My Truck + Mogs = Build Time - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2007, 04:54 PM   #76 (permalink)
willyswanter's Avatar
Member # 16419
Send a message via ICQ to willyswanter
Well today was fun... I went and got breakfast and got home and my key just spun and spun in the deadbolt... Locked out with my food getting cold. So after eating on my porch I spent 2.5 hours drilling, hammering, chiseling, and destroying my way through the deadbolt. They apparently don't want people to be able to get in without a key lol. So it was a slow start today and I had to quit a bit early due to some work related things I need to get done.
Anyway, finished the gusseting on the lower links mounts and finish welded everything on the axle:
Also finished the plating on the back of the pass. side upper link mount and you can see the gussets on the lower link a bit better in this pic:
Finished the ram mount. I had to add the obligatory logo so it reminds me of my faithful 60 I had:
Hard to tell in the pic but it slopes upward which won't really help me in anyway but it made me feel better for doing it?
[SIZE="3"]Jason "Willyswanter" Payne[/SIZE]
[SIZE="5"][COLOR="Red"]R.I.P. DOZER[/COLOR][/SIZE]
We'll miss you Noel :(
[SIZE="3"]Added by PBB: RIP Jason, we already miss you.
[/SIZE]
willyswanter is offline   Reply With Quote Quick reply to this message
Old 07-15-2007, 05:58 PM   #77 (permalink)
Member # 85316
Send a message via AIM to svt150j49
Thing is turning out sick. Keep it up....
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 07-15-2007, 06:06 PM   #78 (permalink)
comeonstart's Avatar
Member # 49939
Very sexy build, I love it.
________
AlexKiss
comeonstart is offline   Reply With Quote Quick reply to this message
Old 07-15-2007, 08:56 PM   #79 (permalink)
phishs toy's Avatar
Member # 11301
Looks real good , I like the ram mount its beefy . Wonder if those UPS guys are playing football with my locker parts again ?
Team Tetanus Racing # 4825
Some Men Are Born Brothers , Others Earn It
BUILD THREAD
It .
phishs toy is offline   Reply With Quote Quick reply to this message
Old 07-16-2007, 12:14 AM   #80 (permalink)
Member # 10045
The U419 axles are not stronger than U416 axles! The center section, axle shafts,knuckles are the same as on the U406-416 axles. The lower portal gear and bearings are also the same, only the upper gear and the input bearing, stub shaft is different. But not stronger! The 419 uses the old style U1300L portal boxes and on those are only the upper portal gear and the input bearing different. Also the axle shaft seals are different and they use an needle bearing instead of an bushing on the front axle shafts. The U419 has the portal box casting# 424331 and the U406-416 casting is 416331, but the last U406-416s are identical to the U419-417 axles. The U1300L CV is much bigger than the U419 CV, also the the whole knuckle is bigger on the U1300L! The 419 axle has the same load rating as the 406-416 axle (3.7T). Pre 73 406-416 axles are different and weaker.
I would not use the stock Unimog driveshafts, because the U joints are not sealed!!!
www.killeraxles.com
Wolfgang is offline   Reply With Quote Quick reply to this message
Old 07-16-2007, 06:48 AM   #81 (permalink)
Member # 16419
OMG! OMG! OMG! OMG!
Sorry just wanted to use as many explanation points as you did...
I have the latest model U416's and 419's here... My 416's use trunion style axle shafts while my 419's use yoke style. So theres a difference right there, but you say they are the same? My 416's have the same box and disc brakes so yes they are the late 416's. And as I said and you said, the upper gear, stub, and bearings are different.
[/SIZE]
Old 07-16-2007, 07:21 AM   #82 (permalink)
Member # 47848
Was this an answer for Jason? I'm sure he knew all that already and some of us either don't care or could find out the same information from a quick search.
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne
[/QUOTE]
1999 4Runner
4x4mike is offline   Reply With Quote Quick reply to this message
Old 07-16-2007, 08:38 AM   #83 (permalink)
Member # 16419
He just saw that I wrote that the 419's are stronger than the early 406/416's and he wanted to argue even though he said the same thing... Sure the late 406/416's have the same boxes but not the early ones. And even still the upper gear is different along with the bearings and stub. He just wanted to go on a U1300L (member here) rant to show how much he knows.
[/SIZE]
Old 07-16-2007, 08:49 AM   #84 (permalink)
Member # 47848
Cool. Now he's all e-strong.
[/QUOTE]
1999 4Runner
Old 07-16-2007, 10:47 AM   #85 (permalink)
OX
Member # 3113
Have any pics that show both? (or just the 419 stuff as I have a set of later disk 406's already, which I assume are the same as 416's???)
