dual alternators?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2008, 01:38 PM   #1 (permalink)
Member # 99058
dual alternators??
Anyone ever try this or hear of it being done? I know some newer trucks have it. I figured it would be a better set up than dual batteries, or not? I have a spare alt for my danger ranger and could fab a bracket to mount it in place of the ac compressor. Tell me what you guys think.
Stranger ranger is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 01:43 PM   #2 (permalink)
Member # 55403
This is my setup dual charging systems and welder , not of CAUTION when alternator #2 is full fielded for welding or recepticle it can produce 150VDC (shock hazard) you need to bring engine down to idle or switch off field voltage .
Half the fire wall/part of the hood & front grill its all CJ
ditchpig is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 01:46 PM   #3 (permalink)
Mechanos's Avatar
Member # 6704
If you tried to charge one battery with two alternators, you'd have to have both alternators with exactly matched outputs (ain't never gonna happen) or they end up fighting each other. Dual alternators is nothing new or difficult... you just have two completely independent 12V systems on one vehicle. One alt. charges one battery, the other alt. charges a second battery. The two 12V systems need to isolated from one another.
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 01:53 PM   #4 (permalink)
Member # 99058
thanks i just read that somewhere. I want the one seperate system to run a winch and possibly have a normal 120v receptical.
Old 03-17-2008, 01:55 PM   #5 (permalink)
Member # 347
I run two systems -- alternator and batterries are fully independent on the charge side, but tied together on ground. I overkilled the grounding, with that in mind.
It works well, and I have a beefy solenoid that allows me to jump them to connect the batteries when I want, and enough cable to flip-flop connections if I need.
Randii
randii is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 02:56 PM   #6 (permalink)
Member # 99058
sounds like a pretty good setup
Old 03-17-2008, 03:01 PM   #7 (permalink)
Danger Ranger's Avatar
Member # 1234
I think the only reason to run dual alt's on a wheeler is to have the second that is independant from the charging system for a on-board welder. Other than that... dual batts will get it done for winching. WTF are you trying to power anyhow... christmas lights on your moon visor?
It's the perfect time of year, Somewhere far away from here.
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 03:42 PM   #8 (permalink)
Member # 347
That's available, too.
Electric water pump and electric fan at a crawl... mix in heated seats for the wife, and a fresh air blower for the dog, and I'm almost as pimp as your average 'neck in a chrome buggy.
Randii (overkill)
Old 03-17-2008, 03:45 PM   #9 (permalink)
Member # 30590
Two alternators one battery
http://www.balmar.net/page21-centerfielder.html
You could also use the regulator from one alt and run both fields.
73jeep is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 04:46 PM   #10 (permalink)
Member # 1234
Randii (overkill)
I just installed a trail back massager for my wife in the rig
Old 03-17-2008, 05:05 PM   #11 (permalink)
mondtster's Avatar
Member # 25349
Send a message via AIM to mondtster
The factory dual alternator installations have a tendency to eat alternators for this reason. If you need more current output, get one big alternator for the best performance or separate your power systems.
mondtster is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 05:25 PM   #12 (permalink)
Member # 87256
Send a message via MSN to jeeptomster
I have two alternators on my Tj:
img]http://www.jeeptuning-foto.com/albums/userpics/10019/05112007%28001%29.jpg[/img]
We do a lot of winching in our competitions over here therfore we need to recharge the batterys as fast as possible.
I instaled a Mercedes Benz 150A alternator with an external regulator.
The 150A alt is running on 14.4 Volts, the origianal 120A unit comes in as the tension during winching go´s under 14Volts.
i testet the setup at a race last october and it worked just great!
During normal conditions (my TJ is my Dalydriver) i had no problems reguarding this setup!
TJ4.0+AW4 - 2" K&S flex - 8.8ARB - JK D44- Bimotor 8274 - PSC cage - Q78+Stauns
jeeptomster is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 06:33 PM   #13 (permalink)
blown4x4's Avatar
Member # 43190
I run to seperate 12v systems on my rig. One setup is just for the electric fans and the winch(don't have yet). I use the single wire chevy alternators. I'm pretty happen with it. Although I do have a short somewhere in the wiring when I installed the painless harness.
1976 F-150 2.5tons locked disk braked 466bff ord doubler 44" boggers coil-overs air bumps etc
blown4x4 is offline   Reply With Quote Quick reply to this message
Old 03-17-2008, 07:31 PM   #14 (permalink)
Member # 347
Huh, I guess my wife's gonna be riding with you, too.
Randii (still got the dog, at least)
Old 03-17-2008, 07:40 PM   #15 (permalink)
TNRanger's Avatar
Member # 22676
Send a message via ICQ to TNRanger Send a message via AIM to TNRanger
I have a 300A large case GM alt as my main and a 120A ford unit as my secondary. The secondary is for welding
There's not point in having dual alts if you get a big one uless it's for this reason.
95 YJ 4 links f/r, D60/14b 5.8/c6/203/205 115.5"wb
90 Ranger 5.0/435/205, D44/D60
04 F-250 PSD
TNRanger is offline   Reply With Quote Quick reply to this message
