 jimmy pontiac 455 60/14b. detroit/spooled 5.13's 44 in.boggers R.I.P
84k5bd is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 07:28 PM   #11 (permalink)
Member # 41097
The 2 things that they may of come out of that i would think would be either an airport tug or a fwa tractor. The wheel type and shear size suggest a larger fwa (front wheel assist) tractor.
mustange70 is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 08:13 PM   #12 (permalink)
Member # 84570
I would think they would be geared too low to be useful in an offroad truck.
redzj is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 08:13 PM   #13 (permalink)
Mr.N's Avatar
Member # 1635
Need pics of them installed for sure!
I'd check Eaton web page, seach for numbers and call the tech line. If they didn't make them they might have bought the company that did.
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 08:23 PM   #14 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
They look really heavy... like 1,500 - 1,800 lb each heavy.
Lets see the truck they're going under and what are you going to be doing with it? Im guessing mud
BTW.. Is that an old military winch on your trailer? It looks similar , but slighty smaller , to a 20,000 lb winch I have that came off of a 5 ton cargo.
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 02-07-2007, 10:18 PM   #15 (permalink)
Member # 41097
I'd try ZF axles as well.
Old 02-08-2007, 05:24 AM   #16 (permalink)
Member # 86620
lets see . . . not sure what gears are en em . . was thinking babout pulling the planitaries apart check that gear and pulling the 3rd member out and finding out the gear there, and what size axle shafts. . but dunno if i'd ever get it back togeather lol . . . . a guy I know runs wild hair monster truck and he's running like 5.87 in the third member and 3 to one at the wheels so if it's close to that I'll be happy . . . also his planateries are only 13 1/2 inches acrros so mine are 4 inches larger across . . . .and yeah heard the f106 ps115 combo alot of the monster trucks run weight 1500 - 2000 lbs but heard up to 2500 lbs a peice as well . . . thinking of running either 69 - 73 tall tires. . .probably play mostly in the mud . . . .
also I got em because I got tired of braking my dana 44 front with 44x18.50 tsls . . . you think I went overboard? . lol . .
as for the winch not sure what size . .either 20 or 40k . . . looks real simular to the ones on my f600 wrecker which are dual 40's . . . all 3 are chain driven . .and the winch on the trailer use to have 3/4 cable on it but was barely enought to reach the back of the trailer so took and spooled up about 350 ft of 3/8's
Old 02-08-2007, 08:25 AM   #17 (permalink)
Member # 3152
No. I mean, you could have found the axles on that big ass movable island that transports the Space Shuttle from scaffolding to launch pad. I'm sure those are just a little bigger.
Seriously, these will require, IMO, tires in the 50"+ range at the minimum, and possibly 60" range.
Bob
Old 02-08-2007, 08:50 AM   #18 (permalink)
Member # 86620
Bob
like I said . .atleast 66 but was eyeing some 69's or maybe even 73's would be sweet . . lol
btw best I can figure so far they are aobut 20 ton axles *shrugs* . .
Old 02-08-2007, 08:54 AM   #19 (permalink)
Tech Tim's Avatar
Member # 19067
That'll end up on someone's sig line....
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Tech Tim is offline   Reply With Quote Quick reply to this message
Old 02-08-2007, 12:00 PM   #20 (permalink)
Member # 86620
lol hey big enought tires and will float and tug-a-war with a ship . .
