D60 Rear Disc Caliper Supports - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-24-2002, 02:15 AM   #1 (permalink)
REDDMANIAC's Avatar
Member # 5733
Id like to know what everyone is using for Caliper Supports on their D60 rear disc conversions. I would like a bolt on bracket so Im hoping the chevy 1/2 ton calipers supports will do.
REDDMANIAC is offline   Reply With Quote Quick reply to this message
Old 05-24-2002, 02:36 AM   #2 (permalink)
Member # 8907
Homemade caliper brackets. The type of dana 60 you have will play a bit of a factor. If you don't understand, then call TSM and pull out the plastic.
TJBob is offline   Reply With Quote Quick reply to this message
Old 05-24-2002, 02:37 AM   #3 (permalink)
Wilson's Avatar
Member # 7233
I don't know about bolt on brackets... but everyone I know is using some after market weld on backing plates. I used them on my 9", seen them used on a 14 bolt and a 60. No problems, real easy to use and they accept chevy 10 bolt calipers (Chevy bigs) adn Chevy IFS rotors. If I had a digi cam, I'd post pics. I got mine from Bent and Twisted 4 wheel drive 530-342-3003
Old 05-24-2002, 08:00 AM   #4 (permalink)
MT
Member # 2919
I used caliper brackets for big Chevy brakes from AFCO http://www.afcoracing.com/
Regards
MT
http://www.4wdfactory.com
MT is offline   Reply With Quote Quick reply to this message
Old 05-24-2002, 09:03 AM   #5 (permalink)
Member # 39
That caliper bracket doesn't look like any of the ones on the AFCO site. Do you have a part number for it? Does it position the caliper in the correct location for the 3/4 ton rotors?
Eric
Parts for Sale --> D44 shafts, 6 lug rims, air tank
Eric is offline   Reply With Quote Quick reply to this message
Old 05-24-2002, 09:07 AM   #6 (permalink)
MT
Member # 2919
Those are '79 Chevy 3/4 ton rotors mated to Dana 70 spindles.
Contact Matt at http://www.westtexasoffroad.com he sourced them for me from Philipe Automotive in San Angelo, TX he is an AFCO dealer. If I recall they were under $15 each.
MT
Old 05-24-2002, 09:20 AM   #7 (permalink)
Member # 4737
I used 1/2 ton backingplates that I had sitting around and cut the bottom off the braket so I had a C hole insted of a cirlce hole. The I just welded up the gap and welded it onto the axel. Been working great for 3 months on my dd/trail rig.
1989 Chevy Blazer 350 V8
4x4realm is offline   Reply With Quote Quick reply to this message
Old 05-24-2002, 09:27 AM   #8 (permalink)
Member # 39
Is that because the 1/2 ton brackets are for the smaller diameter 1/2 ton rotors so you needed to mount them a little higher off the axle to account for the larger diameter 3/4 ton rotor?
Eric
Old 05-25-2002, 09:40 AM   #9 (permalink)
Member # 4737
That's exactly the reson.
Old 05-25-2002, 07:30 PM   #10 (permalink)
tj7
Member # 6425
there is only one guy for this fawk tsm and everyone else sorry matt i do like your work but my boy shakerbuilt is the man....
http://www.shakerbuilt.com/
tell him the SICK canadian sent ya and he will give you a great deal on them....
tj7 is offline   Reply With Quote Quick reply to this message
Old 05-26-2002, 09:29 AM   #11 (permalink)
Member # 39
I will probably do something similar to what you did, but I do have the 3/4 ton backing plates so I just need to slip them over the spindle and weld them on. No lifting needed.
Thanks.
Eric
Old 05-26-2002, 11:04 AM   #12 (permalink)
REDDMANIAC's Avatar
Member # 5733
Thumbs up Thanks for al the great info!
Ive made up my mind & am going to get some 3/4 ton backing plates & calipers. I will post pics once I get done. Ill probably do like YJTJ did & get the DODGE rotors with the higher "hat" so that I can slip it over the hub rather than take the chance of any lugs coming loose & spinning in place whn I try yot remove lugnuts. TJBOB backatchabro!
