ok been searching for two hours - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2002, 10:03 PM   #1 (permalink)
ItsaCJ6's Avatar
Member # 6340
Search, search, search, that's all I have doing for the last two hours
Ok since I was in the planning stageof my install of the 14bolt I recived the other day. I had the wonderous idea to use my current springs 1 3/4 - 4 inch lift springs. Any thoughts?
Or should I grab some waggy springs and slap them on?
Second search is on the narrowing of the 14 bolt.
Is it possible to purchase a new spindle and cut and narrow the 14 bolt's long side to the length of the short side? It looks like its about 5 inchs difference. If so, has anyone done that, and what sources are there for the spindles.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 06-30-2002, 10:15 PM   #2 (permalink)
Member # 4001
Springs..if they work for you now, then continue to use them.
Narrowed 14: Seen it done before. Makes it ~ 60" wms-wms. You cut the long side off, and then reattach the same spindle. (obviously, you need to cut it down and then machine the old tube off of the spindle so that it will fit again)
Scout Dude is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 10:47 AM   #3 (permalink)
Member # 5021
How narrow are you trying to go with the 14 bolt?
Don't be "THAT GUY" on the trail.
The Rockslut is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 11:09 AM   #4 (permalink)
bigdude's Avatar
Member # 6007
If you have a 67" wide 14 bolt and want to go to 63" wide all you need to do is get the bearing hubs from a cab and chasis truck. You will have to move your backing plate mounts also. Much easier than cutting it down in my eyes.
4-Seats of Fury
LS1, 700r4, Atlas 3.0, 2.5 SAWs, Reds
Lead Foot Syndicate
bigdude is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 11:27 AM   #5 (permalink)
Member # 5021
Thats exactly where i was going.
Old 07-01-2002, 11:59 AM   #6 (permalink)
ItsaCJ6's Avatar
Member # 6340
Yea I have the 67incher from a burb. ? Sounds allot easier than cutting it. So is there a part number for the bearing hub ??
Or if I go to the yard is there away to tell? longer snout on the hub?
Marc
Old 07-01-2002, 12:00 PM   #7 (permalink)
bigdude's Avatar
Member # 6007
Originally posted by The Rockslut
Camo Trailer Trash 14 bolt in the rear
Nice sig
4-Seats of Fury
Lead Foot Syndicate
Old 07-01-2002, 12:02 PM   #8 (permalink)
ItsaCJ6's Avatar
Member # 6340
63 would be great (so the hub swap sounds good) However 60 would be sweet.
Marc
Old 07-01-2002, 12:11 PM   #9 (permalink)
bigdude's Avatar
Member # 6007
For ease of completion I would just swap the hbs and see if 63" will work.
The bearing hubs are available on all 1-ton chevy truck that were "Cab and Chasis". We find mostly tool/compartment trucks here but have found some flatbeds also. The WMS is just farther back on the actual hub allowing for the narrower axle while still using the same shafts/housing as other 14 bolts.
4-Seats of Fury
Lead Foot Syndicate
Old 07-01-2002, 12:45 PM   #10 (permalink)
Member # 4001
Actually, every single Duallie, whether it was a Cab & chassis, or dually pick-up bed, had a ~63" WMS to WMS measurement..the Cab & Chassis only thing is a myth. (There might be some wider duallis-P/U style ones, but I have never seen them!)
Old 07-01-2002, 12:58 PM   #11 (permalink)
bigdude's Avatar
Member # 6007
No Sh!t I've only seen C&C trucks at the pic n' pull, never a full-bed dually so that's news to me. Should make them easier to find then
4-Seats of Fury
Lead Foot Syndicate
Old 07-01-2002, 03:57 PM   #12 (permalink)
ItsaCJ6's Avatar
Member # 6340
Sounds Awesome I should be rolling by Sunday. Now I just need a front 60
Marc
