My Truck + Mogs = Build Time - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2007, 10:29 PM   #101 (permalink)
TRD
TRD's Avatar
Member # 8286
Originally Posted by willyswanter View Post
Negative. I was actually thinking today at lunch that I have enough parts (with that 60) to build a moon buggy lol. Think I'd rather sell for $$$ though.
well then you would certainly have both ends of the spectrum covered
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 08:34 AM   #102 (permalink)
Hammered Scout's Avatar
Member # 62561
ZCARCZAR when you going to the Rubicon? Is the Beeter(Chris)going? I plan on going to the Con in the next couple months and would like to cruise up with a SoCal crew.
Scout 800 Cummins 4BT/T400/Atlas/D60/14B/39.5's
1985 Chevy Crew Cab 6bt/P Pump/NV4500/205/D60,70/40's
Hammered Scout is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 06:04 PM   #103 (permalink)
willyswanter's Avatar
Member # 16419
Send a message via ICQ to willyswanter
He's going on my run on the 23rd ish of August. Were running Weds through Saturday and yeah Chris is going as well.
[SIZE="3"]Jason "Willyswanter" Payne[/SIZE]
[SIZE="5"][COLOR="Red"]R.I.P. DOZER[/COLOR][/SIZE]
We'll miss you Noel :(
[SIZE="3"]Added by PBB: RIP Jason, we already miss you.
[/SIZE]
willyswanter is offline   Reply With Quote Quick reply to this message
Old 07-28-2007, 01:50 AM   #104 (permalink)
Member # 62561
Right on!
By the way Jason...... your rebuild is bitchen.
Old 07-28-2007, 08:24 PM   #105 (permalink)
Erik D_lux's Avatar
Member # 1007
Looking good
As for the shock mounts....
I would be scared that youre going to bend the bolt. I know I bend mine and I just use the stock misalignments.
Also my shocks got all scratched up from the tabs running into them. When you install your shocks and tabs just articulate the shocks rod end and grind the top of the tab until it dosent bind or get hit.
www.DLUXfab.com
Erik D_lux is offline   Reply With Quote Quick reply to this message
Old 07-28-2007, 08:52 PM   #106 (permalink)
Member # 16419
Well I would think if the bolts are kept torqued to the proper amount, the clamping force would keep everything parallel to each other... But, I will definately keep an eye on them, never had a problem with bending before but I definately understand what you are saying.
[/SIZE]
Old 07-29-2007, 08:05 PM   #107 (permalink)
Member # 16419
Got link material?
2.5" OD .5625" wall DOM lowers and 2" .250" wall DOM uppers.
Many thanks goes out to our own GoZuki for hooking me up with all that fat tube
[/SIZE]
Old 07-29-2007, 08:54 PM   #108 (permalink)
Clifcattankass's Avatar
Member # 40472
i like the way you think
Clifcattankass is offline   Reply With Quote Quick reply to this message
Old 07-29-2007, 09:17 PM   #109 (permalink)
Member # 16419
This is the reason I went so thick... These were .375" wall:
Click me for super fun prize!
[/SIZE]
Old 07-29-2007, 09:25 PM   #110 (permalink)
77k5's Avatar
Member # 35786
What OD?
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
970-945-7777
77k5 is online now   Reply With Quote Quick reply to this message
Old 07-29-2007, 09:30 PM   #111 (permalink)
Member # 85316
Send a message via AIM to svt150j49
thats sick. using wrenches for plates when you its all you got..
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 07-29-2007, 09:30 PM   #112 (permalink)
Member # 16419
2" OD .375" wall.
[/SIZE]
Old 07-29-2007, 09:30 PM   #113 (permalink)
Member # 16419
Sears wouldn't take the wrenches back when I took that whole thing into them
[/SIZE]
Old 07-30-2007, 02:42 PM   #114 (permalink)
Member # 37089
Jason, what a trail fix!! What kind of welder was that being used? Do you have an onboard kit on your rig?
M&M Fabrications
stallion85 is offline   Reply With Quote Quick reply to this message
Old 07-30-2007, 02:49 PM   #115 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
that is a ready welder spool gun. looks like it had flux core wire in it (no gas cup) and also didn't have the cold start switch (making it the model 10000 if I remember right). I have the same one and love the shit out of it. 2 batteries in series and weld away. I have used mine in the shop on my mig (control heat with the machine, wire on the gun) to weld aluminum and stainless now. does great with both.
Hijack off
I like the mogs, but damn, if you're gonna build a buggy soon, all the work now??? I like the job you're doing and am amazed at what that truck has evolved from to what it is
Kelly Kaiser
Vertical Limits Inc
913.731.3040
for the fastest quick release extinguisher mounts available and UTV parts
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 07-30-2007, 04:38 PM   #116 (permalink)
Member # 8790
Originally Posted by B.A.R.K View Post
I just found these...