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
79 Bronc XLT, 400/C6/404 Mogs/42 roks
OX is offline   Reply With Quote Quick reply to this message
Old 07-16-2007, 08:10 PM   #86 (permalink)
B.A.R.K's Avatar
Member # 8540
I just found these...
Waiting for my turn to get to the rocks...
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 07-16-2007, 08:34 PM   #87 (permalink)
Member # 16419
Yep, 5 years ago
[/SIZE]
Old 07-16-2007, 08:37 PM   #88 (permalink)
Member # 16419
The trunion style look like the 404 shaft where they enter the CV whereas the yoke style looks like a dana 60 shaft.
I have some pics somewhere, I'll try to dig them up...
[/SIZE]
Old 07-21-2007, 08:06 PM   #89 (permalink)
They call me Bondo
RockChump's Avatar
Member # 9252
those pics have to be from frank riens. ha ha sick build mang
"Safety is our # 2 concern" Rage 4th
1965 Jeep CJ6 work in progress
RockChump is offline   Reply With Quote Quick reply to this message
Old 07-23-2007, 11:51 AM   #90 (permalink)
fcfred's Avatar
Member # 3263
looking good. i can't wait to see it ready to wheel again
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 07-23-2007, 12:04 PM   #91 (permalink)
Big91RustyBucket's Avatar
Member # 87635
Send a message via AIM to Big91RustyBucket
Yeah you used to have a can back and shit to right?
~Philip
Midwestern 4x4 Parts
You've inspired me to start a build thread of my own.......... all the pictures will be upside down to reflect my driving style!
89 S10 Truggy
Big91RustyBucket is offline   Reply With Quote Quick reply to this message
Old 07-23-2007, 12:13 PM   #92 (permalink)
Member # 49744
where are you at in bakersfield. im right off allen. i need some fab work done
[FONT="Franklin Gothic Medium"][SIZE="2"][COLOR="SeaGreen"]after monday and tuesday even the calendar says WTF!!!!!!!!!
96 f350 powerstroke.[/COLOR][/SIZE][/FONT]
gfbgreaser289 is offline   Reply With Quote Quick reply to this message
Old 07-23-2007, 06:09 PM   #93 (permalink)
Member # 16419
I'm an east sider. Over off Altavista and Bernard by the old Green Frog Market.
I aint no fabber, I just jb weld yo.
[/SIZE]
Old 07-23-2007, 07:21 PM   #94 (permalink)
Realsquash's Avatar
Member # 2578
Have you made any progress on the wheel/brake adaptors?
Andy
Realsquash is offline   Reply With Quote Quick reply to this message
Old 07-23-2007, 08:16 PM   #95 (permalink)
Member # 16419
Nope, went to Hollister all last weekend thursday through Sunday to get some motivation back up... Then we had a power outtage tonight so no progress again, litteraly just got power 5 minutes ago. So hopefully tomorrow after work.
[/SIZE]
Old 07-26-2007, 09:00 PM   #96 (permalink)
Member # 37089
Jason, looks good as usual. I have to ask, where did you learn all of your fab skills from? Was your old man a machinist or something? I might make it to BB this year just to see your rig!!
Later,
Jeff
M&M Fabrications
stallion85 is offline   Reply With Quote Quick reply to this message
Old 07-26-2007, 09:31 PM   #97 (permalink)
Member # 16419
I had NO fab skills or truck knowledge before 6 years ago... I bought a stick welder and started sticking pieces of metal together and moved on to a lincoln 155 wire feed and got better and better. Just takes practive. For the machining stuff I took a lathe class in college just to do it and got interested in it then just started going in and using the schools machine shop in my free time teaching myself as I went. I learned a ton of truck knowledge on here since about 2002 just searching. Once I got into the heavier stuff I started buying books on the subject.
[/SIZE]
Old 07-26-2007, 09:39 PM   #98 (permalink)
Member # 37089
Cool, so there is hope for me. I just need the time and tools! The wife and kids take up a lot of my free time!!
I know your a busy guy too. Did you sell off you D60 stuff yet?
M&M Fabrications
Old 07-26-2007, 09:46 PM   #99 (permalink)
Member # 16419
Negative. I was actually thinking today at lunch that I have enough parts (with that 60) to build a moon buggy lol. Think I'd rather sell for $$$ though.
[/SIZE]
Old 07-26-2007, 10:04 PM   #100 (permalink)
Member # 13787
Send a message via AIM to zcarczar
You better have this thing done for the rubicon, I might need a winch anchor if I get stuck in little sluice.
zcarczar is offline   Reply With Quote Quick reply to this message
