aluminum links - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2007, 07:00 PM   #1 (permalink)
Member # 80873
aluminum links
to the guys running home made aluminum links, is drilling and tapping the link ends strong enough or are the aluminum threads ripping out? also are you guys bending these links? thanks
bushauler is offline   Reply With Quote Quick reply to this message
Old 03-30-2007, 07:06 PM   #2 (permalink)
toykilla5150's Avatar
Member # 65463
You should check out "Project- Tt Hilux" that Dan Trout, the owner of Fishmouth Fabworks is biulding. He is running home made aluminum links. He has biult a couple sets for some friends of his. good luck
YOU CANT FIX STUPID PEOPLE only shoot them.
toykilla5150 is offline   Reply With Quote Quick reply to this message
Old 03-30-2007, 10:25 PM   #3 (permalink)
HeyBeerMan's Avatar
Member # 4830
What would be the difference between home made and store bought?
HeyBeerMan is offline   Reply With Quote Quick reply to this message
Old 03-30-2007, 10:28 PM   #4 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
He made his own barstock out of beercans.
& Blaine
:tank:
Old 03-31-2007, 12:20 AM   #5 (permalink)
Member # 80873
links
no difference between store bought or home made i just wasnt sure if they are just threading into the aluminum or using inserts of some sort.
Old 03-31-2007, 06:57 AM   #6 (permalink)
THE VOICE OF REASON
imagineer's Avatar
Member # 50419
ALuminum has a higher yield strength than mild steel, so the same can be said for the thread. The aluminum thread is stronger, but it is just not as robust as a steel thread. As long as your rod ends are kept in place with a lock nut and/or locktite (so they wont move and wear the threads) you will not have any trouble.
Aluminum
Tensile Strength, Ultimate 310 MPa, 45000 psi
Tensile Strength, Yield 275 MPa, 39900 psi
hot rolled 1018 steel
Tensile Strength, Ultimate 400 MPa, 58000 psi
Tensile Strength, Yield 220 MPa, 31900 psi
Murphy's Law Motorsports #816
Check us out on
OPTIMA BATTERIES, YUKON GEAR, RACELINE WHEELS, GRIFFIN , FLEXCON, BAJA DESIGNS, FOX RACING SHOX, HOWE PERFORMANCE, B.F. GOODRICH, MITCHELL DIFFERENTIAL, PRP SEATS, FIREBALL HEAT TREATING, JET LUBE, PAC RACING SPRINGS, KESSLER MACHINE.
imagineer is offline   Reply With Quote Quick reply to this message
Old 03-31-2007, 07:22 AM   #7 (permalink)
tennessee rockhumper's Avatar
Member # 52201
i have seen no issues with tapping threads, but i only run them for top links. i have seen some aluminum hex bar bent and cracked almost into a "U" after a nasty roll down a really steep hill, and the tapped threads were still fine.
tennessee rockhumper is offline   Reply With Quote Quick reply to this message
Old 03-31-2007, 09:03 AM   #8 (permalink)
I am very salty
FISHMOUTH FABWORKS's Avatar
Member # 43776
Send a message via Yahoo to FISHMOUTH FABWORKS
nope. threads are good as long as you tap them correctly. 7075 has a good memory. thell bend and spring back. mine are 2" 7075. 40" centers. the bar length is 35" so they are pretty stiff.
Dan Trout- Dave Halabuk RIP
Rage4th #76
FISHMOUTH FABWORKS is offline   Reply With Quote Quick reply to this message
Old 03-31-2007, 11:03 AM   #9 (permalink)
Member # 39371
Send a message via AIM to currupt4130
Aluminum
My tables show this (values in MPa)
6061 (heat treated and aged, T6 temper) yield strength 276, tensile strength 310
7075 (heat treated and aged, T6 temper) yield strength 505, tensile strength 572
2024 (heat treated and aged, T3 temper) yield strength 345, tensile strength 485
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote Quick reply to this message
Old 03-31-2007, 05:49 PM   #10 (permalink)
Member # 80873
aluminum
thanks for the input
Old 03-31-2007, 07:41 PM   #11 (permalink)
Member # 50997
What would be the advantage of using Aluminum?
MigMiester is offline   Reply With Quote Quick reply to this message
Old 03-31-2007, 08:03 PM   #12 (permalink)
Member # 5110
I think the biggest advantage is that it comes pre heat treated. If you wanted the same out of chrome-moly you would have to weld on bungs and then send it out to have it heat treated. With the aluminum you just cut to length, drill, tap, and go. Poly Performance does however sell some pre-heat treated chrome-moly link material.
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
