Buggy plumbing questions, brakes, coolers, etc - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2008, 06:53 PM   #1 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
Posting for my buddy Brain, he is afraid of getting flamed in this section, but Im use to it do here:
Building an FJ40 buggy
this is it: https://www.pirate4x4.com/forum/showthread.php?t=562600
Brakes
1. what size and material hard lines should I use for the brakes? I am planing on 3/16 steel or stainless steel. (20-25 bucks for 25 feet.)
2. for the fittings, all my crap like master cylinder, cutting brakes, proportioning valves, residual pressure valves, line locks, etc are all 1/8" npt female... so do I buy male flared ends to put on the 3/16 tube to connect everything and use braided SS flex to connect to the axles? Any input on fittings, t's, and mount tabs, etc. for securing them would be helpful.
3. are the male flared ends that will connect to the calipers on the 3/4 ton chevy rears and 1 ton front. are they the same?
Trans Cooling lines
1. I want connect to my cooler from the th350 with SS braided AN lines. is -6AN right for this and what fitting do I need to connect the lines to my trans?
2. I also want to run an oil cooler any suggestions?
Pinion Nuts
what size sockets are needed to remove the pinion nut on a chevy dana 60/ 14boltff? they are bigger than the 1 1/4" I have.
B2Krawler is offline   Reply With Quote Quick reply to this message
Old 02-01-2008, 07:30 PM   #2 (permalink)
sierravalley's Avatar
Member # 77176
Send a message via Skype™ to sierravalley
Hey this link ought to help you out
http://i17.photobucket.com/albums/b5.../your20gay.jpg
sierravalley is offline   Reply With Quote Quick reply to this message