He originally lifted it in the first place to "get by" till he built a buggy. that was 6+ years ago. look where it is now....
shaggyk5 is offline   Reply With Quote Quick reply to this message
Old 07-30-2007, 05:25 PM   #117 (permalink)
Member # 16419
Yeah that was supposed to be my tow rig
[/SIZE]
Old 08-05-2007, 10:43 AM   #118 (permalink)
SBChero's Avatar
Member # 18438
Send a message via AIM to SBChero
so... done yet?
[COLOR="Red"]RIP - Jason Payne (willyswanter)[/COLOR]
SBChero is offline   Reply With Quote Quick reply to this message
Old 08-05-2007, 09:50 PM   #119 (permalink)
I am very salty
FISHMOUTH FABWORKS's Avatar
Member # 43776
Send a message via Yahoo to FISHMOUTH FABWORKS
looking good! i guess i will be hiking in that weekend to check this thing out!
Dan Trout- Dave Halabuk RIP
Rage4th #76
FISHMOUTH FABWORKS LLC
PHONE-(916)-996-1532
WEBSITE
E-MAIL
Check us out on Facebook and Instagram!
FISHMOUTH FABWORKS is offline   Reply With Quote Quick reply to this message
Old 08-05-2007, 11:06 PM   #120 (permalink)
Member # 67882
they does wrench back to sears if they craftsmen and ask for some replacement ones lol
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 08-06-2007, 06:02 AM   #121 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
This is so incoherent it's almost sig worthy.
The bartender only serves brown liquor in hell, and that sure sounds like heaven to me.
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 08-06-2007, 12:44 PM   #122 (permalink)
Member # 19615
Send a message via AIM to afroman006
This makes me think of the coonass coach from the movie The Waterboy.
Texas A&M Offroad
84 Chevy -Pigpen- Best trail truck there ever was...
afroman006 is offline   Reply With Quote Quick reply to this message
Old 08-06-2007, 04:47 PM   #123 (permalink)
Member # 16419
Ok sorry for the delays in an update, had to work out of town for the last week... This is Sundays progress:
Stock mog hub being machined down to fit inside 8 lug rotor and fit the new 8 lug hub flange. Basically took ~2" off of the OD and machined the pockets for the lug stud heads to recess into:
This is the 8 lug hub flange that was shown earlier in this thread in a rough state. This is the rotor side finished:
3 of them done:
Here is a 99% complete hub. The new flange is welded to the modified mog hub. The rotor will slip over the assembly like new trucks do. Rotor indexes on the lip in the center of the flange. Studs are normal 9/16". Only thing left to do is turn the OD to get rid of the weld bead and then they are done. The joint was heavily "V" grooved so it's not a problem:
Finished hub with the OD turned to size:
Hub installed with rotor. I don't have the shorter bolts for the hub yet so I used a few of the stockers with a 1" spacer made from 3/4" EMT... Works for now.
Stock HMMWV rim with plenty of clearance:
[/SIZE]
Old 08-06-2007, 04:47 PM   #124 (permalink)
Member # 16419
Next was project was to build the final links for the front. As you saw in an earlier post I acquired some nice 2.5" 9/16" wall DOM for my lowers and 2" 1/4" wall DOM for the uppers. Since the lowers were 9/16" wall the ID became 1.375" which needed to be opened to 1.5" to clear the tube adapters. So I bored a 1.5" hole into the end of the links about 1.5" deep, finally got to use my steady rest:
Now the tube adapters fit and you can definately see how thick these links are... Next up was to taper the ends to make them look a little nicer:
Tapered and welded:
Installed:
Never thought I would think 1-1/4" heims are small but after these links, I'm thinking so. Don't think they will bend? In person it really is comical how big the links are. Got all the links finished and all the 8 lug hubs finished today.
Also got one coilover assembled and installed:
I got new shocks but re-used the coils and hardware. I cannot find one of the coil carriers so I didn't get the pass. shock in tonight but I'll find it in the daylight tomorrow and get it on and get the thing sittings on it's tires.
I think I need some lower rate coils now so I'll have to do some math tomorrow once it's sitting on it's own weight and see what I need to do.
Yes I know I can't change the lug studs in these if I break/stirp one As I said earlier these are temp to get me to the rubicon and moab in a few months. I'll be building the solid one piece aluminum ones once those trips are over, just don't have time at the moment.
[/SIZE]
Old 08-06-2007, 04:48 PM   #125 (permalink)
B.A.R.K's Avatar
Member # 8540
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
