Building a rolling chassis have questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2007, 01:03 PM   #1 (permalink)
Member # 78123
I'm starting with a frame off of a 80's model chevy k10, I've boxed it in and I'm about to start building a four link with coils. Only thing is, if i get the rolling chassis finished, when i build the cage and put the engine and tranny and t case in, will that extra weight mess up the geometry of my four link since I built the suspension first???
05 Dmax, 78 C30, 83 K10 Cab
Rockwelled K10 is offline   Reply With Quote Quick reply to this message
Old 04-09-2007, 01:16 PM   #2 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
When you make the 4 link calcs.,if you don't know all of your weights and CG location, its all just a guideline anyway. The best thing for you to do in this situation will be to draw a FBD or a picture with estimated weights of things to come and thier location, then from that you can make a more accurate guess of the final sprung weight and the final CH height and lateral location.
If you are a slight bit off its not the end of the world... What wheel base are you shooting for? A longer wheel base with longer links will be less effected by off calculations than A shorter wheel base with shorter links.
Also, the front geometry is not as important as the rear geometry, so you can fudge a little to make everything fit if need be.
Im just up the road in Clemson, feel free to contact me if you have any trouble with your suspention design.
Schmozilla is offline   Reply With Quote Quick reply to this message
