Big Axle ID - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2007, 06:46 PM   #1 (permalink)
Member # 72929
Big Axle ID
I need some help here…
I found these axles in a junkyard, owner says he believes they came out of an old IH or Dodge 3TON? Truck, both have limited slip, gear ratio is about 6.17.
Front one is a Dana 70, closed ball yoke design.
Bolt pattern is 6 in 8˝”
Problem is the rear one, I don’t know what is it…
It looks like an old Eaton, but bigger.
Here lying in fornt a D60
Any help would get you at least a case of beer when you come over here...
carlosg_hn is offline   Reply With Quote Quick reply to this message
Old 05-12-2007, 06:51 PM   #2 (permalink)
Member # 29210
Send a message via AIM to Davethorik
I am not too familiar with the bigger Dodge stuff, but those axles look suspiciously like the axles under an old International S-Series 4x4 that our local township used to plow snow and spread salt. When I say S-Series, I mean their line of medium duty trucks made in the 80's, like school buses.
I never looked inside of those axles, but you should pop them open. Limited slips in old-style axles like that rear (and probably that front, too) says to me "No-Spin."
International did put an axle like that under some of their pickups, but I have never looked at one up close. They had an 11" ring gear and 1.5" coarse spline axleshafts, and a No-Spin was a factory option.
:laughing:
Davethorik is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 01:09 AM   #3 (permalink)
Member # 72929
Thanks Dave, I checked the IH data from Dana/Spicer and the 1 1/4 ton 1600 truck from 1967 to 1973 had the Dana 70 with 6.17 and the Powr-Lok.
http://www2.dana.com/pdf/X510-8.PDF
page 200
I hadn´t been able to find tech specs for that truck
Anyone?
Old 05-13-2007, 01:26 AM   #4 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
The rear looks like an F106 to me.
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 07:49 AM   #5 (permalink)
Member # 79206
The rear is an IH RA-15. no L/S were available it's either open or has a NO-SPIN *aka* detroit locker. I'm building a front axle out of one.
trust me I know what I'm doing....
Colorado Dave is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 08:37 AM   #6 (permalink)
Member # 72929
Somebody mentioned the RA-20,
Do you have a place for technical info about this?
Where do you get parts?
Old 05-13-2007, 11:29 AM   #7 (permalink)
Member # 79206
the RA-15 and 20 are very similar... the only diffrence I can find is that the 20 have larger hubs with a big 5 lug budd pattern. some say the RA-15 was only open and that the 20 had the NOSPIN. Brake drums are impossable to find. bearings and seals should be available at most local parts stores but since you are in Honduras... I'd have no idea. I could get you the phone number for a couple of vendors that deal in IH parts/manuals if you would like.
Old 05-13-2007, 03:00 PM   #8 (permalink)
Member # 72929
Yes, I already changed bearings and seals without problems.
Been more into ID it because of things more like shafts and big things, I know that is hard to break them but you never know.
Have you used yours yet?
The phone numbers for the vendors will be fine, thank you in advance.
Old 05-13-2007, 03:04 PM   #9 (permalink)
Member # 29210
Anyone?
They were just International's medium duty line, you could get their gas motors and probably some diesels. Called Loadstars. They had all kinds of available engines, transmissions, auxiliary transmissions, and axles- so no two you see will probably be alike.
Looked like this:
:laughing:
Old 05-14-2007, 05:26 AM   #10 (permalink)
Member # 79206
those axles did not come from a loadstar because they are too narrow. They were found mostly in 1300 or 200 (1 tons) and 1500(1.5 ton) series pickups. because it is the big 6 lug I'd say it came from a 1960's 1300 pickup. heres a lead on a place with used parts... coonrods 303-838-8505 let me know if that number works its been awhile
Old 05-14-2007, 07:31 AM   #11 (permalink)
Member # 72929
WMS to WMS is about 71 or 72"
Old 05-14-2007, 04:10 PM   #12 (permalink)
Member # 79206
its from a 60's 1300 series pickup.
